Question about Refrigerators
Red high temperature warning indictor light on how can I fix this
  • Refrigerators Master
  • 842 Answers
Not all refrigerators work the same, for example, Whirlpool has a temp button located on the control panel within the fridge section. By pushing this button reset with turn off the alarm. Again, ever unit and manufacture has different ways of correcting this issue. Are you having temperature issues? Are the compartments cold enough to hold food or drinks? Was there a power outage that caused this alarm to go off recently? This is an alarm system designed to alert you of a possible issue.
I hope this helps.
Look online under the manufacture name or call the manufacture directly and they should be able to assist on the light issue. You may be able to contact a service center to answers to clear this issue from the panel. 1-800-496-2982 ask for Bob. He can assist you in the issue if needed.
Good Luck
Posted on Oct 15, 2013
No alarm sounding but red light is flashing?
Warning light (red)
If the temperature warning light (4) lights up, it
indicates that the temperature within the freezer has
reached a level where the safe food storage is no
longer ensured. When the freezer is first switched on, the warning light will stay on until the temperature has dropped to
a safe level for the storage of frozen food.
Temperature acoustic alarm
This appliance incorporates an alarm which gives off
an audible signal whenever the warning light comes
on. This signal can be temporarily stopped by
depressing the push button for fast-freezing (6).
The fast-freezing push button can be released as
soon as the warning light is off.
Open door acoustic alarm
This appliance also incorporates an alarm which
sounds if the door is left open for more than 60
seconds. The signal will be stopped when the door is
closed again.
Dado
Sep 02, 2014 | Zanussi 3.53 cu. ft. / 100 liter Upright...
Hi, I just changed a Power Supply(PSU1) and now
got the same Problem yesterday .. did u fixed it ?
Sep 23, 2013 | Enhance Technology Ultrastor RS16SS
How do I check my coolant temperature on my 2006 BMW it has no gauge
Yours is monitored by a light and a set point.When temperature gets a certain temperature the dash light will go on,the radiator cap is under high pressure to remove so the light is your indictor if it's running hot.
Feb 10, 2013 | Cars & Trucks
Is there a temperature and oil light on a 1995 suzuki vs 1400 intruder motorcycle
Oil indicator (red) turns off once you have operational oil pressure from the oil pump. No high coolant's temperature indicator.
Oct 21, 2012 | Suzuki Motorcycles
I have overheating problem with my VW combi 2,5 i . Red warning light comes on . Replaced the reservoir and two pointed switch on top. Fan operating correct. The red light comes on before the temperature...
Hi,it can be losts of things ex.waterpump,airlock in system,watercap leaking,leak,thermostat so its best to get it to a garage to be presure tested.hope u come rite
May 20, 2011 | Volkswagen Microbus Cars & Trucks
Warning light to the left above temp light, red and yellow snow flakes yellow in colour, no audio warning, not flashing, 2007 ford mondeo
It is an outside temperature warning light. Turns yellow when the temperature gets to around 5 degrees and then turns red with the temperature gets to around 0.
Mar 06, 2011 | Ford Focus Cars & Trucks
Power indicator /red/ and warning led/red/ are lighting after ea 15 sec. a lamp never start and fans goes in OFF mode. I checked power supply lines S5V,S-5V,S16V on the Main Board . I checked unit lamp...
If power indicator light red and warning indicator red flashing than according to user manual :-
The projector has been cooled down enough and the temperature returns to normal. When turning ON the projector the WARNING indicator stops flashing. CHECK AND CLEAN THE AIR FILTER.
Experience:- 1. if the temperature is very low than temperature sensor maybe misbehave.
2. If anyone fan not working
so please you check fans.
(If lamp or lamp ballast unit faulty than after a time period the lamp indicator light ON not a warning indicator. I experience many times if any fan in projector are broken or jamed the temperature light if present otherwise warning light ON or flashing)
Jan 20, 2011 | Sanyo PLV-Z4 Multimedia Projectors
Audi A6 2000 a red warning light and noise comes on when I start the car. It looks like a thermometer with waves under it, what does that mean?
A thermometer with waves under it indicates a possible temperature problem, like high temperature.
But, if it does it when just starting the car, when cold, then the CTS or coolant temperature sensor (or circuit.. wiring) may be sending a faulty signal or a false high temperature.
Oct 28, 2010 | Audi A6 Cars & Trucks
Red warning light marked A/T Temp has come on.Meaning?
This light warns you if the transmission temperature goes to high
Jun 29, 2009 | Mitsubishi Raider Cars & Trucks
High temp warning
2 BLINKS: Temperature
Apr 05, 2008 | Sony KDS-R50XBR1 50" HDTV
Refrigerators Logo
62 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
