Question about Whirlpool ACE244XS Air Conditioner
I have a whirlpool wall heat/ac unit, model ACE184XL0. All of a sudden, the heat quit working. Fan still blows, and AC still seems to work, although I can't tell if it's just pulling in cold outside air or actually cooling the air. How do I know if it's the heating element or the thermostat? Thank you!
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 53 Answers
Dear it is a thermostat system. You can simply check it by setting temp at 30 then check either warm air is coming or cool air. at this time warm air should come. If warm air is not coming means there is a fault is realy in your pcb. It can be simply remove no need to worry.
Posted on Oct 15, 2013
4 Suggested Answers
koolbreezes
  • 540 Answers
SOURCE: Whirlpool Heat and Air Window Unit ACE184XRO- freezing up
This is only low freon. If the bottom coils freezes and frost over, you don't have enough freon to travel as liquid back to the compressor and boils right there and past this only cool gas .I'll advise you to get this fixed before you loose a compressor due to locking up by not cooling the compressor properly. Get in touch with an Ac man. this should only cost around $100:00
Posted on Sep 05, 2008
SOURCE: Whirlpool portable AC, compressor works, but no exhaust fan
This is a single speed permanent split capacitor motor for the condenser. One of the capacitor wires shows infinite resistance to hot and netral. The motor needs to be replaced.
Posted on Mar 31, 2009
  • 16 Answers
SOURCE: window ac unit is not blowing cold air
When the unit is running, go outside and put your hand near the condenser fins, this air that comes out should be slightly warmer than the ambient temp. If it is not you will need to take the unit out of the window and out of its outer case and clean the condenser fins from the inside, this is no easy task as it is very hard to reach. You will want to get a small (toothbrushed sized) brass bristled brush with a long handle. Make sure the evaporator coil (in the front) recieves the same attention and wash the mesh filter that goes in front of the evaporator. Re- assemble and enjoy the cold air.
Posted on Jun 07, 2009
Unit not working correctly. The unit worked for the winter, few days ago I turn on the AC and noticed that it wasn't cooling like it should.
It's could be the board or a heat relay. See if you have 24 volts on "x2" im assuming, emergency heat when in cool mode if so it's the board. Or unhook black or x2 or your emergency heat from board and run unit in cool. If heat stays on its a relay
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Jun 02, 2016 | Heating & Cooling
Problem with Fujitsu minisplit heating
did you try to set to maximum heat? (suspect the thermostat is defective)
Oct 03, 2015 | Fujitsu AOU24RLXFZ Dual, Tri and Quad Zone...
Problem with GE PTAC-Model# AZ28E09DABM2 - Why won't condenser kick on when switching to AC from Fan. AC was working fine until today...Fan is still working...Pulled the unit out and could feel the h
Hummm. A bit difficult to solve this problem. Seems like the condenser outside is not working, I mean the fan of the condenser. Looks like you have a wall A/C and a wall A/C always have condensers outside the house and near the A/C. Have you checked if the fan is spinning? I don't think the compressor is at fault but check it anyway. You should be able to hear the compressor running either in the wall unit or in the outside condenser housing. The only heat you should feel is from the condenser itself. If you blows warm air, that means the fan is working, if not that means the fan is not working. But don't be confused with the fan not working because in winter time sometimes the fan is not working and some times it does. As I said, it's a difficult problem to solve but at least start with checking the situation with the fan in the condenser.
Jun 16, 2014 | GE Zoneline Deluxe Series Cooling &...
Ac started chripping then fan quit
Sounds like fan bearing gone. New fan?
Jul 04, 2012 | Whirlpool ACQ189XM Air Conditioner
A/C and heat just suddenly quit working
It is most likely the fan motor's internal brushes have worn out. Either you will have to replace the magnetic brushes, or replace the motor all together. There is a tube and wire harness that will have to be removed. Than there is 3 or 4 bolts that hold motor to firewall.
May 23, 2009 | 1989 Toyota Camry
Heat doesn't work on ac
You need to check if the heat strip is still good on it or that it is receiving power. If its getting power, then the strip is bad.
Apr 01, 2009 | Fedders AEY18F7G Y Chassis Heat/Cool Room...
Whirlpool ACE244XS Air Conditioner Logo
223 people viewed this question
Top Whirlpool Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Whirlpool Heating and Cooling Expert? Answer questions, earn points and help others
