Question about Porter Cable 3/8" Reversible Air Angle Drill PTD381
I have had a Porter Cable 7557 right angle drill for many years. just recenlty it stopped working all together. The cord is fine and has power running to the switch. The switch tested fine. Any ideas?
  • 495 Answers
Providing you some routines to check before you opt for contacting a technician.
Six routines must be followed in order to minimize the chances of your hydraulic equipment suffering costly, premature component failures and unscheduled downtime:
* Maintain fluid cleanliness;
* Maintain fluid temperature and viscosity within optimum limits;
* Maintain hydraulic system settings to manufacturers' specifications;
* Schedule component change-outs before they fail;
* Follow correct commissioning procedures; and
* Conduct failure analysis.
Posted on Apr 24, 2009
Ran over power cord on porter cable belt sander. How do I remove?
Remove the screws holding the 2 sides together and expose the wiring. Remove the remnants of old cord and replace with new one. Reassemble.
Feb 15, 2017 | Porter Cable Tools & Hardware - Others
Where can I get a wiring diagram for a Porter Cable20volt battery
images for Porter Cable20volt battery wiring
Power Tools - Porter-Cable
www.portercable.com/20Volt
Get Linked with the Power and Performance of the 20V MAX* system of tools. Powered by a lithium ion battery platform which delivers the performance and ease ...
Shop PORTER-CABLE 20-Volt Max Lithium Ion Battery, 2 ...
www.lowes.com/pd_472386-79992-PCC680LP_0__?productId...
Lowe'sPORTER-CABLE 20-Volt Max 1.5-Amp Hours Power... ... PORTER-CABLE 20-VoltMax 4.0-Amp Hours... ... PORTER-CABLE 2-Pack 20-Volt Max 4-Amp Hours...Missing: diagram
Jan 20, 2016 | Porter Drills
Porter-Cable battery charger model #8605
go to www.dewaltservicenet.com and enter the model number of your drill. It will get you to the parts breakdown and will tell you if there is a charger available from the factory. Or call 1-800-433-9258 1-800-4DEWALT. stanley black and decker owns all of them so yes that's the right place!
Jan 02, 2013 | Porter Cable 19.2V Drill Kit
Describe your 2 - 1/2"
Not sure what you question is however Porter Cable and Bostitch are now part of Dewalt. Parts and owners manuals as well as other documents are available at the web address below.
http://servicenet.dewalt.com/
Aug 24, 2011 | Porter Cable 2 - 1/2" 15 - Gauge Angle...
Porter cable hammer drill 987 suddenly stopped running.
Push the battery in and out while pressing the trigger on the the drill to see if there is a loose connection here.
Check the battery terminals inside the drill and the battery terminals .These sometimes become tarnished and don't make contact. Clean with very fine sandpaper.
Mar 04, 2011 | Porter Cable 987 19.2 Volt Grip - To - Fit...
My porter cable 19.2v model 8605 battery charger
Porter Cable has not offered a replacement for their poorly designed 19.2V chargers. I had the same problem and happen to like my drill and circular saw. I found a universal charger called a model number CHUN-2420. Google it--I got mine for $27 plus shipping. All you need to do to make this work is splice 3 wires.
My charger is a PC model 8624, so the instructions might vary slightly between the chargers. Remove the six screws on the bottom of your PC charger. Remove the bottom section. Remove the screw(s) that attach the circuit card to the plastic housing. Disconnect the 3 pin white charging connector from the circuit card, and cutoff the connector. Discard the circuit card and power cord. Cut the 3 conductor (red/yellow/black) cable coming out of the Chun-2420 approximately 2' from the charger. Splice these three wires to the three wires in the charger housing that connect to your battery. In my situation, Red/Red, Yellow/Yellow, White/Black. To verify, red=positive, black/white=negative, yellow=temperature sensor. Wrap the red/yellow/black cable with electrical tape where it exits the PC charger through the power cord hole. Re-attach the bottom.
Jul 24, 2010 | Porter Cable 19.2V Drill Kit
Driver blade won't retract to shoot the next nail
Sounds like you have something caught in the guide causing it to jam a lil.
These guns are allmost disposable and have a short life span.
Mar 31, 2010 | Porter Cable 2 - 1/2" 15 - Gauge Angle...
My gun is leaking air ... a have 2 finish nailers and are leaking air , please can u tell me where can send those to fix?? i'm in north south carolina my sip code is 29536
The closest loction to you is in Charlotte:
DELTA | PORTER-CABLE/DEWALT FACTORY SERVICE #042
3557-B WILKINSON BOULEVARD
CHARLOTTE, NC 28208
US
704-392-0245
Oct 01, 2009 | Porter Cable 2 - 1/2" 15 - Gauge Angle...
Brand new drill won't charge - never battery
You have the right to return the second unit for a refund or credit on another brand
Jul 22, 2009 | Porter Cable-Cable PCL180DK-2 18-Volt...
Porter/Cable 15 gauge angle finish nailer
The driver assembly can sometimes get bent or the tip can get a little deformed causing it to hang up in the nose. Other than that, not much else it could be if you rebuilt the whole thing
Dec 31, 2008 | Porter Cable 16 - Gauge Finish Brad Nailer...
Porter Cable 3/8" Reversible Air Angle Drill PTD381 Logo
233 people viewed this question
Top Porter Cable Drills Experts
LINDEN DAVIES
Level 1 Expert
Tom Chichester
Steve P
Steve P
Are you a Porter Cable Drill Expert? Answer questions, earn points and help others
