Question about GPS
Garmin nuvi 265w
Software corrupted
  • Fritz Engel Oct 24, 2013
    I have there downloader. The computer or the site does not recognize my nuvi265W.
  • 49 Answers
You need to go to the Garmin website, and get a downloader program. You will need the serial number of your GPS. Once you register, the site will try to identify your unit connected to your computer. Once the handshake takes place, it will advise you on what programs you need to replace.
Posted on Oct 23, 2013
  • ChuckyMo Oct 24, 2013
    If the site does not see or recognize your Garmin, you may have to call the 800 telephone number for Garmin support to get help with that. One other suggestion is that you try to register the unit on the Garmin site and see if it will recognize it then.
HarryHarley
  • 343 Answers
SOURCE: restore garmin nuvi 265w
Do a MASTER RESET for that.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} To perform a Master Reset on the nuvi 200, 205, 465, 500, 600, 700, 705, 1200,1300,1400 or 1600 series device:
Note: A master reset will erase all waypoints or favorites and will restore your unit to the default factory settings. But who cares if you have problems, right?
  1. Start with the unit OFF and unplugged from power
  2. Touch and hold the lower right corner of the screen with an index finger or the eraser end of a pencil
  3. Continue touching and holding the lower right hand corner of the screen then power the unit ON
  4. Release the power button when the device powers ON
    • You will see a new message: Do you really want to erase all user data?
  5. Remove your finger from the touchscreen when this message displays
  6. Touch Yes
The device will automatically reset. Follow the on screen prompts then place your device in an area with a clear view of the sky until it acquires satellites.
Posted on Jan 19, 2010
HarryHarley
  • 343 Answers
SOURCE: Garmin Nuvi 265W just will not switch on!
Bad or very low battery
Replace at Garmin
But first know this:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Sounds like a bad or low battery. Do you have the Garmin approved charger / car charger?? You may have to send your 265 in for battery replacement or try this:
There are three ways to charge the internal battery in your automotive GPS unit.1
  1. Use the provided vehicle power cable that came with your GPS unit. The unit will charge while powered on and using the device as well as when the GPS unit is powered off and plugged into a running vehicle. About 3 hrs for a full charge. If the unit will not charge in the vehicle, check the fuse in the power cable for the unit and the power outlet in the vehicle.
  2. Use an AC power adaptor. Some units come with this power cable to plug the GPS unit into a wall outlet allowing the GPS unit to take a charge. For units that do not come with this cable, one can be purchased from Garmin's online store.
  3. For most units, the final way of charging the battery is to plug the GPS into a powered on computer with a USB cable2. This method of charging will be a trickle charge and it may take longer (like a full day) than the other two options, however it will still charge the battery. A USB cable is provided with a few GPS models. For those that don't come with this cable, one can either be ordered from the online store or you can use a standard USB to mini-USB cable that fits the unit and plugs into your computer.
1 - Please note that temperature can play an effect on the charging of a device. If the battery registers a temperature of 0°C and below or 45°C and above (32°F and 113°F respectively) then it will not charge. When connected to external power it will only be operating off of external power.
2 - The Quest® and Quest® 2 will not charge using a USB cable.
HarryHarley
  • 343 Answers
SOURCE: Garmin Nuvi 265w voice command stopped working.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} If you are not receiving any sound on your Nüvi 2xx the first thing to check is that the sound is not muted. To ensure that your units sound is not muted please perform the following:
  1. Turn the device on
  2. Press the Volume button on the ‘Where To?’, ‘View Map’ screen
  3. Ensure the Mute box is not ‘checked’
If the mute button is not ‘ticked’, you will need to change the voice to ensure that the preset voice is not faulty:
  2. Touch the Tool icon
  3. Touch Settings
  4. Touch Language
  5. Touch the language voice next to Voice
  6. Scroll through and select another appropriate voice
If changing the voice is not helping you will need to ensure that you are running the latest software which can be done by installing a program called WebUpdater. WebUpdater can be installed via the link below:
http://www8.garmin.com/support/collection.jsp?product=999-99999-27
Once updated please allow the unit to reboot which will ensure the software successfully installs.
