Question about Kitchen Ranges
Can not read Control panel output. Do I have to replace it or can it be repaired?
    Top Expert:
  • Kitchen Ranges Master
  • 9,472 Answers
What is the model number?
Posted on Oct 16, 2013
How to remove side panels on a whirlpool Gold double oven, in order to remove control panel. I would like to reconnect the control panel, it may reset the panel to work again
Hello Ms Jackson,
An E6-F2 is a very common control board failure. The control board in your appliance will need to be repaired or replaced.
Read more below about common Whirlpool oven Fault codes and what they mean. FixYourboard.com can repair this issue quickly and economically. We also back our workmanship with an industry leading two year warranty. http://blog.fixyourboard.com/2015/08/20/gbd-rbd-whirlpool-oven-problems-causes-and-solutions/
I've also attached a link on how to remove your Whirlpool oven control board How to Remove Whirlpool Oven Control Board
Feb 10, 2017 | Whirlpool Ovens
The variable screen control of the flyback is smoking
Replace the LOT with the same number. There is no repair to it. Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts.
Apr 29, 2014 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
I have Whirlpool RBS305PDB16.The bottom broiler element will not heat up only the top.Any ideas on the problem?
the broil element
is the heating element that is found at the top of the oven and produces a very high heat for broiling. If the broil element isn't working, you should first do a visual inspection for signs that the element has blistered or separated. If the element appears normal then you can check for continuity with a multi-meter. Remove power from the appliance before performing this test. Remove the back panel and locate the terminals for the broil element and inspect the terminals and wires for signs of overheating or damage.
If there is no continuity then the element will need to be replaced. If the wires are damaged then they will need to be repaired. If the element is ok then you will need to check the broil circuit to determine the cause. This involves live voltage checks and should only be performed by qualified persons. Components to check include fuses, if the range is equipped, and oven control thermostat or electronic control. Depending on the manufacturer of the element, you will normally read between 19 ohms and 115 ohms
Most modern ovens use an electronic control board
to control the oven functions. These models will use the control board to operate the oven safety valve on a gas range or oven, and the bake and broil elements on an electric range or oven. If there is no power to the igniter circuit, or the element circuits, then you should check the control board to verify that there is power at the appropriate output relay. These are live voltage checks and should be performed by qualified persons only. If there is no output voltage then the control should be replaced.
http://www.partselect.com/Repair/Range-Stove-Oven/Will-Not-Start
Nov 16, 2012 | Whirlpool RBS305PD Electric Single Oven
Error codeE6 F2
Remove the power from the oven. Open the control panel and unplug the key pad ribbon from the control board. Assemble the control panel back and turn the power on. Wait a few hours.
If the error code came back on, replace the control board.
If the error code did not show up, replace the control panel (the key pad comes as a control panel assembly).
- The part number for the new control board AP3595759
- The part number for the black/stainless control panel AP3131755
Good luck.
Gene. __________________Hi I did some research for your oven and this is what i found , someone with the same problem , control board needs to be replaced , if you click on the web page below it will explain it to you , good luck Frank
Read more: http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/1094-whirlpool-fault-code-e6-f2.html#ixzz1gYuqvZnV
Dec 14, 2011 | Whirlpool RBD275PR Electric Double Oven
How to fix open or shorted relay circuit 3-4 shift solenoid relay condition on 2000 jeep cherokee
Check this TSB...
Set Condition: This code is set if the voltage detected on the 3-4 Shift Solenoid Control
Circuit at the PCM is difference than the expected voltage.
POSSIBLE CAUSES
FUSED B(+) FEED TO TRANS CONTROL RELAY OPEN
TRANS CONTROL RELAY
3-4 SOLENOID CONTROL CIRCUIT OPEN
3-4 SOLENOID WIRING HARNESS INTERMITTENT
SHIFT SOLENOID CONTROL CIRCUIT SHORT TO GROUND
SOLENOID AND HARNESS (SOLENOID CONTROL CKT)
SOLENOID AND HARNESS (SOLENOID PACK CONN)
TRANS RELAY OUTPUT CIRCUIT OPEN
TRANS RELAY OUTPUT CIRCUIT SHORTED TO GROUND
PCM (3-4 SOL CONTROL CKT)
PCM (CODE SET)
POWERTRAIN CONTROL MODULE
TEST ACTION APPLICABILITY
1 Key On.
With the DRB, read trouble codes.
