Question about Refrigerators
Refrigerator does not defrost and makes ice hit fan in refrigerator make noise and it stops with door open. model RF217ACRS
    Champion:
  • 210 Answers
Wrong model number
Posted on Oct 15, 2013
4 Suggested Answers
  • 172 Answers
SOURCE: Kenmore Coldspot w/Ice Maker Not Making Ice
hi LOP7,
In most cases you can easily solve this problem.
step one would be to make sure your freezer is getting cold enough. If you have icecream in your freezer is it frozen solid or is it soft. Most icemakers cycle around 0 degrees and if your freezer is not getting to 0 then it will not cycle and it will not make ice.
Step two would be to make sure you icemake is cycling. To do this simply lift the little shut off arm on your icemaker and wait about an hour then go back to the icemaker and drop the arm down. The icemaker should start going through a cycle. You should notice the arm slowly begin to raise and the ice dispencer fingers will begin to turn. Then you will hear it call for water. You may hear a humm.
If the freezer is cold enough and the icemaker is cycling that only leaves the inlet valve. replace the valve and enjoy the ice.
If the freezer is cold enought and the icemaker does not cycle, then you have a bad icemaker. Simply replace the icemaker and viola.
Third if the freezer is not cold enought 0 defrees. Then you may have a defrost problem. In this case post more info and I will be happy to help. Good luck mca0824@aol.com
Posted on Apr 30, 2008
  • 22 Answers
SOURCE: refrigerator
the fan behind the ice maker is iced up poss fault defrost heater gone try total defrost faor a list 36 hrs restart it noise come back then you need to repace the defrost heater hope this helps
Posted on Nov 13, 2008
heatman101
  • 43501 Answers
SOURCE: hi, my lg fridge (model
Here is a tip that I wrote about refrigerators and the fan noisethat they develop sometimes...
RefrigeratorFan Noise
heatman101
Posted on Jul 26, 2011
Freezer has constant noise. When we open freezer drawer, noise stops. Could this be the fan?
usually the fan runs with door open as well. how ever u may have a problem with fan hitting something if it has come loose or off its support bracket, if u have an ice build up in freezer usually due to defrost problem the fan may make funny noises also
Mar 13, 2015 | Samsung RF4267HARS Stainless Steel French...
Fridge has started running very loudly, only a year old.
Defrost the unit. Unplug it and leave the door open overnight. The noise is the fan hitting on ice when you shut the door. If you can, adjust the defrost timer for an extra few minutes defrost/ drain down, and make sure the underneath and rear of the unit are scrupulously clean.
May 03, 2012 | Refrigerators
I have samsung refrigrator model RL729WCSW since yesterday the Fan inside refrigrator has Hitting noise and the sound will Stop When The Door Is Opened.would you explain me how to rectify the problem. the...
The defrost is not working and the fan is hitting ice buildup...
Check out these tips...they can help you figure out what is going wrong with your refrigerator
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 21, 2010 | Refrigerators
Grrr noise that stops when doors are opened
The noise you are hearing is probably the fan blades hitting some ice build up. Un plug your refrigerator for over night and it will defrost melting the ice. If it still makes the noise after that then the fan motor is going bad, you will need to replace it soon. The reason that it stops when you open the door is because the power is cut off to the fan when you open the door.
Nov 20, 2009 | LG LRFD22850 Bottom Freezer Refrigerator...
Frigidaire side by side freezer - LOUD noise...
It sounds like the evaporator fan is hitting ice that is built up on the evaporator coil. When it's making the noise, open the freezer door and see if it stops.
(Most models are wired so that the evaporator fan cuts off when the freezer door is open.)
Check the inside back, lower panel of the freezer for ice built up or frost on it. If there is, you have a defrost problem that is most likley a bad heater. It's located around the coil inside the freezer behind the panel you will be looking at. The defrost problem would explain the freezer not freezing ice cream.
Nov 12, 2009 | Frigidaire FRS26R4A Side by Side...
I need help or repair for my LG Refrig
could be ice on or around the fan...when the fan hits ice it makes noize....
Nov 11, 2009 | Refrigerators
Buzzing sound
If noise stops when you open the door, you may have a noisy fan (or could have ice build up, causing fan blade to hit ice and cause noise). I gather it is a frost-free model ie has a fan in the freezer compartment. If noise is caused by fan hitting ice build up, you may have a problem with the auto defrost system, as you should not get ice build up in a frost free.
Noise stops when you open door because fan turns off when door is opened.
Aug 09, 2009 | LG Refrigerators
Refrigerator
Nov 13, 2008 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
