Question about Mintek DTV-263 26 in. TV/DVD Combo
How do i restore proper color - Mintek DTV-263 26 in. TV/DVD Combo
    Master:
  • 359 Answers
Go to the menu on the TV and look for display settings where you can adjust the color saturation, tint, sharpness etc.
Posted on Oct 14, 2013
No display on monitor
Open your computer and discharge static by holding the chasis casing of your system unit for 1 minute. Then start cleaning your video and memory card and also the their slot by using vacuum cleaner and small paint brush. Then put it back again and test for a display. Most of the time because of the dust covered the slot or the pin of the video and memory so the system did not detected that hardware that is why those hardware will not functioning. Clean and test have a nice day!
Jun 04, 2011 | Computers & Internet
* verify if all cables are properly connected.
* Perform monitor self test by unplugging the video cable (ex.VGA) from the monitor, if you see colored bars showing on the monitor that means your monitor works fine but if there's NO colored bars showing on the monitor that means the monitor needs to be replaced.
* Go to safe mode, if successful, perform system restore. If system restore fails, run hardware diagnostic by going to F12. If no failure found, perform pc restore, if it still fails-you can reinstall you operating system.
*If all fails, you can contact your manufacturer.
***PLS NOTE that performing PC RESTORE and OPERATING SYSTEM REINSTALLATION will cause DELETION of DATA. IF YOU HAVE IMPORTANT FILES, BACK UP YOUR FILES FIRST BEFORE DOING the suggested resolution.***
Jun 04, 2011 | Intel D865GBF Motherboard
Unplugged printer to fix printer jam; color is not true now
Hi littlefri971,
The first thing we need to do here is re-seat the Cartridges once to ensure that they are properly secured.
Once done, please run an Alignment Test and print a test page.
In case this does not resolve the issue please clean the cartridge and carriage electrical contacts with a cotton swab moistened with water.
If you believe the cartridge is good test it in another compatible printer.
If this fails to restore proper color, replace the color cartridge.
Have a great day!
Sep 06, 2010 | Epson Stylus NX300 All-In-One InkJet...
Hey, I'm trying to restore my e455 to a setting where it will print color jobs. How do I do that?
Click on your start menu. Then in Settings select Printers and Faxes.
Find your printer and right click on it. Select propertied and in imaging or color managemant in print properities select color instead of black and white and apply and ok.
That should do it.
Jul 19, 2010 | Toshiba e-studio 455 Copier
One of my friends did something to my computer and i think it inverted the colors. i had to change the display settings to actuall see the screen but now certain colors, or it might just be white or black,...
Right-mouse click anywhere on your "desktop wallpaper".
Click Properties.
Did your friend change a "theme", via the 'Theme' tab?
Did your friend change something via the 'Appearance' tab?
Did your friend change the 'Settings' (down to 4 or 16 colors) ?
If you connect an external monitor to the VGA-output port,
do you get the same colours, or do you get "proper" colours?
If you get "proper" colours, it could be that your internal LCD screen is damaged.
If all else fails,
click Start
Click All Programs
Click Accessories
Click System Tools
Click System Restore
Select a "restore point" one or two days ago, before your friend touched your computer, and "restore" your computer to that date/time.
Jan 05, 2010 | Dell Latitude D520 Battery PC Notebook
My tv color is missing red and the people look
It sounds like you have a bad or broken COAX, or S-Video cable. Replace whichever you have. Or first just wiggle the COAX or S-Video cable and see if the color comes in proper.
Sep 19, 2009 | Hitachi 57F500 57" Rear Projection...
I cant scan anything onto my computer with my printer. It says there is an error. I' not sure if we hve the software, but we have hp photosmart essential 3.5
If ur facing this problem recently. than u can restore ur computer.
start /run /type restore / restore the computer to earlier time.
select the bold color date which is last week date( the day when the scanner is working properly). click in next .
now the computer will restart.
you will get a message like restore completed successfully.
or else install the drivers again.
Jul 18, 2009 | HP OfficeJet 6110 All-In-One InkJet...
HP 2600 COLOR PROBLEM
I am not sure what out of position refers to but if it is a setting in the printer this should fix it.
Restoring the factory-set defaults returns all of the settings to the factory defaults. Restore the factory-set defaults
  1. Use the c00317853.gif (LEFT ARROW) or the c00317858.gif (RIGHT ARROW) button to select Service, and then press c00317851.gif (SELECT).
  2. Use the c00317853.gif (LEFT ARROW) or the c00317858.gif (RIGHT ARROW) button to select Restore defaults, and then press c00317851.gif (SELECT). The device automatically restarts.
  3. Hope this helps
Mar 24, 2009 | HP Color LaserJet 2600n Printer
Cannot reset defaults for HP color monitor. No reds, just garrish
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 01, 2009 | HP vs19 (Silver) 19" LCD Monitor
Need two restors burnt out need color or size
board numbers are usually the value , use multi meter on resistors to get proper value
Nov 30, 2008 | Car Audio & Video
Mintek DTV-263 26 in. TV/DVD Combo Logo
Top Mintek Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Mintek Televison and Video Expert? Answer questions, earn points and help others
