Question about Whirlpool Kitchen Ranges
My whirlpool gw397lxuq06 control broad not working?
Samsung PN60E530A3FXZA replace the power broad and still no picture or sound?
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
MAIN LOGIC BOARD
Aug 22, 2015 | Samsung Televison & Video
How do I get to the igniter on a whirlpool gas dryer? Model # WGD59005WO
1. remove lint screen, remove 2 screws
2. Take a broad blade putty knife and insert on either side where top meets front panel, should pop up
3. remove 2 screws in front panel
4. remove fronr panel
5. Igniter is loacted on burner valve in side funnel
good luck
Jan 31, 2013 | Whirlpool WGD5900S Gas Dryer
Whirlpool dryer Model wgd59005wo not getting heat
1. remove lint screen and remove screws
2. take a broad blade putty knife ind insert between top and front panel
on either side(should pop up)
3. remove front panel screws at top of panel, remove panel
4. Igniter element is locared on burner(ceramic)
Jan 31, 2013 | Whirlpool Dryers
My Whirlpool model ED2SHAMT00 water dispenser and the light does not work.
MAKE SURE THAT YOU PUSH EACH BUTTON ON YOR PANEL ALL THE WAY IN AND SEE WHAT HAPPENS THIS PUSH BUTTONS ARE ELECTRICLY CODEPENDED TO EACH OTHER AND MUST BE PUSHED IN BEYOUND THE CLICK AS THE APPLIANCE AGES.WORSE CASE PANEL BROAD REPLACEMENT
Oct 21, 2012 | Refrigerators
I have been advised by a certified tech that I need a new control broad for my LG refrigerator. I have ordered the control broad from LG, but I need help installing it. Please send me instructions on how...
Replacing is rather simple. First unplug unit. Find and galvinised panel on the back of unit where the power cord leads to. Remove the 3 screws and panel. Here is the board. All the connector on this board can only go in one spot so remove all the wire harnesses. There are 4 locking tabs that hold the board onto the unit usually a needle nose pliers works the best for these. After it is removed place the new board into position and replace the harnesses into the locking postions close panel and plug new back in. Done.
Jun 03, 2011 | LG Refrigerators
Noises
Now this is a broad complaint!! LOL! Where do we start? What does the noise sound like? If it sounds like a bird chirping, it's your evap fan motor. If it sounds like somethings hitting the fan blade, your unit's frozen up with ice and needs to defrosted COMPLETELY and a new defrost system replaced. Call us and we'll be sure to ge the right parts out to you right away asap so you can get this unit back up and running again! We look forward to hearing from you and hope to be able to work with you more.
Sep 10, 2009 | Whirlpool GC5SHEXN Side by Side...
Whirlpool gas range control panel doesn't work
Hello glad to help. If this is the part that has been replaced before you may want to have a technician take a look at why the board is failing.
I have included a link to our PartsDirect page where you can purchase the part you need to complete your repair. Just click the blue link below to be taken to the page.
searspartsdirect.com/partsdirect/part-model/Whirlpool-Parts/Range-Parts/Model-GW397LXUQ06/1198/0124250/W1203145/00001?blt=06&prst=0&shdMod=GW397LXUQ06
Aug 02, 2017 | Whirlpool GS460 Gas Kitchen Range
Whirlpool LER7646E will not stay running
I was told to replace the HEAT RELAY (3405281)or the Module Broad, but the problem is that 48VDC is not present on the motor relay.
Oct 12, 2008 | Whirlpool LER7646E Dryer
Driving Force? Pro pedal set problem PS2
my ps2 games dose'tn recognize driving force pro any more.so do need to replace my broad on the in side of my driving force pro.because all testing that dun piont to the broad.
Dec 22, 2007 | Logitech Driving Force Pro (963293) Wheel...
Kitchen Ranges Logo
21 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
