Question about Dishwashers
Zulauf/ablauf light is on and the dishwasher stop working
Dishwasher Asko 1986 suddenly stopped working
Also is mainly a control board's
Did you have a power outage or power surge?
Need model
Oct 08, 2016 | Asko Dishwashers
Nimmt kein Wasser vom Zulauf
Bitte fragen Sie noch mal unter Washing Machines
Nov 27, 2013 | Washing Machines
On my miele dishwasher i have a red light that warn you that Zu -/Ablauf
A usual problem that causes this problem is that the the rotor of the motor of the pressure pump sometimes stucks so it's capacitor doesn't have enough strength to start it.Its not a serious problem and you can fix it comparatively easily.
1.Make sure that you drain the water that might be still inside.
2.Remove the two hoses and the power plug and place the washer somewhere more convenient.
3.As you face it,till it and lay it on its right side.
4. Use a screw driver to unscrew the four bolts that hold the left cover and then unscrew another four of it's bottom that are placed next to its legs.
5.The pump motor is placed down and back in its left side so now you must have it in front of you.
6. There are some black hoses connected on it.Use pliers to remove them and also a bolt on the back of the dishwasher that holds the motor of its back center.
7. Now you must be able to tilt the motor( you don't have to remove it completely ) towards you in order to make accessible it's back side.
8.Put the screwdriver in its back and try to rotate the rotor with it and unstuck it. It needs minimum strength.
9.Repeat the steps backwards.
Will work with no problem.Usualy this problem appears after a long period of time of no use.
Good luck :)
Aug 13, 2010 | Miele 24 in. Incognito G863 SCVi Built-In...
Problems with Whirlpool dishwasher model GU1500XTKB0
have they checked the thernals on the bottom of the tub
Mar 14, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Problem in dish washer
DAER SIR ,
THIS IS MANITOWOC EC50A MODEL ICE CUBE MACHINE.SIR, MACHINE WORKING AFTER 1hr MACHINE WATER FLOW IS LOW ,
AT THIS TIME SOLENOID VALVE NOT ON POSSITION PLEASE REPLY FOR A PERFECT SOLUTION
BY
JOTTIN FRANCIS
KERALA
Dec 04, 2007 | Miele Dishwashers
Water not heating up
check for thermal cut outs, there could be up to 3 located around depending on the make etc, all have different places, 1 normally under the base of the drum lining, 1 on a water pipe below the drum lining, maybe 1 inside the door skin, also there could be a broken wire inside the door skin just above the hinge, the wires get hot, dry out and snap with wear and tear while opening the door, hope i have helped
Sep 29, 2007 | Dishwashers
Dishwashers Logo
Top Dishwashers Experts
Owen Barnes
