Question about Henry Vacuums
Electro conductive grease for henry hoover
The connection a the nozzle of my henry hoover needs new electro conductive lubricant. where can i buy ths? the connection is intermitent which means the sweeping rollers dont work properly.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 85 Answers
If you are in the uk try
01484 718674
or try some KY Jelly or even vaseline as it contains a lot of water
Posted on Oct 20, 2013
2 Suggested Answers
  • 126 Answers
SOURCE: Hoover WindTunnel Canister: Roller brush motor not turning
These motors have a fuse incorporated in the field winding and it sounds like that blew. These motors sometimes overheat at the front bearing and the bearing will melt into the plastic housing. This will cause the fuse to blow. It sounds like that's your problem. You can remove the motor by removing the three screws on the bottom of the powerhead and then check the front bearing for any bubbling or blistering in the plastic housing. The shaft of the motor should turn easily.
Posted on Jan 27, 2008
Water in henry hoover motor HVR 200A
Chris, I hate to be the bearer of bad news, but you've already guessed it. You need a new machine. Personally, if I were you, I'd check into the small shop vac's, type of vacuum. Craftsman has a good one that I've been using for, wow, more years than I can remember now. I had it a long time I know that. I actually picked up a spare one at a garage sale last summer and put it up on a shelf for one my old one finally bites the bullet, but so far, it's still going strong. The wet/dry vac's have a float system in them that actually plug the bottom of the air chamber where the vac draws it's air from, when the water gets too high in the tank. The motor starts to race faster than normal and that's the tipoff that it's full. Dump out the tank and go at it again. Better luck this time.
Nov 10, 2013 | Numatic Henry Bagged Canister Vacuum
Hi, My Henry hoover has stopped working about 10
Check the motor brushes as well as the on/off switch.
Sep 20, 2017 | Hoover Vacuums
How do i fit the hoover bag
If you remove the top of the vacuum via the clips on the side you will see the empty bucket. Where the hose connects is where you will fit the bag from the inside. On the bag you will see a hole with cardboard around, this will then push over the outlet.
Apr 08, 2010 | Henry Numatic "" Canister Vacuum
New Henry Numactic Moter - How to wire?!
on the motor there are 2 connection together and one on it's own and on the brushes 1 each ignore these .and on the motor fix to the 2 tab one that you can see a wire connection on and then fix to the other side of the motor .this worked for me
Mar 11, 2010 | Henry Numatic "" Canister Vacuum
My hoover smells of ammonia
I too have a problem with a bad smell coming from my henry hound hoover, but thats probely because i haven't used a hoover bag. I took the cloth filter out,banged all the dust off, then sprayed it with 'RugDoctor' pet stain remover for carpets and upholstery. It still smells a bit, but not half as bad as befor. I have now ordered a reusable,zipable,washable cloth hoover bag especially made for Henry's. It cost £8.80 from ebay with free postage. Hope this helps Nikki.
Oct 30, 2009 | Numatic HHR-200 Henry Hound Bagged...
Rewiring a Henry Hoover
Ignoring for the moment the fascinating question of why you would actually want to do this...  I'm sorry to tell you it won't work. Swapping the wires over will make no difference.
Apr 20, 2009 | Numatic Henry Bagged Canister Vacuum
My henry hoover has just stoped working its not the fuse do you have any ideas
I had exactly the same problem.there were no burning smells coming from it so nothing seemd obvious.I then took it apart and checked that all wires were connected,which they were.Then decided to check the plug.After replacing the fuse I chopped the cable of (as it is a seald plug) and connected up a new one.Hey Presto,Henry was alive again.Hope this helps.
Nov 03, 2008 | Hoover Vacuums
Henry hoover
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=26736&thid=552936
Henry Hoover
Posted by modbod on Apr 28, 2008
Automatic rewind cable not working. Cable will only come out a few feet then jams. Currently using an extension lead. Any advice on how to free cable much appreciated.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
I am sorry that Henry Hoover is having a problem with his cordwinder and what happens that the cord tends to overlap the other cord inside of the vacuum and what needs to be done is this; #1 take apart the cordwinder and unwrap al the cord all the way out then re-wrap the cord and re-install #2, if that does not work then lubricate the cordwinder but not the cord to have it work more efficiently, and #3 if all else fails replace the cordwinder with a new one. Always when using the cordwinder, always pull out everything until the end to use the cord all the way out to prevent the cord from over lapping and binding up inside the Henry Hoover. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Don – The Vac Man
Go Ahead. Use Us.
Apr 28, 2008 | Henry Numatic "" Canister Vacuum
Vacuums Logo
173 people viewed this question
Top Henry Vacuums Experts
Gerry Harvey
Gerry Harvey
Chris Nomland
Chris Nomland
Are you a Henry Vacuum Expert? Answer questions, earn points and help others
