Question about GE Spacemaker JVM1640SJ Microwave Oven
Can you please tell me the wattage on a 1995 GE Spacemaker microwave oven Model JVM240wv? Ser# is FM924649s....thanks..
  • GE Master
  • 9,098 Answers
The owner's manual (here) says on the front page that it is a 850W model.
If you need repair, see this link for more tips, or for a "drop-in" replacement, see GE support.
Posted on Oct 17, 2013
  • 4 Answers
SOURCE: Removal of GE Spacemaker Microwave oven
1. Unplug the microwave. The plug is probably in a receptacle that is in the cabinet above the microwave, or in the wall above the shelf that is above the microwave.
2. Remove the two (or three) screws that go straight down through the bottom of the cabinet, or the shelf, into the top of the microwave. Have help in holding the microwave when you do this, as the front of the microwave will be able to fall down when the screws are removed.
3. Allow the front of the microwave to rotate down a little, then lift the back of the unit up about 1/2" to 1". At this point, the microwave will be disconnected from the mounting plate on the wall, so you can move it forward and carry it away.
Posted on Nov 29, 2007
  • 96 Answers
SOURCE: ge spacemaker microwave jvm/1650
Mmmm it's so easy,
First disconect the power, take the cover off, moslitly there would be 5 screws and two tab's on the top.
inside on the right hand side the magnetron it's a sylver box measuring about 4 in x 4 in x 5 in. It will have a plasic cover moslitly that would have to be remove first then on the magnetron there is 4 crews and one connector.
It should fall downard after.
If you have a power supply after the secondary , that may also be your problem.
Regards
Bob
Posted on Jan 22, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Disassembly of GE JVM1460 microwave oven door to clean
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 10, 2008
vitg55
  • 78 Answers
SOURCE: My Ge SpaceMaker XL1800 Microwave Oven won't power on any more.
1.Check power outlet for working.
2.If it is than you have broken fuse inside the m/w.
3. To change the fuse you have to disconnect the power to m/w, take the upper grill off, take the screw on top of control panel, lift the control panel up and removed. The 20 Am fuse located behind this panel.
Posted on Dec 15, 2008
bestdarngood
  • 3037 Answers
SOURCE: run but does not heats
Sounds like the magnetron has failed. This is the component that produces the microwaves that heats the food. The cost of the magnetron is about 95% of the cost of a microwave oven. Most people don't, for this reason, replace the magnetron, they replace the whole oven which is probably what you will end up doing. There is a possibility that the circuit that provides power to the magnetron is faulty and you need to take it apart, find the proper electrical leads and test them with a volt meter. To do this you have to remove it from its mounting and take it apart. It is a fairly lengthy process however. Benjamin
Posted on Jun 07, 2009
What is the wattage output of my GE Spacemaker Microwave model JVM1850SH02
The JVM1850SH microwave has a maximum power output of 1100W.
I hope this helps.
(The final two digits are not critical for the microwave's specifications.)
Mar 06, 2015 | GE Microwave Ovens
Can ou please tell me wha the wattage is on a 1995 GE pscesaver Mirowave Model #JVM240wv and ser# of FM924649S?
Oct 14, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
GE Microwave JES1244wa 001
Look in the manual that came with it or look on line at the make and model and that should help you.
Jan 02, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
I need a bulb for my JVM1631WB002 SPACEMAKER MICROWAVE what are the specs on the bulb ? Wattage ? Where can I purchase ? Thanks
most grocery stores have them , if you look where they have light bulbs, this one will say for microwaves only on it, easy to change them good luck cost about $3.79
Jul 27, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
I am looking for the wattage of a ge spacemaker microwave model #JVM1640WJ03
According to the GE quick specs sheet, this is a 1000-watt oven, 1.6 cu. ft. capacity. You can also download the manual here if you need a copy.
Jan 31, 2011 | General Electric Microwave Oven
What is the wattage on my microwave JES1451 please . I need the answer in order to cook something tonight. Thanks Can'[t find answer in my owners manual--may have overlooked it.
that model sahould be betewwn 900 and 1000
depending on the age they changed it about 3 mosinto produvction
aif you bought it after 98 its 1000 watts
hope this helps
Oct 24, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Model of 1989 GE Spacemaker
The model number should be on a tag as shown in the drawing below.
Feb 06, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
What is the wattage of the spacemaker microwave oven model JVM1540DM2WW manufactured in September 2007.
Look on the oven interior for the product information label or the specifications of thr owner's manual. Look for the OUTPUT wattage. No luck? try this service agency, they may be of help.
Call Toll Free to Speak to a Live Operator
1-866-336-8987
May 22, 2008 | GE Microwave Ovens
GE Spacemaker JVM1640SJ Microwave Oven Logo
116 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
