Question about ASUS Computers & Internet
Eject button stuck
I have an ASUS computer and the eject button on the optical drive is pushed too far in and will not work. I there a way that I fix the button?
  • ASUS Master
  • 8,073 Answers
Near the eject button (on the same face as the eject button) there should be a pin hole. Use a straigtened paper clip to force the ejection of a stuck disk. It may also work even without a disk stuck. ( I just tried it on the drive of the laptop.)
Posted on Oct 14, 2013
5 Suggested Answers
  • 476 Answers
SOURCE: Couldn't eject DVD from the slot-in drive
From memory its a bugger of a mission ,
Easier to take to a Service Technican unless you are able to do this type of repair,
It will require a lot of paiteince and skill to strip down and reassemble this just to get to the disk.
Give it to the PROS only if you want it to work again,
Sorry but thats the truth,
Hope this helps ,Please rate me thanks
Posted on Jul 31, 2008
RescueTechLA
  • 2653 Answers
SOURCE: cd stuck inside laptop
There is a small hole, usually near the eject button. Unbend a paper clip and carefully push the paper clip into the hole, try to keep it straight. drive should pop right out.
Posted on Feb 20, 2009
  • 114 Answers
SOURCE: A cd is stuck in my Dell Studio 15 laptop
Hello there,
find a very little hole infront and get a pin about 3-4 inches long and stick it there the CD drive should open, it will be a little hard but push it and it will open.
Posted on Mar 31, 2009
  • 243 Answers
SOURCE: My Dell laptop won't eject a disk from the disk
You can eject from my computer open it right click cd drive and select eject.
Posted on Dec 30, 2009
How do I insert CD in computer? It doesn"t seem to have an open slot.
If there is no "Open" button for the drive then normally they are opened by pushing on the DVD/CD tray itself momentarily. It only needs a short positive push and the drive tray should slide out.
Dec 28, 2014 | Acer Aspire Computers & Internet
Cant open cdrom
I'm pretty sure that model of laptop doesn't have a CD-ROM, or any optical media drive, could be your problem.
If you have an external one connected, there should be a button on the external device, alternatively open "My Computer" and right click on the optical drive and select "Eject" to eject the tray.
Hope this helps.
Dec 07, 2013 | ASUS Eee 4G Notebook
CD stuck in Asus desktop optical drive
On the CDrom drive, there is a small hole near the button to open the drive. Insert the tip of a straightened paper clip into the hole and press gently. The drive should open to allow you to remove the disk that is stuck.
Mar 30, 2012 | ASUS Computers & Internet
Disc Drive
If the eject button is not working, assuming this is a Windows based computer, click on start icon, your start menu will display, on right side under your user icon you should see Computer or My Computer, click on it.
You will now see all drives in your computer. Right click on your dvd(optical) drive. You should see an eject option.
If this dosen't work, close to the eject button on the drive is a tiny hole that will accept a paper clip, carefully push clip into hole until drive ejects.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
Feb 13, 2012 | HP Computers & Internet
My CD is stuck in my Toshiba Satellite A505D laptop slot, with no hole near the Eject button.
Look on the cover on the tray near the eject button. Should be a tiny hole.
Get something like a straightened out paperclip and insert it in to the hole and push firmly but carefuly. It's an emergency eject for a stuck tray.
Feb 07, 2012 | Computers & Internet
Dvd is stuck in my ACER laptop how can I get it out
The Acer 5610 has an emergency eject hole to the right of the eject button on the right side of the computer. Find a paperclip and unfold it (or small allan wrench), push the end of the paper clip into the hole until you feel pressure. Press firmly and the optical disc tray should come slightly out of the machine. Grab and pull the tray out (gently). This should work even without power to the drive on any machine tray optical drive, if the tray mechanism is undamaged.
For a slot-loading optical drive, it's a bit trickier. You can try sliding another object into the slot and using it to pry or lift the stuck disc. The safest option is to use another optical disc or credit card sized item and double-sided sticky tape. Put a piece of the tape on the item and then remove the paper from the other side of the sticky tape. Slide the item into the drive with the sticky tape towards the stuck disc (down for most computers). Once far enough into the drive, lower your item and press the tape firmly onto the stuck disc. Lift up and try to pull the stuck disc up and out of the drive.
I hope this helps.
Oct 26, 2011 | Acer Aspire 5610 Notebook
Loaded a cd to upgrade firmware, firmware would not load. eject button would not eject. read manual, says to push eject at the same time you plug in the electric cord,still would not eject. Any...
Please try in this way.
Disconnect power.
Connect power back, and keep REPEATEDLY pressing the eject button while you connect. If still no ject press power on button while you keep hitting the ehect button. You need to press eject on the unit, do not use the remote.
If that does not work, then the unit must be taken apart.
Dec 09, 2010 | Cameras
Optical Drive Door Stuck!
get a pin and push it through the pin hole by the eject button
Jan 08, 2010 | HP Compaq Presario CQ60Z Notebook
Phillips DVD+RW burner on Dell computer won't eject
You will find a small hole on the face of the drive. This is the manual eject mechanism. Insert any wire-like object (a properly sized size paper clip works real well) and push until the disk ejects.
Note: Many times the mechanism is recessed quite far behind the face plate, so make sure the object you use is long enough (again, paper clip).
"Today's the best day of my life...and NOW you're part of it!"
Dec 13, 2008 | Philips CDD 4801 CD-RW Burner
CD/DVD burner tray won't open- unresponsive
the door may be stucked due to dust in door gears.
Nov 24, 2008 | Micro Advantage Computers & Internet
Computers & Internet Logo
99 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