If after following all the above the final steps would be to perform a master reset:
  4. Release the power button when the device powers on. After 5-10 seconds you will see a new message: Do you really want to erase all user data?
  6. Touch Yes
The device will automatically reset. Please follow the on screen prompts on the nuvi and when completed place your device in an area with a clear view of the sky until it acquires satellites.
  • 1111 Answers
SOURCE: my Garmin Nuvi 265W will not turn on
plug it in to the computer for a few hours, then hold the power switch to the on position for up to 15 seconds.
if that fails, disconnect it from the power source, then press and hold the lower right corner of the screen, while holding the lower right corner, switch the power to the on position. once you see the message "do you really want to delete your data" select yes, then follow the on screen instructions
bill
Posted on Dec 11, 2009
sharcnet
  • 2130 Answers
SOURCE: Garmin Nuvi 265W, T, or WT
W = wide screen version, 4.3" diagonal screen GPS
T = Includes Traffic receiver
WT = widescreen & with traffic receiver
If I answered your question, please rate my solution as fixya.
Thanks
- Jim
SHARCNET-USA
Posted on May 12, 2009
My nuvi 265W screen keeps flashing the "GARMIN" startup logo...and wont stop
I can help you reset and fix your Garmin Nuvi 265W.
Getting stuck on the flashing Garmin logo, or a message about not finding any maps, are indications that the firmware / system software inside your GPS has been corrupted.
There are three steps to take to get your Nuvi 265W running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
_____________________________
Nuvi 265W Manuals here.
Apr 05, 2010 | Garmin Nuvi 265W GPS Receiver
Hi, im having problems with my gps, it doesn t turn on, i don´t know what happened, it is pretty new...i used it just a few days. thank you
I hope that helps.
Feb 14, 2010 | Garmin Nuvi 265W GPS Receiver
My garmin nuvi 265 will keep shutting down and rebooting while being used. any suggestions, it is just over 1 year old and this happens whether on battery power or if connected to DC power
Getting stuck on the flashing Garmin logo, or a message about not finding any maps, or freezing and rebooting, are indications that the firmware / system software inside your GPS has been corrupted.
I hope that helps.
Feb 01, 2010 | Garmin Nuvi 265W GPS Receiver
My garmin wont stay turned on
Shutting down, freezing, getting stuck on the flashing Garmin logo, or a message about not finding any maps, are indications that the firmware / system software inside your GPS has been corrupted.
I hope that helps.
Jan 11, 2010 | Garmin Nuvi 265W GPS Receiver
Screen not in sync when you type into it
Erratic behavior, or freezing and rebooting, are indications that the firmware / system software inside your GPS has been corrupted.
I hope that helps.
Jan 05, 2010 | Garmin Nuvi 265W GPS Receiver
Nuvi 265w is flashing on and off and will not turn on??? can you help john
I hope that helps.
Nov 16, 2009 | Garmin n?vi 265WT Car GPS Receiver
I have a nuvi 265W Garmin It keeps locking up and is A block off. Also It now has a problem finding the Satalights. We were in German and How friends have the same one and it is dead on. what is the...
I hope that helps.
Sep 29, 2009 | Garmin Nuvi 265W GPS Receiver
Nuvi 265w powers on but will not load
I hope that helps.
Sep 21, 2009 | Garmin Nuvi 265W GPS Receiver
Garmin nuvi system software missing 265W i try to update my garmin nuvi 260. I see on the screen: sytem software missing. I cannot do anything else. Please, help!
I hope that helps.
Feb 22, 2009 | Garmin nuvi 260W GPS Receiver
Garmin nuvi 265w
Getting stuck on the flashing Garmin logo, or a message about not finding any maps, are indications that the firmware / system software inside your GPS has been corrupted. Don't skip the hard reset step (or the backup step!)
I hope that helps.
Dec 25, 2008 | Garmin nuvi 350 GPS Receiver
GPS Logo
27 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
