Question about Apple IMAC A1208 desktop Used
When I cut it said insert bootdisk pess any key but want read it an want come on no farther than that what is it
  • Apple Master
  • 15,734 Answers
The error that you are talking about means that the hard drive has failed.
Posted on Oct 14, 2013
The key lock wont turn
One of the tumbler blades has been pushed out farther than normal due to the cut of the wrong key. WD40 the lock inserting the tube into it. Put in the correct key and jiggle it while trying to turn key back and forth. Repeat as necessary. If after multiple attempts don't work (be patient) then tap the outside of the lock where you insert the key with a block if wood or small hammer. The vibration is what will allow the tumbler blade to slip back into place.
Mar 20, 2015 | 2006 Ford Escape XLT
No bootable device acer aspire 5250
This error message means that the computer is not seeing the hard drive or there is no operating system on the hard drive. In the bios does the computer see the hard drive? The unit may have to have the hard drive replaced.
Nov 05, 2012 | Acer Aspire 5250-Bz873 Amd Dual Core C-50...
How 2 create bootable floppy
OPEN COMPUTER IN DOS MODE MAY BE BE BY ANY BOOTABLE 98 CD, INSERT BLANK FLOPY DISK >TYPE C: AND ENTER >TYPE SYS A:\ AND ENTER
OR IN WINDOWS XP http://www.bleepingcomputer.com/tutorials/tutorial108.html
http://www.bootdisk.com/
http://www.optimizingpc.com/install/bootdisk.html
HOPE T WILL HELP YOU
Nov 30, 2010 | Intel D845GVSR Motherboard
How to install xp in lenovo g550, its cant able
fist go bios & give boot from cd RAM save it exit from there insert XP CD it will ask you press any key ,just pess it then it will start coping fails & drivers after that XP will install ok
Mar 08, 2010 | Lenovo G550-29583AU Notebook
UPDATING BIOS... DISK BOOT FAILURE INSERT SYSTEM DISK
This happens because the boot process fails: either because in the boot order the floppy isn't mentioned (put it first) or the bootdisk isn't good.
BTW you should update the BIOS only if you have problems, like a new processor not being recognized.
Dec 11, 2009 | Foxconn WinFast K7S741MG Motherboard for...
Installation of XP hung up and will not complete - system down
Well it sounds like you have a dirty cd or a bad cd.
Turn the cd upside down and look at it usually when you get the hang it means that the eye stopped moving from either somthing on the cd so clean the cd then try.
If it still doesn't work then see if there is a deep scratch on the cd.
But my bet would be is the cd needs to be cleaned
Dec 23, 2008 | IBM ThinkPad 600E 2645 Notebook
My screen has rotated by 90 degrees.
try this pess Ctrl+shift    and pess one of the arrow keys..... see what happens and then post
it might also be  shift+ctrl or ctrl + alt
dont remeber the exact   but try and post the results pls
Nov 30, 2008 | Computers & Internet
Installation
For that you will have to have the installation cd of windows xp
insert it in the cd- drive  and then meke the laptop boot from the cd  (either you will have a boot menu by pessing 'f12'  or del   or enter the bios settings and then change it )
after that follow the steps given on the page  please do read the instruction  before pressing any key
you will have to format a drive of your system so   caryy forward only  after taking  the backup
hope this  helps
if you have any other questions pls  post back
Nov 26, 2008 | Compaq Presario Notebook
SPICELOUNGE UNMOUNTABLE_BOOT_VOLUME
I have the same computer except it is the 2400 Dimension. If you have a win 98 bootdisk which is a lot smaller file and easier to use insert in a:/ startup with cdrom support when its done loading it goes to a:/. When thats done your cdrom drive has been changed to E:/ if you have your XP install disk put it in your cdrom. Ok beside where it says a:/ type in e:/ which changes it to e:/ drive when thats done type in setup and it should start your install there should be a choice to repair at some point click on that and it should repair. If by chance that don't work let me know and we will do something different.You can get a 98 bootdisk at http://www.bootdisk.com/bootdisk.htm just follow instructions how to make the disk.
Let me know
God Bless Greg
Nov 24, 2008 | Computers & Internet
Apple IMAC A1208 desktop Used Logo
21 people viewed this question
Top Apple Computers & Internet Experts
paulcarew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
