Question about American Standard Home
Bidet keeps running
The cold water faucet on our bidet keeps running - even when the water shut off valve at the base of the bidet is turned off. I'd like to fix it myself, and started taking the handle off, but didn't know how to proceed from there.
    Scholar:
  • 64 Answers
If you've tried turning off both shutoffs underneath and water still runs, then the shutoffs are also likely worn out and need to be replaced. If there is no way to shut off from that point, then the only other option is to have somebody turn off all water in the house near your water meter or main water line. In many places, hardware stores will sell something called a "water shutoff key", but depending on your location, it may have a different local name.
Once water is off to the whole house, turn the hot water on somewhere in the house to reduce pressure from your water heater before replacing your faucet and shutoff valves.
It is a good idea to take one of your old water shutoffs with you to a hardware store to make sure the new one would fit propperly.
If you know somebody who can take apart the faucets to check and replace just the washers, then it could be fixed with even less expense, if you would not rather replace the faucet with a new one that will last longer.
Posted on Oct 14, 2013
3 Suggested Answers
  • 74 Answers
SOURCE: no water pressure on Pegasus kitchen single handle faucet
Those new faucets generally have a lower water pressure due to legislation passed in 2007 that reduced that maximum allowable gpm (gallons per minute). I hate to tell anyone this but there is little if anything you can do. First of all, make sure the shut-off valves are open completely. I know that sounds elementary but I've seen it a bunch of times.
Also check to see if the aerator is blocked with a bit of debris.....unlikely if the flow is uniform but still an easy fix.
Hope I didn't break your spirit too much....
Posted on Apr 28, 2009
  • 297 Answers
SOURCE: when i turn faucet handle no water. I feels like
inside the handle there is plastic stops,this has broken. you must replace the handle
Posted on Jul 15, 2009
Will I still have water running to the water heater if I shut off the bypass valve?
Bypass valve is to bypass the water heater. No bypass valve and always water in tank. Put a bypass valve and shut it up it is like no bypass valve.Open the bypass and shut up the input (cold water) and output hot water) no running water in heater tank but still have cold water in the rest of the house even in the hot side of the faucet.
Nov 25, 2017 | Water Water Heaters
How do i repair bellera #r560vs kitchen faucet reduced/low cold water flow have installed newfaucet valve
Turn off the hot & cold water supply lines at the shut-off valves.
Yo need to use the correct replacement cartridge for the faucet you are fixing
The cartridge replacement procedure requires using food grade silicone lubricant around the base of the new cartridge and around the threads of the bonnet.
Then you must properly align the 2 bumps on the bottom of the cartridge with the inside body of the faucet.
Insert and tighten down the bonnet that holds the cartridge in place to where it is snug- do not over tighten the bonnet!
Then reinstall the trim piece and lever.
Slowly, fully open the hot and cold water shut-offs and check for leaks at the shut offs, sink handle, and spout.
If you are using the Watts brand floodsafe supply lines, turn the hot and cold water shut-offs, on slowly. Rapid flow and pressure may activate the floodsafe valve within the supply line, causing little to no water flow to the faucet.
Feb 23, 2015 | Plumbing
My house is only 2 years old and has begun making a "hammering" noise when I turn on the cold water tap in the bathroom only. The water will actually stop flowing in a moment or two.
If the water actually stops running it might be a problem in the internal balancing valves. Some valves will restrict flows of the other water-supply: If there is slow hot water it throttles the cold water, if there is slow cold water it throttles the hot water. It is meant to stop the screaming in the shower if a toilet for example is flushed and the cold water pressure drops. Some but not all valves can be taken apart and cleaned. Turn off both shut off vavles first!
Oct 18, 2013 | Hansgrohe 06649860 Solaris Single Hole...
Fixed leaking faucet, now handles leak at the base & the water pressure is low
No, air can't get trapped in there. I don't think you did anything wrong. It sounds like the valve or internal parts are worn more than new washers take up for. Tightening down the valve just reduced travel for valve to open fully. Can't think of a fix; where's that joe da plumber?
Nov 23, 2011 | Plumbing
I have a one handle shower/tub faucet, and when you run straight hot water (to preheat for example) the water shuts itself off. Lever is still in the lifted/on position however. Cold is fine, even warm...
If this is a newer valve what is probably happening is the valve is a scald guard valve and is shuting itself off when it senses no pressure on the cold side. I don't have a lot of experience with am. std. valves but I'm sure you can get instruction on line to set heat setting on valve higher. Thank you.
Jan 20, 2011 | American Standard One Handle Tub & Shower...
New Pegasus shower valve that does not get hot water
single water handles are often put back in 180 degrees off, remove the shaft and turn it over
Aug 02, 2010 | Union Pegasus F1228100PBV Series 5000...
Cold side of faucet, when turned on, occasionally stops flowing.
Sounds like the valve is comming apart internally. This allows the water to get into places it shouldn't and the water pressure forces the valve closed even though the handle is in the open position. Take it apart and check for loose screws and broken pieces. Lowes or Home Depot should have parts. Don't forget to shut off the valve below the faucet (if the plumber installed one) if not one will have ot shut off incomeing water supply.
Sep 02, 2009 | Price Pfister Plumbing
Washer was working fine! Moved washer to new house, and now it will run but only with hot water. put washer on Auto controll, and cold cold or warm cold setting, and it wont even turn on.
Have you tried checking your cold water supply faucet? Are you sure there is cold water running out of that faucet before you hooked up the hose? Is it possible there is a shut off on the supply valve that isn't turned on? Therefore it will not run on cold water setting? This actually happened to me once. We went away for a week and turned the water off for the hot and cold supplys. Came back to do laundry and only turned the hot one on and not the cold. Good luck!
Aug 17, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Faucet running in off position
the fixture is set up so off is full to right as you go to the left the cycle is cold then hot if you don't understand turn tap all the way to right and turn on main if you need more help please post comment thank you for useing fixya please rate me
Feb 23, 2009 | Plumbing
Kitchen faucet Remove
All faucets have a hot and cold line input. The single handle units have a mixing valve within the handle. Aside from removing the water lines there is usually some type of connecting bolts for the base plate as well that will need to be removed prior to removing the faucet. Do not forget to turn the shut off valves off at the wall before you remove the water lines.
Good Luck
Dec 03, 2008 | Plumbing
Home Logo
107 people viewed this question
Top American Standard Home Experts
Mike
john h
Tom Chichester
Are you an American Standard Home Expert? Answer questions, earn points and help others
