Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Deck ingaging diagram - Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
    New Friend:
  • 38 Answers
Sears online with ur model number
Posted on Oct 15, 2013
Why doesn't the mower deck come up or down when ingaged
sorry with no make /model we have no way of offering suggestions
Sep 08, 2015 | Garden
Why will the motor stall when put into gear or trying to in gage the mower deck
You may need to lubricate the bearings on the deck or change them out.
Jun 19, 2015 | Garden
I have a Craftsman mower, model 917.273810, and when you engage the blades, the brake pads that are used to stop the blades from turning when you disengage the blades...won't release and it trys to...
Sounds like you have a broken spring #148 on diagram, part #169022 that holds the idler arm back. Go to www.searspartsdirect.com and enter the model # of your mower and click on the mower deck to print drawing out, take your deck off the mower and see if all the springs are ok. If the pads are closed on the pulleys and the pads release when you turn the idler arm, the deck is ok. The problem will be a bad or disconnected safety switch that cuts the motor off if you try to ingage the mower. If the switch is disconnected under the seat it will kill the engine when the mower is engaged. I had this problem on my mower, just plug the wiring into this switch or replace it if it is bad.
Aug 16, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Transmission wont ingage or move
Check to make sure the drive belt is still on there.There are two belts.One is on the deck for the blades the other is the drive belt.It is above the deck.
Jul 01, 2011 | Cub Cadet Garden
My z2400 stopped moving all belts seem to be in place
did you burn out the pto? try ingaging it at a lower idle speed and see if it will work if not could be a wiring issue
also if it wiring a wiring diagram and a test light are needed. If you don't have the wiring diagram, use a test light, start at the clutch and work your way back checking for current at each switch/connector. It maybe the ignition switch, there should be one terminal on it that feeds 12v to the clutch curcuit.
could be your ignition switch but thats the best way to find out where its not getting power to.
May 29, 2011 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
My riding lawnmower blades will not disengage or engage Now my lawn mower will not start
just replaced some pulleys on my craftsman 42 inch cut and now the blades are ingages all the time, but it will start
Jul 17, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
When I pull the blade lever the blades do not turn. Found that the trottle wire to pto is broken. Need instructions and a diagram on how to fix it. Thanks
just wire it back together, you don't have to worry about crossing the wires up. because it's just a hot and ground for a coil to magnitize to ingage the pto clutch.
Jun 21, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Garden tools
Sounds like a pully might be stuck or one of the deck spindles might be froze-up
Aug 22, 2009 | Garden
Not ingaging
Check to see if the belt might have come off and wedged on something under the frame. Or,,maybe a spindle could be locked-up. One more thing to check is if your deck might have a braking system on it to keep the blades from moveing it might not be disingaging.
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
21 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
