Question about Samsung Assembly Evaporator Refridgerator Haemil Oem Original Part Da96-00626h
Samsung RF217 refigergator makes a noise because ice builds up and fan hits the ice
    New Friend:
  • 4 Answers
If possible try to let the fridge cool down or a bit until the ice melts and if the ice is visible, than it would be better to attempt to break off the ice while it is warmer than usual
Posted on Oct 15, 2013
Ice is building up and making fan noise. I replaced the defrost thermostat. Four or five days, it starts making noise again. Any ideas where to look after replacing the thermostat?
I suppose it's possible the fan has some issues of clearance. You may be able to adjust it to provide needed clearance. But if the Ice build-up is excessive, there may be a "timer" that may have an effect on the amount of ice build.
May 02, 2015 | Samsung Refrigerators
Freezer has constant noise. When we open freezer drawer, noise stops. Could this be the fan?
usually the fan runs with door open as well. how ever u may have a problem with fan hitting something if it has come loose or off its support bracket, if u have an ice build up in freezer usually due to defrost problem the fan may make funny noises also
Mar 13, 2015 | Samsung RF4267HARS Stainless Steel French...
Samsung RS263tdbp fan making noise when closed and opened refrigerator doors
is there a build up of ice around it or is the fan blade bent and hitting something, otherwise u may have a bad motor in the fan going out
Jul 17, 2014 | Samsung RS263TDBP Side by Side...
Samsung refrigerator
Hi Kathy.
That is your Evaporator fan hitting against something.
I would think from hearing it and assuming the fridge/freezer is running warmer than usual that the defrost heater may not be working and the noise is the fan hitting the build up of ice.
I would get a technician to look at this ASAP
Josh
May 11, 2013 | Refrigerators
Tempreture on fridge too high ice build up in fridge mahes noise like a tractor
Your automatic defrost cycle may not be working. Feel the walls inside and if they are hard solid you have ice build up and the fan is hitting the walls or ice making the noise. Unplug your fridge for 2 days and let the ice in the walls melt. Put towels on floor to catch water. Plug it back in and it should run fine for a couple of weeks until the ice builds up again. You have a bad timer and it isn't letting the defrost cycle come on. Defrost cycle are heating elements that melt the ice build up and runs about 10 mins once a day or so. This will give you time to check if an afforable repair can be done or a replacement fridge.
Jul 11, 2010 | Samsung Refrigerators
My 10 year old amana fridge makes a noise from the fan in the freezer it sounds like something is hitting it ,but on inspection I see nothing hitting it
Look closer because ice can build up and the fan just barely hits it making the noise. If the fan blades are not hitting anything, replace the fan motor as the bearings are getting worn out.
Dec 30, 2009 | Amana ABB1927DE Bottom Freezer...
Buzzing sound
If noise stops when you open the door, you may have a noisy fan (or could have ice build up, causing fan blade to hit ice and cause noise). I gather it is a frost-free model ie has a fan in the freezer compartment. If noise is caused by fan hitting ice build up, you may have a problem with the auto defrost system, as you should not get ice build up in a frost free.
Noise stops when you open door because fan turns off when door is opened.
Aug 09, 2009 | LG Refrigerators
Noise on the ice maker
I think you are having the same issue that I am having. My noise is being caused due to ice build up around the fan inside the freezer. There is a switch when you open the door that causes the fan to shut off, hence the reason the noise stops when you open the door.
I pulled the cover (just below the ice maker) and removed the ice that had built up. Only problem is that after three days the noise is back. I think there may be a bigger problem that is causing the ice to build up around the fan.
Jan 05, 2009 | Samsung RS2630WW Side by Side Refrigerator
Ice/cold room chiller fan noise
bearings in motor bad(new motor) fan blade hitting ice build up many different causes for this
Mar 29, 2008 | Freezers
FREEZER SOUNDS VERY NOISY
It could be the fan is bad or that it is hitting ice. If the noise is kind of a buzzing like it is hitting ice...defrost your unit by unplugging and waiting a day or so for full melt out...then check your door gaskets for cleanliness and good seal. Avoid 'windowshopping".
Dec 22, 2007 | Samsung RS2630SH Side by Side Refrigerator
Samsung Assembly Evaporator Refridgerator Haemil Oem Original Part Da96-00626h Logo
75 people viewed this question
Top Samsung Radio Communications Experts
JP Services
JP Services
Jerry Greenberg
Jerry Greenberg
Are you a Samsung Radio Communication Expert? Answer questions, earn points and help others
