Question about Hotpoint Washing Machines
Iput the mcahine at 8 and 40 degree and 1300 spin but it kept washing and didnt spin
The water from the tub will not flush
turn washing machine on and use pump cycle or spin cycle if does not work check filter and pump for blockage
Dec 02, 2016 | Washing Machines
60 degree wash wont spin
Would it not take time to heat up water to 60 degree temp before it starts to spin ?
May 03, 2014 | Zanussi Washing Machines
Neptune Front Load, Error Code, dc What does this mean?
The machine failed to reach a spin speed of at least 400 revolutions per minute (RPM) due to unbalanced load or motor related problem. Turn off the machine and redistribute the load properly. Add more load if the load is too small for the machine to spin but do not overload it. Let me know if the error code does not clear out for further troubleshooting and repair assistance. It will help if you can elaborate and provide more details about the problem including the exact model number of the mcahine.
Jan 25, 2010 | Maytag MAH8700A Front Load Washer
Our Kenmore Model 110 - 82980120, Stock 29801, 118 G is giving a problem with the Automatic Process. It does not move by itself. It stays at the same place it is kept. If Kept at Wash it stays there, if...
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Jan 21, 2010 | Kenmore Washing Machines
Washer will not drain on spin
We ended up opening up the washer and checking the pump and guess what , there was a tiny drill bit stuck in it that stopped it from spinning and working. Thank god we didnt burn out the pump.
Nov 11, 2008 | Frigidaire CWS3600AS Top Load Washer
LG front load washer spinsense buttom does not come on
I have the LG WM3988HWA, which is a washer and dryer in one. The way it works on ours is that you press and hold the Spinsense button for 3 seconds before you start a wash, or while a wash is paused. When Spinsense is on, the LCD will say "Spinsense" on the right-hand side when the machine is running. Nothing happens with the light on the Spinsense button.
Spinsense makes a huge difference as the machine is on the second floor of our old wooden house. I don't even notice the spin cycle with Spinsense on.
Problems:
1. We need to turn it on for every load. This is just annoying.
2. Spinsense will not turn on when you've the Dryer option activated. This means we have to do two trips to the machine for each load, or have our house feel like it's shaking to pieces. There's no good reason that the Spinsense/Dryer shouldn't work.
Jun 24, 2008 | LG WM-1832C Front Load Washer
Hoover washer dryer saver 1300
I have inherited a hoover saver 1300 in new flat, the dials have worn away and it goes onto drying mode after wash, how can i have it on wash and spin only - NO DRYING? Thanks
Apr 12, 2008 | Hoover H120M Front Load Washer / Dryer
Washing machine trouble
i need more info but can help front loader top loader brand etc
Dec 30, 2007 | Washing Machines
Washing Machines Logo
16 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
