Question about Electric Mobility Rascal Scooters, Turnabout/Stowaway, Mini base scooter 130 Wheelchair Battery
I could really use a manual for my Rascal 130. Is there one left out there?
Does the owners manual have a wiring diagram in it for the rascal 230 electric scootetr
Hi marilyn, Sadly no mobility scooter manual will give you such information, i willing to help , what do you want to know ? faulty lights , thinking of fitting a new controller ?
Regards
Rob
Feb 15, 2016 | Electric Health & Beauty
Rascal 230 wiring diagram
Check the multi pin connector on tiller and where it connects under the seat between the batteries. Most common problem.
Oct 09, 2014 | Electric Mobility Rascal Scooter...
Does anyone have arepair manual for a rascal 300 I need to fix the electromagnetic brake
It is the same as a Rascal 600 only the 300 has smaller wheels.
The manual is not much help on the brake, it does not go into repairing the bake, except for checking voltages and replacing the microswitch, some tips are a little oil on the detent balls help to keep it free and movable, but don't get oil on the brake pad.
Scooter Doctor App
Aug 27, 2014 | Rascal 300 Electric Scooter - Used...
I have a Rascal 200..was working fine..now after you go forward and let go of the throttle. ..it goes in reverse itself. .is there a throttle adjustment?
I had a similar problem on my Pride Legend scooter, it would
creep back in reverse if you let go of the throttle. The FWD/REV spring tensioned throttle pot inside was "off center"causing it to activate in reverse when it should have stayed put with the electric brake energized.
I had to replace the throttle pot assembly. Not sure if yours
is similar, but I would suspect it might be.
Jul 29, 2014 | Electric Mobility Rascal Scooters,...
Rascal scooter
Could have a wiring issue you should look in the console make sure nothing is crossed.
Jul 21, 2014 | Electric Mobility Rascal Scooters,...
Rascal 600T Scooter FIX IT Manual
There is an owners manual available which has a troubleshooting guide at the following: http://manuals.monsterscooterparts.com/mobility/Rascal/manual-rascal-600-t.pdf
If you have a good relationship with a local dealer they may be able to copy and provide you with one.
Electric Mobility, the manufacturer, in my experience will not provide one to you.
Mar 02, 2014 | Electric Mobility 3 Wheel Motorized...
Sometimes my electric mobility scooter acts as though it's dead - but, the batteries are fully charged and the horn will work. Other times, it acts perfectly normal. The downside is, it's left
okay now this is most likely a loose connection
does the rear axle come away from the main frame ? if so check the connectors there clean gently,,,,
Now check the battery connections does the battery pack come away from the scooter if so again check the connections here , clean and make sure connections are good.
Regards
Jan 12, 2013 | Electric Mobility Rascal Scooters,...
Could use a workshop manual for Rascal Taxi 4. Several queries re battery
HI
YOU CAN GET A USERS MANUAL, NOT A WORKSHOP MANUAL FOR YOUR RASCAL BY CALLING 1-800-MOBILITY OR GO TO ELECTRIC MOBILITY.COM
GOOD LUCK
TIM
Apr 27, 2011 | Health & Beauty
I have a 245 Rascal Scooter. I need to know if I can lower the seat?
most rascal 235 and 245 scooters come equiped with power seat height control. you turn the key to the left and then the throttle lever becomes the seat height controller. the seat motor is ditectly uuder front of seat post. if it will not run follow wires to see that they are plugged up good.
Jun 09, 2010 | Golden Technologies Golden CompanioN II -...
Electric Mobility Rascal Scooters, Turnabout/Stowaway, Mini base scooter 130 Wheelchair Battery Logo
109 people viewed this question
Top Electric Mobility Health & Beauty Experts
Robin Hill
Robin Hill
Colin Taylor
wcdoc1953
wcdoc1953
Are you an Electric Mobility Health and Beauty Expert? Answer questions, earn points and help others
