Question about Dell V313w AllInOne InkJet Printer
How do I set the printer for "Quick print" or "draft mode"?
  • 22 Answers
The easiest way is to do this from Windows. Open the Devices and Printers and select Printer Properties for the printer you want to make the change on. Select "Prefernces..." and change to the desired quality.
As an option, add the printer a 2nd time and have one as Draft mode and the other at maximum quality. That way you can just select a printer to get the quality you want.
Posted on Oct 15, 2013
How do I set my printer to automatically print in draft mode and just black ink without having to manually select these options each time I print?
Sir are you doing it in the control panel setting? Go to control panel and set you defaults. Doing it there will do it for all programs on your computer.
Dec 27, 2014 | HP ENVY 5530 E-ALL-IN-ONE PRINTER 1200X600...
Wow Pamela! You ask your question well. Good Job! Print options such as that can not be set at the printer. Changing the settings inside the application is not permanent. Follow HPs instructions here for default settings:
Changing Print Settings in Windows7
How to use draft mode in epson lx_300+ii printe
Change the printer's default settings.
Hold down the Font button and switch the printer on. The printer will print language setting
instructions.
Press the font button again and the printer will print instructions for changing from default settings
Follow the instructions to change draft mode on/off.
Jun 08, 2011 | Epson LX-300+ II Matrix Printer
We have printing of pdf files in multiple,nere by 1 lakh pages within 2-3 days but now printer is printing 250-300 pages in one hour. how to increase the speed of printing ? email id ---...
Change the printer's print settings to print in draft mode.
Draft mode is a low quality, but highest speed print mode.
  1. In Windows, click on the Start button and choose Control Panel.
  2. Choose Printers and Other Hardware from the menu that opens.
  3. Choose View Installed Printers or Fax Printers.
  4. On the window that opens, look for your printer's name. Right click on the printer's icon and choose Printing Preferences.
  5. On the Print Quality tab, choose Draft or Fast (varies depending on the printer).
Mar 05, 2011 | Office Equipment & Supplies
I print labels with my Microline 320 Turbo. I put a new ribbon in and the labels are so wet and bold and after sitting for awhile they bleed until you can't read them. I have the lever on the print head...
This results from theway the print head is striking the paper. If you have it set to NLQ. it will be heavy, you can set it to a draft mode or SSD:
Print the Menu Settings, to see what your settings are:
Printing the settings is the only way to have a record of
the settings.
1 Make sure paper is loaded in the printer.
2 Enter the Menu Mode (SHIFT + SEL).
3 Press PRINT (PARK key).
Print Quality
! Important!
Front panel settings for print quality and character
pitch are overridden by software commands.
The lights will always reflect the printer's state.
Press PRINT QUALITY to select:
NLQ: Near Letter Quality
• Highest quality, slowest speed
• Courier or Gothic fonts
• Recommended for correspondence
UTL: Utility
• Medium quality, medium speed
• Gothic font only
• Recommended for internal documents and high-volume
data.
HSD: High Speed Draft
• Lower quality, faster speed
• Gothic font only
• Recommended for drafts.
SSD: Super Speed Draft
• Lowest quality (12 cpi only), fastest speed
• Gothic font only
• Recommended for fastest output of drafts.
Super Speed Draft
To use Super Speed Draft (SSD), enter the Menu Mode and
make changes as follows:
1 Press SHIFT + SEL.
2 Press GROUP twice.
3 Press SET until DRAFT prints as the setting for the Print
Mode.
4 Press ITEM.
5 Press SET (SSD prints).
6 Press SHIFT + SEL to exit Menu Mode and save your
changes.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 01, 2011 | OKI MICROLINE 320 Turbo Matrix Printer
Can not find a way to print in draft mode so toner
Laser printer can sometimes be set via the front panel on the printer for draft mode. Also, you might be able to set Draft Mode from the printer properties menu in the print driver.
The actual easiest way is change your font to something like Courier, 10P, which is a fixed spaced font.
When the document is finished, then you can do a "Ctrl A" and change the font to a more fancy font.
Don
Feb 18, 2010 | HP LaserJet 3600n Printer
How do you set this printer into draft mode? (HP officejet J4580)
Go to Start->Control Panel->Printers and faxes. Then right click on your printer and choose printing preferences. There you will find a setting for quality and set it to draft (or fast draft).
Regards,
nicolasiac
Feb 12, 2010 | HP OfficeJet J4580 All-In-One Laser...
How do I get draft mode (to save ink) when printing on my Pixma iP4200?
goto the printer & faxses
select the printer
from their select the properties
or printing prefrence for printing mode
change the setting to draft mode
ok bye..............
Nov 10, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
Draft mode?
start->control panel->printers and faxes->right click on lexmark E232->properties->advanced->printing defaults->print quality->draft->OK->OK.
Jan 12, 2008 | Lexmark E232 Laser Printer
How do you print in draft quality Canon Pixma MP 180
go to your setup or print options box. go to color management page. should be a print setup box showing draft, regular print, dpi etc. check the draft print mode.
Sep 11, 2007 | Canon PIXMA MP180 All-In-One InkJet...
Dell V313w AllInOne InkJet Printer Logo
64 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
