Question about Acer AL1916W 19" LCD Monitor
All plugged in monitor sys no signal and toer jusy beeps any suggestions
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 72 Answers
Check all ur coonection...hold power buttom for 2 min...and then restart pc...should solve the problem....
Posted on Oct 22, 2013
Sys fan nor cpu fan working and black screen
Try a known , good working PS. If that does not do it, you have serious mo bo issues.
Mar 27, 2017 | ASUS PTGD1-LA Motherboard
I am currently on my laptop because when I turn on my desktop, the monitor (ViewSonic VX2235wm) powers on with a message that says No Signal Digital and then turns off. Any suggestions?
hi; your monitor has no problem, its your cpu. Try to hook your monitor to your laptop,and change the display setting to your LCD monitor. If LCD has displaying no signal mean signal coming form the Video card of your CPU try to visualize if you hearing some beeps into from CPU, some motherboard has beep codes if there's an error or failure to your CPU, 1 beep means its good system test. if you don't hear any beeps, try to check first your Video Card marmeto12_21.jpg if you have Spare try to replace it, try to reset all the connectors even Memory card to its slot. reset means pull the connectors and place it back again, also check the power supply of cpu if still functioning good.but you can test it by multi volt meter. if nothing happens check your motherboard most common failure is bloating capacitor, and overheating chipset. thanks....................hope this helps...................
Sep 07, 2011 | ViewSonic VX2235wm LCD Monitor
My apple macbook won't start and continuously keeps on giving a beep sound.
the beep pre-boot is signaling a kernel panic. It could be bad ram or something else, it's hard to tell without hearing the beep (they signify different things)
1 beep = no RAM installed
2 beeps = incompatible RAM types
3 beeps = no good banks
4 beeps = no good boot images in the boot ROM (and/or bad sys config block)
5 beeps = processor is not usable
taken from http://www.welovemacs.com/whdoallthbme.html
So depending on the beep, it means different things. However in any case I'd suggest taking it to an Apple Authorized Repair Facility. Unless you feel comfortable with assessing the proper solution on your own
Good Luck.
Feb 17, 2011 | Apple MacBook 13"White /2.0Ghz Intel Core2...
My acer 19" monitor has no signal what should i do?
  1. check whether the signal cable properly connected to the vga port or not ?
2.listen the single beep from PC
3.try monitor on another PC . if persists , then the fault lies in the monitor . if not then the fault is in the CPU
thank you.
4.if no beep from CPU then disconnect RAM . listen contineus beep . if heard , then the RAM is faulty , replace it .
Jul 23, 2010 | Acer AL1916W 19" LCD Monitor
Monitor says NO signal...can hear the computer boot up and make its' welcome to windows noise, but the montior goes into standby after saying NO signal
you must make sure that the VGA cable to the computer is properly fitted to the sys unit. if problem persist pls add a VGA card to your sys unit to solve your problem rate solution Afterwards
Jan 04, 2010 | Gateway FPD1530 15" Flat Panel LCD Monitor
Using Non-Dell monitor on Dell system
Have you tried the monitor on another PC, have you checked the cables, or tried another monitor cable, AND Look inside both place the monitor plug goes and look for BENT PINS or broken PINS, not every hole may have a corresponding pin but thats OK, look for bent or broken pins, If those soutions dont work repost error code beeps, and I or someone will help more.
Thanks for the fixya rating, everyone helps me..have a blessed day
Apr 08, 2009 | Computers & Internet
When I boot my PC up I get a blank screen and a message saying no signal then the screen goes into standby mode
OK, it's gonna be one of these 3 things :
1. The cable linking your CPU to your monitor might not be properly plugged or has been damaged. You should hence ensure that the connection between the two devices has been properly done and that the cable’s state is fine.
2. You might be facing a problem with your monitor if the CPU makes a single beep error sound when you switch on the system. You can check whether the problem comes from your monitor by testing it on another CPU. If you still have “No Signal” error displayed including the error beep, I would strongly suggest you to try to get your monitor fixed by a competent technician or to get a new monitor.
3. If you receive several error beeps when starting the computer, this might be linked to a graphic card dysfunction. You can refer to the motherboard notice or check that the connection has been properly set
Dec 12, 2008 | Computers & Internet
HI no startup beep on my emachine and no signal onscreen
Get a new Hard Drive and plug it into your USB Port
Jul 05, 2008 | E-Machines eMachines Desktop PC
Acer AL1916W 19" LCD Monitor Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
