Question about Dishwashers
Water goes in but it doesnt drain - Dishwashers
  • 35 Answers
I don't understand how you expect to get a resonse with the details of the probelm. Did you read the troubleshooting section in the user manual?
Posted on Oct 14, 2013
Water sits in bottom
If water does not drain at all then the drain pump could be blocked.
If only a little water is remaining but cycle is complete, then this is normal.
However, do check the kitchen drain is clear and you do not have a garbage disposer (insinkerator) in sink which is full. Normally empty it before you start the dishwasher.
Do you get any alarms (lights flashing etc)
Jan 03, 2013 | Frigidaire 24 in. FDB1050REC Stainless...
It doesnt stop filling
The pressure switch, also called the water level switch, is what control the amount of water goes in the machine, If your machine is constantly filling to the overflow point, then that is your problem. Now, if water is going in and the level is staying the same then your machine drain line is lower than the pump and your siphoning out the water as it goes in. Pull the drain up a little a that should fix the problem.
Apr 26, 2012 | Samsung SW62ASP Top Load Washer
I have a whirlpool washing machine WI4818S which isnt draining. I have checked the hose where the water drains out but that doesnt seem to be blocked there. also when i start the machine up, it doesnt...
Check the water pump, it may be completely dirty, washing powder. Too much washing powder.
By reducing the plastic tube goes into hydrostat. Wyjmnij powder tray, put the washing machine on one side of the plastic pull out the exact reduction and Purge this branch of the sludge and other particles.
S?uchaj Zapis fonetyczny
May 06, 2011 | Washing Machines
Is it typical for water to drip from furnace through pipe to outside? i was told from city inspector that this is indicator that unit has problem and it's releasing water throught secondary valve.
condensation should go to your drain pipe, sometimes the pipe that goes outside doesnt have declivity for the water to go in the drain pipe
Aug 24, 2010 | Heating & Cooling
Maytag washer doesnt fill with water. after about 3 inches of water in bottom, it starts draining out.
pull the drain hose out of the wall
it should only be six inches in the wall
or will create a syphone and the washer will continue to fill and drain and fill and drain
try this and let me know how it goes
Feb 09, 2010 | Maytag Legacy Series Top Load Washer
When washer goes to spin cycle it doesnt drain water
Remove the hose from the drain and lower the hose to a floor drain or a large bucket. If water flows, there is a failure with the pump. If no water flows there is an obstruction, such as a sock lodged in the drain path from tub to pump. Either condition will require some disassembly to repair.
Jul 12, 2009 | Whirlpool Washing Machines
What causes water to run in bottom of refrigarator
This is caused by plugged drain tube. When the freezer goes through a defrost cycle the water drains down a tube in the back of the freezer to the pan under the refrigerator. When this tube is plugged the water doesnt drain through the tube but drains through the vent in the refer. The easy way to fix this is to unplug the refrigerator for 24 hours.
Jun 30, 2009 | GE Refrigerators
Rinse and drain
Just had this problem and fixed it by installing a new timer. Be sure to remember the order the wires were attached on the old timer.
Dec 16, 2007 | Maytag MAV7600 Top Load Washer
Dishwashers Logo
Top Dishwashers Experts
Owen Barnes
