Question about Lowrance LMS-330C GPS Receiver
Note on Screen: GPS not responding. I have checked the transducer - it looks OK. Ann
I can't see the picture on my navman fishfinder looks like pixcels are gone on the screen. Is there any way of fixing this
Have you checked the transducer for damage, or the wire to it. Also check the connection on the unit itself. On my Humminbird there is a Demo Mode. See if yours has one? If Demo Mode works, then it is the transducer.
Here is the contact page of the company.
http://www.navmanmarine.net/navman-marine-support.html
Support and FAQ
Apr 15, 2016 | Navman GPS
Garmin 551s sonar stopped working, no bottom definition or ability to see fish GPS charts and speed all work It shows 3 step image repeats top of the screen / water surface has the transducer packed
Check you transducer cable route and connections. Look for kinks, punctures, & tears in cable. Visually check the transducer for damage. #2 check the units operation on a friends boat with the same set or research a local marine repair shop to check ops. Best of luck on the problem.
Jan 11, 2016 | Garmin Boating
Gps problem
If the new harness / parts are listed for use with this model GPS, it should work - unless you have miswired something. Double-check your work. Make sure all connections are made up tight. Pay particular attention to the ground wire. Relying on the boat to pass ground it not reliable. Look for damaged or cut cable from power source and transducer. You may wish to troubleshoot with a meter or a test light to be sure power is available at the GPS. Good luck!
May 29, 2013 | Humminbird 1198C SI Side Imaging High...
My Garmin depth finder/gps combo is giving me a false depth reading,like way way outta sack,not a foot or two. It came as an extra on a boat I purchased and elsewise seems ok,just inaccurate depth. Is it...
YOUR TRANSDUCER MAY BE SET FOR HORIZONTAL MODE...MEANING FROM BANK TO BOAT, NOT DEPTH...CHECK THE TRANSDUCER TO MAKE SURE, IT IS AIMING DOWN, NOT OUT...OTHERWISE YOU'LL NEED TO CHECK YOUR MODE SETTINGS IN YOUR MENU.
YOU CAN ALSO DO A TEST ON YOUR TRANSDUCER, BY SCREWING IT ONTO A BROOM STICK ...ADJUST THE TRANSDUCER DOWN, CHECK YOUR SETTINGS ON THE SCREEN, THEN DO A SIDE TEST WITH THE TRANSDUCER TILTED SIDEWAYS TOWARDS THE BANK AND CHECK YOUR SCREEN!
THEY CAN BE TRICKY...AND ARE VERY SENSITIVE, BUT ONCE YOU FIGURE OUT, HOW YOU WANT TO USE IT, YOU'LL LOVE IT!
HOPE THIS HELPS!
Sep 03, 2011 | Garmin GPS
Good day, I just bought a transducer (R209) for my 1920 C furuno display but seem to have a probleem with the setup on the display. I have no radar connected to the system and to do the installation...
If you just have the transducer and no network sounder youre pretty much dead in the water. along with your transducer, you will need either a BBFF1 or DFF1 sounder. Since they operate on a network they will have to be configured depending on your setup.
Oct 07, 2010 | Furuno NavNet vx2 1920C GPS Receiver
A65 Transducer
jmiller,
Sound like your getting turbulence from the hull or your angle is allowing cavitation under the transducer. Look under the hull where the traducer is mounted and look for a part that has no obstruction including saltwater pickups, hull relieves, etc. The other thing to check is to take a strait edge on the bottom of the transducer to ensure the angle is slightly forward than the hull.
Bob
Sep 11, 2008 | Raymarine A65 Combo GPS...
Rl70c raymarine depth finder problem
fish finder transducer needs to be on before you boot your system. check your hsb cables and termination
Jul 12, 2008 | Raymarine RL70CRC GPS Receiver
Transducer not connected
my 947 c says transducer not connected
Jun 14, 2008 | Humminbird 947C GPS Receiver
Transducer
I have the exact same problem. Were you able to solve your problem???
May 12, 2008 | Garmin GPSMAP 3210 GPS Receiver
Installing an old used lowrance fish finder
I don't think your old fish finder is the LMS-332C GPS Receiver listed above in the description. You don't need the speed wheel for the fish finder to function just the transducer and transducer mount. You should mount that on the back of the boat towards the center but not too close to the motor and not too close to the side of the board. Don't let it hand below the level of the boat. That should keep it from getting hit by the trailer or dragging on the bottom. Try to make it as level as possible. The green and white wires may be for the speed wheel but i'd need a model number for clarification. Hope this helps.
Apr 26, 2008 | Lowrance LMS-332C GPS Receiver
Lowrance LMS-330C GPS Receiver Logo
21 people viewed this question
Top Lowrance GPS Experts
Andrew Taylor
Andrew Taylor
Are you a Lowrance GPS Expert? Answer questions, earn points and help others
