Question about Frigidaire Ovens
Our Frigidaire GLEB27Z7 is less than 3 years old. Our EOC went out a little over a year ago and we replaced it. It has gone out again and we are replacing it again. Is that normal it goes out 2ce in less than 3 years? Did we get a lemon? It's becoming very expensive to keep this oven. Help!!!
  • 1314 Answers
SOURCE: Whirlpool Gold double electric oven Model GBD277PDB1 lights
in answer to your question no not that your tech is bad his stuff is honest most of the costs are parts what i would is do contact whirlpool cust assistance and talk to them dont confuse cust assistace also known as custmer relations with with customer service they are not the same cust relations could give you the parts and then you can pay labor if your going to keep the oven see about a service contract on it ge or whirlpool both have good ones whirlpool cares about there cust so be nice when you talk to them like my mom had whirlpool ive allways had whirlpool but i just dont understand whats going on with this oven etc good luck
Posted on Dec 29, 2007
Powerman
  • 68 Answers
SOURCE: Kenmore Gas wall oven flashes F7 Code
Hi Indy2008,
You can find my solution to the most common cause of the F7 problem at the following link:
http://www.fixya.com/howto/h155060-dreaded_f7_error
I have helped over 1600 folks solve the F7 problem. The problem is usually with the touchpanel and not the ERC. My fix tells how to determine which part is faulty. Hopefully you will not need to purchase a new touchpanel, however, if you do, an internet search will lead you to lower cost sources.
Please let me know if my fix works for you. You can email me at:
hutchipop@yahoo.com
Regards,
Powerman
Posted on Mar 22, 2008
  • 10 Answers
SOURCE: JKP18 WALL OVEN IS A PIECE OF JUNK
http://www.fixya.com/howto/h155060-dreaded_f7_error    Go to the above link.  I will fix it.
Posted on Aug 18, 2008
SOURCE: THERMADORE DOUBLE OVEN NEW OLD STOCK
Thermador SCD302 upper oven preheat does not work; the heat temperature goes up very slow.
Posted on Dec 08, 2008
barkencoa
  • 3463 Answers
SOURCE: keep having to replace element
Not neccesscarily a problem with oven, as it is quite a common fault with fan ovens.
You could make sure that the fan is running properly, and is free to turn, and that the fan blades are not covered in grease etc',
Make sure that oven door seal is o/k, as hot air escaping here will lead to longer running times.
Plz rate this solution.
Thanks.
Posted on Dec 19, 2008
Frigidaire oven wont heat up but stovetop and digital all works
Hello angeleyez82 - The EOC (electronic oven control/control board) basically sends power to both the broil and bake elements. As long as the power supply to the range (240VAC) and wiring between the elements is correct, then typically only the element(s) or EOC could prevent the unit from heating. I hope this information helps to some degree.
Jun 25, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
Quatre par convection Erreur auto Frigidaire Nettoyant f 3 et f 1
F3 -The oven temperature sensor is open
Check for open wire connection between EOC (Electronic Oven Control - Clock) and the oven temperature sensor. Replace sensor if no wiring problem.
F1- EOC (Electronic Oven Control) failure
Replace EOC (Electronic Oven Control)
Thank You
Sep 03, 2010 | Frigidaire Ovens
Oven will not ignite, it is approx. 8 yrs old. 2 years ago the ignitor was changed for a similar problem. Everything works on stove even the broiler. Very dissapointed in the GE profile since I have had...
Jim your ignitor has gone bad once again.
You can turn off the gas supply,remove the oven racks,remove the oven base pan,remove the flame spreader to access the ignitor.
Place a clamp on amp meter over one wire of the ignitor and turn the control on for bake. If the ignitor does not glow at all. It is bad. If it glows and reads 3 amps or less on the amp meter it is still bad.
A proper functioning ignitor will light and re-light the burner in 45 seconds or less.
Jan 01, 2010 | GE Ovens
F7 frigidaire
F7 is a EOC(electronic oven/clock control) failure.
Replace and it would fix the problem.
Note :- Some models have 3 to 5 years warranty.
Thanks.
Jul 02, 2009 | Frigidaire FEB27S6DC / FEB27S7DC Electric...
F7 error code- what does this mean?
Frigidaire / Westinghouse / Tappan / Gibson
Oven Fault Codes
Display Condition Remedy
F0 & F1 EOC failure Replace EOC
F2 Oven over heat Defective Sensor or EOC
F3 Oven Sensor Open Replace Sensor
F4 Shorted wire or Sensor locate short and correct it
F5 EOC failure Replace EOC
F6 EOC failure Replace EOC
F7 EOC failure Replace EOC
May 17, 2009 | Frigidaire 30 in. Electric Gallery Series...
F8 / Convection portion of top oven doesn't work
F8 Oven door lock failure Check lock relay and door switches.
Apr 02, 2009 | Frigidaire 27 in. Electric Gallery Pro...
Oven heating element
Hello rvready
Welcome,
You said, We have an OLD (1950-60) Frigidaire wall oven, model # RBG-94. Bottom heating element has gone out. Oven is still in good shape so we'd like to be able to find an element replacement, but have had no luck finding one.
unfortunately,
I am not able to find this part either.
Anywhere. This oven is to old for parts. But most important is that it is causing you high utility rates!
Today's appliances save you the arm and the leg that such an old oven is costing you.
You have no idea how it is sucking your money out of your pocket!
It is unfortunate, that no one told you about this years ago!
You payed for more than one oven with your utility bill if you had it since it was new. My advice is do not put good money into bad!
Shop for a new one and see your bills go down.
my wife was telling me to replace the air and furnace for 7 years and I said, it's not broken. But it was over 20 years old. She was right, cause the new one saved me $100. a month!
That means I threw away $7000. in 6 years with my old world attitude.
Yes I am old fashion and always fix it!
But after 25 years of marriage. i finally realized she is a good evaluator and I was a fool to not appreciate her gift for all these years! And out tons more money than I told you about!
Hope I saved you some bucks with my real life stories!
Don't tell your wife!!!
Huuum
Oct 17, 2008 | Ovens
Frigidaire self cleaning convection range
Error code F1
1. Shorted keypad.
2. Control's internal checksum may have become corrupted.
3. Control has sensed a potential runaway oven condition. Control
may have shorted relay, RTD sensor probe may have gone bad.
1. Disconnect power, wait 30 seconds and reapply power. If fault returns
upon power-up, replace EOC.
2. Check RTD sensor probe and replace if necessary. If oven is
overheating, disconnect power. If oven continues to overheat when
the power is reapplied, replace EOC. Severe overheating may require
the entire oven to be replaced, should damage be extensive.
3. Replace EOC.
Check resistance at room temperature, if less than 500 ohms, replace
Temperature (°F) Resistance (ohms)
32 ± 1.9 1000 ± 4.0
75 ± 2.5 1091 ± 5.3
250 ± 4.4 1453 ± 8.9
350 ± 5.4 1654 ± 10.8
450 ± 6.9 1852 ± 13.5
550 ± 8.2 2047 ± 15.8
650 ± 9.6 2237 ± 18.5
900 ± 13.6 2697 ± 24.4
Hope it helps please let me know
Jun 11, 2008 | Frigidaire Ovens
Ovens Logo
20 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
