Buffalo ministation I want to change permissions. It is read only.
    Master:
  • 630 Answers
Are you doing this as an administrator On the ''Security" tab, towards the bottom click on "Advanced" then "Change Permission" and go from there. Should be able to affect all sub folders and whatnot.
Thanks
Posted on Oct 14, 2013
Testimonial: "I have a Mac and I can not find the security tab"
  • 88 Answers
SOURCE: buffalo ministation
if you dropped your hard-drive and it stopped functioning - high chances that the drive has a physical crash. Best suggestion will be to contact a professional data recovery team if the data on the drive is really important (Coz, they charge a bomb for the recovery) Suggestion would be to talk to drivesavers.com
Posted on Jan 11, 2009
SOURCE: cannot access data in my buffalo ministation orange light showing
Try accessing it in another USB port or computer. If still not, it may unfortunately be damaged. You may be able to get it replaced under warranty.
Posted on Jul 07, 2009
bob_computer
  • 3153 Answers
SOURCE: xp cannot install this hardware. Buffalo
I devised these simple steps that tend to remedy quite a few issues with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
If none of the above steps help look at updating the drivers from the manufacturers web site in the support section
Posted on Sep 24, 2009
Testimonial: "very helpful advice and correct also. I had changed the usb lead and it cured the problem."
  • 10406 Answers
SOURCE: my usb external Buffalo ministation
The external storage device has several major components:
* USB cable
* external power-supply
* disk-drive inside the enclosure
* USB-to-disk-drive adapter inside the enclosure.
Try a different USB cable.
Try a different USB port on your computer.
Try a USB port on a different computer.
Take a multi-meter, and measure the output voltage/amperage of the power-supply,
and compare with the specifications on the label of the power-supply.
Open the enclosure, and remove the disk-drive, and attach it as a "slave" drive in a desktop computer, to see if bypassing the USB-to-disk-drive adapter bypasses the problem.
Look at the label on the disk-drive, for manufacturer, product-number, serial-number, and manufacture date. Access the manufacturer's web-site, and use "check warranty status" to see if the warranty still is valid. If so, the drive can be replaced, at minimal cost to you.
Buy a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Search online for a professional "data recovery service". For a significant fee, they can repair your disk-drive, just long-enough to copy your files to a new disk-drive.
Posted on Nov 04, 2010
  • 224 Answers
SOURCE: I have a buffalo ministation
It is possible to recover data after formatting. This guy does it remotely and works off of donations http://FreeDataRecovery.us
Posted on Jul 24, 2011
Formatting buffalo ministation stealth for mac
Probably the software could not recognize or support the disk type/model
Dec 18, 2013 | Buffalo Technology 1tb Ministation Stealth...
Boot your computer into safe mode then open mycomputer right click on the drive and click properties you can change the permissions from there
Oct 14, 2013 | Buffalo Technology MiniStation Stealth 1TB...
Buffalo Ministation not flashing or recognized
Im having the same problem sound like your cable is not working or you need a new case because the pins are broken.
Jul 22, 2013 | Buffalo Technology 320GB MINISTATION TURBO...
Buffalo ministation not auto-playing or showing in my computer
i have exactly the same problem with HD-PCU2 500gb ministation (Buffalo). i have also gone through the solution given by John Adams. i cannot find the device in disk management, therefore i cannot format the device...is it going to work again..please help
Sep 03, 2012 | Buffalo Technology Buffalo MiniStation...
My external hd buffalo ministation fell a small fall,ever since that fall it is detected but cnt read..doesn't have the icon in my computer..how can i reboot it.
There is nothing you can do: that little fall has destroyed the hard disk's reading heads. This unit is dead, time for a new one.
Feb 25, 2011 | Buffalo Technology (USA), INC. - 500GB...
Buffalo ministation
Oct 18, 2008 | Buffalo Technology 320GB MINISTATION TURBO...
Open Questions:
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
