Question about Koblenz Model SP-15 Accelerator- Rectangular 20X14 Orbiting Pad, 1.5 HP motor, 3500 RPM Floor Machine square scrub Discount Shipping
Koblenz square scrub breaker popping when using
My koblenz u40 commercial upright vacuum will not power on please help
Start by making sure the vacuum is getting power. Check the cord and switch, if they are good check the motor.
Jan 10, 2017 | Koblenz Vacuums
Application
Use siemens for old ITE breaker box.
Square D will not work:
http://waterheatertimer.org/See-inside-main-breaker-box.html
Add a comment and describe product, and attach photos.
May 26, 2013 | Square D Co. HOM130C Circuit Breaker
I have a Square D QO panel. I am trying to install a couple of 2 pole thin line breakers. I bought 2 QOT2020 breakers at Home Depot and they will not fit. I am aware of Square D's Homeline series...
im going off memerory right now but i seem to recall that you may only be able to instal that breaker in the lower part of the panel maybe check to see if the buss bar is a little short to acomadate the 2 pole breakers i will check it out in the am sorry if im mistaken
Jul 23, 2011 | Square QO 30 Amp Double Pole Circuit...
I have a square d breaker box. Cat. No. QOC30CF Series SO1. Can you use mini breakers in this box? If mini breakers are possible, how many can you safely use in a box?
You should be able to find this website useful in finding Mini Breakers for your Square D Panel . ( http://ecatalog.squared.com/alphabetical_listing.cfm ) And remember , you can put as many breakers in as the panel can hold . BUT >>> you cannot overload the panel for that which the busbars service was intended . Another words , if you have a panel rated at 200Amp , then at FLA's you can not supercede that rating .
Feb 08, 2011 | Hammering
I have a trilliant square D breaker box and I need to change a breaker in it. My electrician told me that once I had everything shut off and disconnected that it should pop right out but I can't get the...
if it's a bolt-on you will see the bolts on the outside of it. if it's a plug-in, sometimes they can be tricky to remove. you wanna pull out towards the inside of the breaker then slide the breaker towards the center and it will pop out then. definately don't need a special tool.
Nov 04, 2010 | Square D Trilliant 100 Amp Circuit Breaker...
I need to down load a parts manual for a Koblenz Tp2015 floor machine.
Ouch! My head hurts searching this one out but here you go.
http://www.koblenz-electric.com/manuals/LP-FL-200609.pdf
Feb 26, 2009 | Koblenz Floor Polisher Model TP-2015
Koblenz P2600 manual
Here you go this link will pull it right up. I recommend printing it immediately or saving to your computer since I found it through a backdoor search. Seem they don't want everyone to have a manual.
http://www.koblenz-electric.com/manuals/LP-P1800-200611.pdf
Feb 23, 2009 | Koblenz Tools & Hardware - Others
Arc fault trips under load
Arc fault breakers are definitely a pain. First make sure the receptacles are made for a 20 amp circuit. Second vacuums, Curlers,and most appliances will trip your breaker since they create an arc or a short if you will to operate. That is exactly what these breakers are made for. To stop the arc. Apparently they never really thought the whole arc fault thing through. As per code in most of arizona you only need this breaker in bedrooms where this type of appliance is not used. They also are more prone to popping so make sure you aren't running something on each of the receptacles at the same time
Dec 18, 2008 | Siemens 20Amp 1-pole arc-fault circuit...
Koblenz Model SP-15 Accelerator- Rectangular 20X14 Orbiting Pad, 1.5 HP motor, 3500 RPM Floor Machine square scrub Discount Shipping Logo
Top Koblenz Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Koblenz Tool and Hardware - Other Expert? Answer questions, earn points and help others
