Question about Sony VAIO VGC-RA710G PC Desktop
Optical Drive does not opent
I have two optical drives and one does not open. If I push the eject button it tries to and make a few sounds but nothing happens. Any suggestions?
  • 44 Answers
If you had a CD in it, the CD may have wedged itself such that the tray cannot be extended. If it was empty, you may have a gear that is no longer making contact with the tray. I would remove it from the computer and look at taking the cover off the drive to see if the tray's path is obstructed.
Posted on Sep 25, 2007
How do I insert CD in computer? It doesn"t seem to have an open slot.
If there is no "Open" button for the drive then normally they are opened by pushing on the DVD/CD tray itself momentarily. It only needs a short positive push and the drive tray should slide out.
Dec 28, 2014 | Acer Aspire Computers & Internet
Samsung Optical Drive SE-208 tray rattling won't eject
if you look on the drawer you will see a little hole.push a pin in the hole and the drawer will open.
Nov 15, 2012 | Samsung Optical Drive SE-208AB/TSBS...
My CD is stuck in my Toshiba Satellite A505D laptop slot, with no hole near the Eject button.
Look on the cover on the tray near the eject button. Should be a tiny hole.
Get something like a straightened out paperclip and insert it in to the hole and push firmly but carefuly. It's an emergency eject for a stuck tray.
Feb 07, 2012 | Computers & Internet
We have a Polaroid 15 inch LCD television with a built-in dvd player. It also allows for jumpdrive connection. I must be missing something but we cannot figure out how to play a dvd. I put a dvd...
Do you have the Polaroid 1513-TDXB? I assume you have tried the eject button on the side of the TV (the lowest button next to the DVD slot). There are a few things that can cause a DVD to jam and not be recognized by the drive: put in the disc label side to the back of the TV, home disc with a glued on label (if the label comes loose), two discs in the slot or non-standard optical discs.
Some slot optical drives have a manual eject hole on one side of the slot; it should be near the top of the slot on this unit. Straighten a paperclip and try pushing on the release mechanism inside that hole. (A small paperclip is the correct size.) Sometimes pushing the optical disc with a second optical disc will bump it loose (be careful you do not want the disc to be dragged into the drive). Another possible solution is to pry the disc up off the spindle with a credit card. (Note: trying this could damage the disc and the drive.) A similar card with double sided sticky tape can sometimes lift the disc off the spindle. Stick the tape on the card, then peel the paper off the other side of the tape. Insert the card to be on the top of the disc (sticky side towards the back of the TV) and press it down on the disc. Lift up slightly and pull the card and optical disc out.
If the disc has partially ejected, two credit cards (one above and one below) can grab it. Turning the TV on its side so that the optical drive is pointing to the ground can also work.
There are a few things to check once you get the disc out. Were there scratches or other problems that would keep the drive from seeing the disc? Other optical drive issues are dirt on the lens and the tracking unit failing on the drive. Blowing the dirt out of the drive may help. Otherwise, it needs to be fixed or replaced which means getting it out of the TV.
The manual for the TV is available at this review site: . The direct link to the manual is .
I hope this helps.
Jun 09, 2011 | Televison & Video
How do iget the bloody door open tp insert disc
Mac OS 9.2
  • Press the Eject key on Apple Pro Keyboard
  • To open the second optical drive on a Power Mac G4 (Mirrored Drive Doors) computer, press Option-Eject on the Apple Pro Keyboard.
  • Open the Eject application found in the Eject Extras folder. The Eject Extras folder is located in the Apple Extras folder on the CD.
  • Click the iTunes eject button (see Figure 1).
  • Hold down the mouse button when you hear the startup sound as the computer restarts.
  • Start up from Mac OS X and customize the toolbar with an eject button.
Mac OS X
  • In the Finder, Choose View > Customize Toolbar. In the window that appears, drag the Eject button to the toolbar, then click Done. Select the disc you want to eject in the Finder window, then click the Eject button in the toolbar.
  • Press the Eject key on the Apple Pro Keyboard.
  • If you have a keyboard without an eject key, press F12 (under Mac OS X 10.1 and later). Note: You must press the F12 key longer to prevent the tray from accidentally opening.
  • Click the eject button in iTunes (illustrated in Figure 1).
  • Start up from Mac OS 9.2 and follow the options in the section above.
Aug 18, 2010 | Apple eMac G4 Desktop
Optical Drive Door Stuck!
get a pin and push it through the pin hole by the eject button
Jan 08, 2010 | HP Compaq Presario CQ60Z Notebook
The dvd rom quit ejecting. It clicks and a light flashes and nothing else...won't come out. I tried the little hole with a paper clip. nothing. How do I access it from the bottom.
If the optical drive is not ejecting with the emergency eject button ,it probably a bad optical drive. The repair manual is given on the link below
Go to the option that says >removal and replacement procedures>optical drives
Thanks for using fixya
Nov 12, 2009 | HP Pavilion Ze4900 Notebook
My cd drive will not open or operate
You might have a bad drive,have you tried removing the drive and re-inserting it? You can get replacement drives on ebay or you can also look at they sometimes have them cheap.
Sep 26, 2009 | Dell Latitude D600 Notebook
CD/DVD burner tray won't open- unresponsive
the door may be stucked due to dust in door gears.
Nov 24, 2008 | Micro Advantage Computers & Internet
Sony VAIO VGC-RA710G PC Desktop Logo
62 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
