Question about Proview HV-147 14 in. EDTV-Ready LCD Television
Password for v chip - Proview HV-147 14 in. EDTV-Ready LCD Television
How do i reset parental control when we have forgotten password
You should be able to find it in your TV's manual.
If you lost your manual, here are some possible options:
  • Try pressing the recall button 5 times quickly within 30 seconds.
  • Hold the Volume button down and push the Number 1. Then go to the V-chip button and enter there your new password.
  • MENU button, press SET +/- button to select V-CHIP SET, press ENTER button. Enter password using channel selection. Enter same password confirmation, ENTER Press SET +/- button to select V-CHIP
  • First press menu button then select set or v-chip set obtain then press the enter button then enter the password in four digits. v-chip password will set then we using the direct channe
Your TV model would help a lot, but I hope you find your manual or one of these work.
Mar 02, 2011 | Televison & Video
Tip
Reset Bose LifeStyle 48 VChip Password
Bypass or Reset Bose LifeStyle 48 System V-Chip Password Lock
Would you like to bypass, defeat or reset your Bose LifeStyle 48 System Parental V-Chip parental lock? Have you forgotten your V-Chip passcode or password?
If you forget your V-Chip passcode, you can view the locked signal without entering your password.
When your passcode is requested, enter the temporary code 2673. This process temporarily unlocks your system, and you can reset or change the password.
I hope that helps.
_______________________________________
Bose LifeStyle 48 Manual Download
Bose LifeStyle 48 Video Mode
on May 02, 2010 | Bose Lifestyle 48 System
Tip
Reset Bose LifeStyle 38 VChip Password
Bypass or Reset Bose LifeStyle 38 System V-Chip Password Lock
Would you like to bypass, defeat or reset your Bose LifeStyle 38 System Parental V-Chip parental lock? Have you forgotten your V-Chip passcode or password?
I hope that helps.
Bose LifeStyle 38 Manual Download
Bose LifeStyle 38 Video Mode
on May 02, 2010 | Bose Lifestyle 38 System
I have an Akai PT5492S television that I don't know the v-chip password to and need to reset the v-chip password.
SETTING V-CHIP
This TV is fitted with a V-CHIP controller which provides you with channel viewing access controls
and restrictions. This function is to prevent your children from watching violence or sexual scenes
that you may choose to exclude.
Press the MENU button and press the SET + or – button to select the V-CHIP SET option,
then press the ENTER button.
Enter your password (4 digits) using the Direct channel selection buttons (0-9).
In the event of entering incorrect password press the RESET button. Then press the
ENTER button.
Enter the same password for confirmation, then press the ENTER button.
Press the SET + or – button to select the V-CHIP option.
Press the ENTER button to select the ON.
Press the SET + or – button to select the TV RATING or MOVIE RATING option. Press
the ENTER button.
Press the SET + or – button to select the desired rating for the applicable video or TV
channel. Press the ENTER button.
And to change or put in a new password:
NOTES:
• If you want to change password, follow steps 1 and 2 and select "CHANGE PASSWORD"
option then enter your new password.
• The V-Chip function is activated only on programs and tapes that have the rating signal.
• Once you block a program using the V-Chip function, the blocked program cannot be watched
based on the content of the show. When the program starts, the "INPUT PASSWORD" will
appear on the screen. When you want to release the V-Chip temporarily, enter the password.
If you change the channel or turn off the TV while the V-Chip function was temporarily released,
the original setting will be resumed. If you return to the channel you were watching you must
re-enter your password to temporarily release your V-Chip function again.
• When you watch the TV from the cable box or the VCR with the RF Modulator, then you release
the V-Chip temporarily, the V-Chip setting will not be resumed until you turn off the TV. The
TV channel is not used in this case.
• When changing the channel with the cable box or the VCR, approximately 10 seconds will
pass until the program appears.
Feb 13, 2010 | Akai PT5492S 54" Rear Projection...
The v chip locks up how do we remove this if dont have code for good on hd 1080 is there a code change to remove the original
SETTING V-CHIP
ENTER button.
the ENTER button.
NOTES:
Hope this helps.
Jan 21, 2010 | Mitsubishi WS-55807 TV
Tip
I hope that helps.
on May 02, 2010 | Televison & Video
Tip
I hope that helps.
Bios info on hard drive
The BIOS password is not stored in the hard drive.
Try Dell as the password first.
The BIOS password could be stored in the BIOS chip or an an EEPROM chip.
If the password is stored in the BIOS chip, you can restore the BIOS back to the default setting and remove the password by removing the BIOS battery for 1/2 + hour, insert the battery and go into the BIOS configuration to set the Date & Time.
If the password is stored on the EEPROM chip, there are no backdoor passwords available.
May 03, 2009 | Dell Latitude D620 Laptop (Latitude-C620)...
V-chip or parental control
SETTING V-CHIP
ENTER button.
the ENTER button.
NOTES:
End of manual text.
try this thx nick
Feb 07, 2008 | Curtis-Mathis CM32010 TV
Forgotten v chip password
hi i have a vivid 106 cm plasma sold by aldis in australia i am now in portugal and canot change the country in the tv to get Digital tv
Aug 15, 2007 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Proview HV-147 14 in. EDTV-Ready LCD Television Logo
16 people viewed this question
Top Proview Televison & Video Experts
Steven Wander
Steven Wander
joncin91
Level 1 Expert
Are you a Proview Televison and Video Expert? Answer questions, earn points and help others
