Question about Thermador Ovens
The microwave unit on my Thermadore CMT231 (integrated microwave convection oven) has suddenly stopped functioning. I suspect a fuse has blown. Is this a self-serviceable part? I am a complete novice, but willing to try if its an easy fix.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 92 Answers
No to novice work! get yourself or your family killed (although you might do Darwins' work for him.....)
Yes to fuse, check the HV fuse and try replacing it. if it blows again you have a serious fault and need a micro tech.
PS expensive :-(
Posted on Oct 18, 2013
4 Suggested Answers
SOURCE: OVEN will not heat
After reading the above, here is how I fixed my KEBS177DSS9
I pulled out the wall oven from the cabnet. Took off the back tin panel about 10 tin screws. Follow the wire from both heating elements. They are both connected to a thermo fuse. When using the self clean feature this fuse protects the oven from over heating and starting a fire. I put a jumper wire from the hot lead on the left and connected it to the 2 leads on the right side. I turned the power back on and turn the oven on to bake at 350 degrees. Yep It worked like a charm. I bypassed the thermal fuse and used the oven, until the new thermal fuse was ordered. If you have any questions about this fix email me at jodunn5555@aol.com Good luck
Posted on Dec 24, 2007
SOURCE: kitchenaid KEBC177 electric convection oven will not heat
This is a design flaw in the Kitchenaid convection ovens. I can help fix this problem if you have a built in oven (I don't know if the parts are located in the same place for stand alone ovens). First it is not a FUSE that has blown rather it is the thermostat in the rear of the oven. (Part #4452223) This small part cost about $37 US and after shipping it will cost you about $47. I tried to get an estimate from an electrician as to what they would charge for the part and to come out and fix the oven an the price was about $90 for the part and anywhere between $100 and $170 more for the service call + repair! After a day of frustration I decided to tackle the problem myself.
The very first thing you must do is shut off the circuit breaker to the oven and put a very large sign on the panel that reads DO NOT TOUCH! That is 220 volts to that oven and while most panels have just the oven ont circuit you dont want anyone reactivating that circuit by mistake!
The next part requires a little work. Find the side panel screws (usually located in the oven door) and remove the two panel flanges that cover the 2 or 4 mounting screws that keep the oven in the wall. Now go underneath the oven and find the power junction box, take off the cover and disconnect the wires that run from the oven. Remember which goes where. Next remove the little nut that holds the electical conduit cable to the junction box then loosen the wires. Once this is done you can now slide the oven out and get to the thermostat.
This part requires a little elbow grease. Find a platform or table that fits just under where the stove will slide out and slide the oven on top of the table or whatever for support. In the back of the oven there will be a sheet metal panel that covers the thermostat and other wires, remove the 5 or 6 screws that hold this panel on and put the panel aside. Almost in the middle of the oven's back you will see a little black device with two wires running out of it (one red the other white or yellow). It will have the part number on its front, remove the wire and notice that the thermostat is half red and half white (remember this for the new part will have the same markings) the red wire goes onto the lead coming from the red markings. When you have the new part simply put the new one in (remember: the red side to the red wire), attach it to the back of the oven, replace the sheet metal cover and slide the oven back into place securing it with the screws. Viola! you are done! Turn on the power and then test the oven (I used the broil setting to warm it up then switch to a temperature setting). The entire process took me about an hour and I am NOT a handyman!
For about $50 and a little work you will save yourself from $150 to $250. Not to mention the repairmen won't have a clue as to what the problem is or who will attempt to sell you a new front panel or perform other unnecessary work.
Posted on Dec 09, 2008
kram26
  • 544 Answers
SOURCE: I need to self- clean my Thermador convection oven
hi,
here is the manual for your oven try to follow them and make them as your guide enjoy..
click on this site..
http://specs.retaildeck.com/CACHE/FILE2202.PDF
thank you,
please don't forget to rate our answers.
Posted on Feb 19, 2009
GE Dualwave Mirco Oven combo - Oven works fine - Micro doesn't even show the clock
There is a very good chance that it has blown a fuse. They would be located behind the control panel. Be careful around the wiring to the high voltage circuit and make sure that the power is shut off.
Apr 14, 2014 | GE Jkp90Dpbb 27" Built-In Combo Microwave...
Hello we have bosch hbc 86 and every time i want to turn on the microwave it suddenly stops, even when im trying to defrost,it starts and then in 3 seconds it turns off, please do you have a solution for...
My HBC 86 showed this behavior, after a fuse for the microwave operations was blown (remove the top cover and you will see it on a board close to the door). It's an 8A, medium speed. There might be different reasons, why the fuse is blown. In my case, the switches that detect whether the oven door is closed or open caused the problem. There are two connected with the microwave, one on the left (a bipolar switch) and another on the right. The switches will cause a short-circuit (and thus a blown fuse), if the left one detects an open door and the right one a closed door - it's an additional security feature. The problem can be caused by a blocked or slowly reacting switch. You might want to clean/replace the switches and/or put the right switch as far as possible away from the door so that it detects a close later (and open earlier). A good thing for testing: the problem occurs without actually starting the microwave.
Oct 15, 2010 | Bosch HBC 86Q650B Electric Single Oven
The fan start coming on after the oven is heated up then f10 starts flashing and the oven starts beeping on my kenmore elite convection oven
the only codes ifind for the f 10 is defective touch pad.. ck the glass alligament /ribbonconnector / replace touch pad if necessary / . this may be a thermadore buit unit / there f10 states also to replace the contr board .. hope this helped **** ..
Dec 04, 2009 | Kenmore 47783 Electric Single Oven
My microwave is making all the right noises and going through the time set ok but liquid still cold
HI. in most cases, this will lead to a failed Heating device(magnetron tube).It would be wise to check the Magnetron cutoff fuse to be sure of its integrity. if the fuse is blown, simply replace it. if the fuse continues to show continuity, replace the magnetron.
(((The fuse is located inside the unit along side the magnetron)))
Nov 10, 2009 | Ovens
Convection works but Microwave does not heat
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
duid
May 26, 2009 | GE Monogram® ZMC1095BFBB /...
try using a voltage stabiliser .it may just solve ur problem..
May 17, 2009 | GE Monogram® ZMC1095BFBB /...
Oven will not heat up on bake broil or convection cook.
I justn encountered the same problem (Model KERS507Y). Haven't checked yet...but am suspecting the Thermal fuse. Have you solved the problem?
Jan 18, 2009 | KitchenAid Architect Series KEMC308KSS...
Creda convection oven wont heat up
my ge profile double electric oven, bottome convection wont heat up
Feb 19, 2008 | Ovens
Ovens Logo
Top Thermador Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a Thermador Oven Expert? Answer questions, earn points and help others
