Question about Garden
Castelgarden tractor mower problem
Oil leak at eingine block at gasket
    Sergeant:
  • 416 Answers
Bolts have loosed up you can try to tighten them but you may have to remove engine to get at all of them
Posted on Oct 17, 2013
3 Suggested Answers
  • 22 Answers
SOURCE: I am trying to get the 11 hp Briggs & Stratton
On the end of the shaft that comes from the motor there should be a bolt that holds the pulley in place. You will need to remove the bolt in order to get the pulley off. If you can lift the front end onto a couple of blocks it will make the job easier to do. You may have to place a screw drive in between the belt and the pulley. A wood wedge the width of the belt would be better as it would be less likely to damage the pulley. Depending on how old the tractor is, you may have to spray the bolt with a penetrating oil first to help loosen the bolt.
Hatter1
Posted on Mar 14, 2009
  • 22 Answers
SOURCE: Tractor mower started smoking- added oil- now it won't start
replace solenoid
Posted on Sep 03, 2009
Oil leak center case to left of oil filter gasket leaks bad after shut off is there a check valve inside
I would replace the filter. turn filter on BY HAND til the gasket seats, then 1/4 turn more ONLY (light film of new oil on gasket, dip fingertip in oil bottle and wipe onto gasket)
Oct 15, 2016 | John Deere Riding Lawn Mower. D170 54 in....
This is a lawn tractor air cooled lots of white smoke
You will likely find it clears after running it for a few minutes and then seems more blue. Your engine is getting tired and likely needs rings. Did it run when low in oil lately or just before this happened? It may need a "short block" (main part of the engine less parts like carb etc) or it may be cheaper to buy a used one the exact same.
May 08, 2016 | Garden
Is there a owners manual for the castelgarden TC12.5/102 mower
Looks like they are available. Don't know if any are free. First link definitely wants money.
castelgarden TC12 5 102 Google Search
Oct 25, 2014 | Garden
I have a b&s model 330000 engine which seems to leak a small amount of oil on the left side of the engine ans accumulates on the frame rail of the lawn tractor before dropping to the ground. i rec
My guess, without seeing the engine would be a seal or gasket is bad. Use Gunk brand degreaser to clean the engine. Start it up after that with the engine cover off and watch for leaks.
Jun 23, 2014 | Simplicity Regent 22 44 Riding Lawn Mower...
Castelgarden tractor mower problem oil leaking from eingine block gasket
I have seen those housings crack before. You should see what motor it is and then pull it off the mower and check for cracks in the housing and replace the gasket.
Oct 14, 2013 | Garden
Oil leaking around the oil filter, oil filter has been tightned
Did the old gasket from old filter stick to base and when you put a new filter on it now has two gaskets? I would remove filter and clean base thoroughly and check for additional gasket. After installing new filter I would clean the area well. Add oil, start unit and carefully check for leaks to pinpoint. Hope this helped. Happy wrenching!
Sep 08, 2013 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Oil leak in front lower end on 22 hp intek motor
Is the valve cover leaking? The only place besides cover
would be the gasket between block and sump plate
, lower engine. Alot a work there, leaking bad bad.
Jul 29, 2012 | Craftsman Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
