Question about Frigidaire FDF70S Dehumidifier
Worked just fine using a drain hose but now it will not drain thru the hose but fills the bucket....The hose is not clogged as I have blown air thru it.
  • 252 Answers
SOURCE: dehumidifier not draining
hose/fitting is clogged - blow it out with your mouth or what ever - it won't be a hard clog
Posted on May 28, 2009
SOURCE: Problem with draining water through hose
I bought one of the FDL70S1 Frigidaire dehumidifiers today for my shop, and found that the $5 hose I bought to drain it through the floor wouldn't tighten down completely, allowing the hose to twist and wobble, a sure indication that it was not water tight. Simply adding a second washer, as described in another answer here, allowed me to tighten the hose sufficiently to produce a tight fit with no play between the hose and the dehumidifier. It hasn't leaked. I know it is a threads-per-inch issue, and I am stumped as to why Frigidaire would supply these units with a different thread pitch than the standard GHT (garden hose thread) 3/4" - 11.5 tpi. The threads on the unit appear to be 3/4 NPS - 14 tpi. Go figure!
Posted on Aug 06, 2009
  • 288 Answers
SOURCE: Attached a pump to drain collected water. The
the water should still collect into the tank. the dehumidifier had a float switch that shut the unit off when the tank is full. In turn it should have a second switch, probably a float switch that turns the pump on and off so that the pump doesnt continue to run when there is no moisture in the tank
Posted on Nov 27, 2009
  • 37 Answers
SOURCE: 50 pint dehumidifier has drain hose connected but
safety switch is turning off the dehumidifier....you need to drain out the bucket more often....or put the drain hose into an actual drain....ive seen some people run a small plastic hose from the dehumidifier to the sump pump hole in their basement.
Posted on Jan 27, 2010
woodchuck789
  • 4070 Answers
SOURCE: hose not draining, bucket only fills
The easiest way to unstop the hose is to blow air through the end enough to clear the clumped up dust at the other end using air compressor or air pump.
Posted on Jul 12, 2010
How to get direct drain option to actually work on my Edgestar DEP700EW dehumidifier?
The outlet is probably clogged with moss or foriegn bodies. Clear the water way.
Sep 11, 2014 | EdgeStar 70 Pint Portable Energy Star...
MDL11-40AEN3. When connecting hose to unit for continuous drain, will not drain through hose (fills up bucket and shuts off). I've called Midea and they told me to tilt unit. That doesn't help
Dennis, the problem you're having is caused by either the drain hose being clogged or the drain hose connection and tubing being clogged. When this occurs, water is diverted to the bucket.
Turn the unit OFF & unplug it.
Remove the hose and check it for for clogs. You can do this visually or by blowing thru it. If you find nothing there, it's the connection and/or interior tubing that is clogged.
Using an appropriately sized, 18" long, plastic Zip Tie, carefully insert the tip of Zip Tie into the connection hole & tubing. Continue to push it in until you reach a bend in the tubing. You will need to gingerly work the Zip Tie past this bend, until it either bottoms out or you run out of usable Zip Tie. Then slowly pull the Zip Tie back out while rotating (twisting) it. This will breakup any clogs. As you reach the inserted end of the Zip Tie, be prepared, as some water may follow. Reconnect the hose, plug the unit in and turn the Master ON/OFF Switch to ON. Set the humidity extraction level to 35% or Maximum if you have a manually controlled unit. Allow the unit to run, while you monitor the hose for water flow. Be sure the drain hose is not kinked and is sloped down from the unit. In addition, the hose length on most dehumidifiers should not exceed 48".
NOTE: If you don't have a Zip Tie, you may use something similar ( i.e.A long pipe cleaner), but NO wire coat hangers
I hope this helps you solve the problem. Please let me know and thanks for choosing FixYa.
Aug 11, 2011 | Dehumidifiers
Continuous drain hose stopped working...worked fine until a couple of weeks ago
Paul, this is usually caused by 2 things: The attached hose is clogged or the hose drain connection and tubing are clogged. Before attempting any service work on the unit. Turn the Master ON/OFF Switch to OFF & Unplug the unit:
The first one is easy to solve, by removing the hose, looking thru it or blowing thru it.
The second requires a little more work:
Remove the water collection bucket and look up inside the bucket holder cavity. You will see either a drain hole or small tubing that drains the water into the bucket. Using an appropriately sized, 18" long, plastic Zip Tie, carefully insert the tip of Zip Tie into the hole or tubing. Continue to push it in until you reach a bend in the tubing. You will need to gingerly work the Zip Tie past this bend, until it either bottoms out or you run out of usable Zip Tie. Then slowly pull the Zip Tie back out while rotating (twisting) it. This will breakup any clogs. As you reach the inserted end of the Zip Tie, be prepared, as some water may follow. Reinstall the bucket, plug the unit in and turn the Master ON/OFF Switch to ON. Set the humidity extraction level to 35% or Maximum if you have a manually controlled unit. Allow the unit to run, while you monitor it for any leakage.
NOTE: If you don't have a Zip Tie, you may use something similar ( i.e.a long pipe cleaner), but NO wire coat hangers.
Hope this helped you to further troubleshoot and solve the problem. Please let me know. Thanks.
Jul 08, 2011 | Soleus DP14003 Dehumidifier
I have attached a hose and the bucket continues to fill - this has only started in the last two weeks - last year and prior to two weeks ago, it was draining well
From what you have described, either the hose is clogged or the hose connection tubing inside the unit is clogged.
The hose is easy to solve. Just, disconnect it and either blow thru it or look thru it.
If the clog is not in the hose, it's in the hose connection tubing of the unit. To solve this do the following:
1. Turn the Master ON/OFF Switch to OFF & Unplug the unit.
2. Using an 18" long, plastic Zip Tie or something similar (NO wire coat hangers, though) that is appropriately sized to fit in to the hose connection tubing .. Carefully insert the Zip Tie and continue to push it in, until you reach a bend in the tubing. You must gingerly work the Zip Tie past this bend, until it either bottoms put or you run out of usable Zip Tie. Now, slowly remove it while rotating (twisting) the Zip Tie. This will dislodge any clogs. As you reach the inserted end of the Zip Tie, be prepared for some water to follow.
To avoid clogs in the future, clean the air intake filter regularly. At least once every two weeks.
Hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
Jun 29, 2011 | Whirlpool 25-Pint Dehumidifier
Hose not draining, bucket only fills
Jul 12, 2010 | Frigidaire FDF70S Dehumidifier
LG 65EL water not dripping to bucket
THE DRAIN LINE IS CLOGGED TAKE OFF THE HOSE FROM THE UNIT AND BLOW AIR BACK THRU THE UNIT,, IT IS NOT UNDER A PUMP SYSTEM IT IS GRAVITY, IF IT WON'T DRAIN IT'S CLOGGED
May 29, 2009 | LG LD65EL Dehumidifier
Dehumidifier not draining
May 28, 2009 | Frigidaire FDL60P1 Dehumidifier
I have an amana dehumidifier. I have a drain hose hooked to it but it just filled the bucket... it drained fine last year
Check to see if you have a clog in the drain hose from the mold and algae that builds up.
Apr 26, 2009 | Amana Dehumidifiers
Frigidaire FDF70S Dehumidifier Logo
54 people viewed this question
Top Frigidaire Dehumidifiers Experts
Charles T Nevin
Charles T Nevin
Oloyede Monsuru
richie46
Are you a Frigidaire Dehumidifier Expert? Answer questions, earn points and help others