Is the Trans 12 volt Supply Relay Control Circuit code set?
All
Yes - Refer to symptom P-1765 TRANS 12 VOLT SUPPLY RELAY CONTROL CIRCUIT in the TRANSMISSION category.
No - Go To 2
2 Key On.
Is the DTC Specific Good Trip displayed and equal to zero?
All
Yes - Go To 3
No - Go To 17
555 TRANSMISSION
3 The code is present at this time.
Key On.
Check and record Freeze Frame data to determine the conditions when the code was set before disconnecting the PCM Connectors.
Note: Freeze Frame data will be erased.
Road test Vehicle. Attain Vehicle speed of at least 50 MPH.
Push OD Switch 4 times such that Vehicle attempts to shift from 3rd to 4th and back.
Did the Vehicle shift between 3rd and 4th?
All
Yes - Go To 17
No - Go To 4
4 Key Off.
Disconnect the Trans Solenoid Pack Connector.
Note: Check connectors - Clean/repair as necessary.
Turn Key On.
With the DRB, actuate Trans Control Relay.
Using a Voltmeter, measure the voltage at the Trans Relay Output Circuit.
Does the voltage fluctuate from 0.0 volt to over 10.0 volts?
All
Yes - Go To 5
No - Go To 13
5 Key Off.
Disconnect the Powertrain Control Module White Connector.
Key On.
Using a voltmeter, measure the voltage at the 3-4 Shift Solenoid Control Circuit.
Is the voltage above 10.0 volts?
All
Yes - Go To 6
No - Go To 7
6 Key Off.
Repair 3-4 Solenoid Control Circuit shorted to voltage.
Reconnect all disconnected Connectors.
Push OD Switch 4 times such that Vehicle attempts to shift from 4th to 3rd and back.
All
Yes - Test Complete.
Perform Powertrain Verification Test VER-5A.
No - Replace the PCM.Perform Powertrain Verification Test VER-5A.
7 Key Off.
Using a Ohmmeter, measure the resistance between the 3-4 Shift Solenoid Control
Circuit at the PCM Connector and Ground (B-).
Is the resistance below 5.0 ohms?
All
Yes - Go To 8
No - Go To 9
556 TRANSMISSION
8 Key Off.
Using an Ohmmeter, measure the resistance between the 3-4 Shift Solenoid Control
Circuit at the PCM Connector and Ground.
All
Yes - Repair the 3-4 Shift Solenoid Control Circuit shorted to ground.
No - Replace the Solenoid and Harness Assembly.
9 Key Off.
Remove the Trans Control Relay.
Using an Ohmmeter measure between the Trans Control Relay Output Circuit at the
Relay and the 3-4 Solenoid Control Circuit at the PCM Connector.
Is the resistance above 40.0 ohms?
All
Yes - Go To 10
No - Go To 12
10 Key Off.
Using an Ohmmeter, measure the 3-4 Solenoid Control Circuit from the PCM
Connector to the Solenoid Connector.
All
Yes - Go To 11
No - Repair the open 3-4 Solenoid Control Circuit.
11 If there are no potential causes remaining.
View repair options.
All
Repair
12 Key Off.
Using a Ohmmeter measure between the Trans Control Relay Output Circuit at the
Is the resistance between 26.0 and 40.0 ohms?
All
Yes - Replace the PCM.
557 TRANSMISSION
13 Key Off.
Key On.
Using a Voltmeter, measure the Fused B(+) Circuit in the Relay Connector.
Is voltage above 10.0 volts?
All
Yes - Go To 14
No - Repair the open Fused B(+) Feed to the Trans Control Relay.
14 Key Off.
Using a Ohmmeter, measure the Trans Control Relay Output Circuit from the Relay
Is the resistance above 5.0 ohms?
All
Yes - Repair the open Trans Relay Output Circuit.
No - Go To 15
15 Key Off.
Using a Ohmmeter, measure between the Trans Control Relay Output Circuit and Ground.
All
Yes - Repair the Trans Relay Output Circuit shorted to ground.
No - Go To 16
16 If there are no potential causes remaining.
All
Repair
Replace the Trans Control Relay.
17 Key On.
Check and record freeze frame data to determine the conditions when the code was set.
Erase the DTC.
Warning: This will erase the Freeze Frame data.
Attempt duplication of Freeze Frame Data to help reset the code.
Key Off.
Using the Schematic as a guide, inspect the Wiring and Connectors.
Were any problems found?
All
Yes Repair as necessary.
No Go To 18
558 TRANSMISSION
18 Key On.
Note: Actuate the 3-4 Solenoid or the test can be done with the Engine running.
Wiggle the Wiring Harness from the Solenoid to the PCM.
Note: You are attempting to set the code.
With the DRB, read DTC's.
Does the 3-4 Solenoid Control Circuit Trouble Code appear?
All
Yes - Repair as necessary.
No - Test Complete.
559
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Dec 02, 2011 | 2000 Jeep Grand Cherokee
After reseting the circuit braker the smoker did not come back on
Hi and welcome to FixYa, I am Kelly
Most likely the heater has failed.
The manual for the 20070106 is on this page:
http://www.masterbuilt.com/manuals.aspx
The element kit is PN: 9907090033 (Est. $45.00)
My thoughts are the element has shorted out. Before ordering read out the element with an ohm meter. Read each terminal to ground with the at least one wire disconnected. Then read the element end to end. You should read resistance end to end but NOT end to chassis.
That is just for the element. You said it did not come back on after resetting the CB. If the display is blank the control panel has failed: Contact Masterbuilt at 1.800.489.1581 (<-Only source)
MASTERBUILT Customer Service at 1-800-489-1581.
Control panel PN: 990050048 Digital Control Panel Kit
Something has caused the control panel to fail... if there is a chassis short some where in the unit you can have a brand new control panel fail. Inspect the wiring and components for signs of damage BEFORE replacing the control panel. Repair any wire damage found. Thee are only 2 components that use electricity; the control panel and the heater. Finding a wiring problem should be simple.
Thanks for choosing FixYa,
Kelly
Jul 24, 2011 | Masterbuilt 20070106 Electric Smoker
LG42PC3D TV - No remote control. Manual control works.
dont blame the receiver yet, the problem mostly comes from the remote control. it may be the infrared emiting problem. checkout if the infrared in the remote control is emited well. to see this infrared you can read the article at http://www.unique-stuff.co.cc/fixing_remote_control_check_infrared.html
good luck
Dec 05, 2009 | LG 42PC3D 42 in. Plasma Television
The control panel went dark. Can only read it
Not sure on the make but it appears that the timer clock display is failing. Replacement cost is typically £80 but without the make i cannot give you a accurate costing. Fitting would be extra.
Regards
Aardvark Repairs
Nov 16, 2009 | GE Profile JTP56 Electric Double Oven
Lightning Strike - Master Temp 250
I have dealt with similarly damaged boards, I can testify that while they can be repaired, the cost of labor is the most significant factor and some parts may be tough to get. I would have never undertaken it but the company which manufactured the control board (this was a sophisticated electric security gate) couldn't ship us the board in the time we could afford to wait so I repaired it. Once. The second time lightning hit it, I replaced the board and ordered the installation of a 'whole house' surge arrester.
Aug 29, 2009 | Pentair Mastertemp Pool & Spa Heater Dual...
Vizio vw42l, the vizio light turns from ornage to
Does LCD screen backlight come on? If so proceed....
USE:CAUTION WHEN DOING THIS....
Try this if repairing yourself...find power supply, small board with no cover over it...check voltages on output pins/plug/connectors (white plugs) three in a row...
1 Plug has 24Volt supply..1 has 12Volt supply and 1 has 5Volt supply when read to ground (screw that holds board in) if you have these voltages it's a safe bet it's the main control board...I just replaced mine and it fixed a problem like yours.
Jul 10, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
