Question about Reebok 8050 ES Treadmill
Reebock treadmill bogs down - Reebok 8050 ES Treadmill
    Top Expert:
  • Reebok Master
  • 12,223 Answers
See the videos and fix it. God bless you.
lube the rollers bearing front+back , test the drive belt motor, and replace it if necessary.
Posted on Oct 15, 2013
How do I regain lost functions on a Reebock RT 5.1 treadmill?
http://www.manualowl.com/m/Reebok/Competitor-Rt-5.1-Treadmill/Manual/350955 It's look like the engine controller has some fault occurred on it,those board made out of components,as you mentioned motor is spinning but controller not working,so might be liquid damaged through top or faulty circuit refer manual from web ,it's fixable
Mar 31, 2014 | Exercise & Fitness
Please any one can send me a Reebock, Premier Run ( RE-12301) tread mil control board Sercuit, becasue when I power up my treadmill its fuse burnt. Why is that. Please help
Dear Sir:
I will help you inmediately.
SOLUTION:
a. Check the reset/off circuit breaker . If the circuit breaker has tripped, wait
for five minutes and then press the switch to the reset position.
b. Make sure that the power cord is plugged in. If the power cord is plugged in, unplug it, wait for
five minutes, and then plug it back in.
c. Remove the key from the console and then reinsert it.
d. Make sure that the reset/off circuit breaker is in the reset position
e. If the treadmill still will not run, you MUST replace the complete PCB to due some electronic component is in ShortCircuit.(Reason for to blown the fuse or c.breaker.
You must provide Mark, Model,Serial Number. please contact the phone number:.CALL TOLL-FREE from the:
1-877-994-4999
www.reebokservice.com
I hope to help you. blessing , sincerely.
E.CUADRA
MANAGUA, NICARAGUA C.A.
Sep 13, 2011 | Reebok Vista Treadmill - RBTL13305
Treadmill seems to start out OK but after maybe 2 minutes suddenly bogs down to about half speed then will stop all together if keep trying to go. If step off the belt after it bogs, it will speed up to...
hi,
check the motor and the motor controlling card. check the motor is it over heating or not. also check the speed sensor beside the motor pulley. clean the speed sensor and refix it. then test again
ok
Jan 01, 2011 | Proform iLog 750 Treadmill
The machine powers up but the screen does not come on. i have checked all the wires and they are all attached. it is a reebock I run treadmill. please help
Check the main harness running up to the console through the leg. unplug it and use a volt meter to test the red and black wires. You should have 9-12 vdc if you do and the console is not lighting check that the safety key is in place. If it is and it is still not coming on the console is malfunctioning and would need replaced. If there is no voltage coming through the harness then you will need to check the harness for continuity. If harness tests ok then the controller is malfunctioning and would need replaced.
Jul 21, 2010 | Reebok Vista Treadmill - RBTL13305
Got a 390pi proform and when I step on the
Go to your local hard ware store and purchase silicone spray. Apply Lubricant by lifting one side of the running belt spray contents length wise starting at motor shroud to the back end repeat this process the other side. If this unit bogs down again then you will have replace the running belt and possibly the deck.
Jun 01, 2010 | Proform Sport 1000 Folding Treadmill...
I have a NordicTrack EXP 1000 X. Just bought it froma guy on craigslist, and it was working fine at his house. Messed with the belt tensioner bolts a bit when I brought it home, and now when I walk/run on...
It sounds like the belt is bogging down, this condition is when the treadmill operates normally without a person on the belt and then slows down when someone steps on the belt or when the treadmill operates normally for a given period of time with someone on the belt then abruptly begins to slow down.
The only certain way to test for a worn walking belt is to take a DC amp draw . Trying to look at the belt or a feel test is highly unreliable. Better tests, if you lack a DC ammeter (they are expensive for a good one), are a coast test or an incline test.
The coast test is to get on the treadmill as the lowest incline setting and walk on the treadmill at 3 MPH. Pull the safety key and it should take you 2-3 full steps to stop fewer steps indicate high friction.
The incline test is to put the treadmill at max incline and walk on it at 3 MPH. If the treadmill operates normally at max incline but bogs down at minimum incline, replace the walking belt. Gravity takes over for the drive system eliminating much of the friction problem. On some heavily worn walking belts, this test will not eliminate the problem.
May 23, 2010 | Nordic Track NordicTrack Treadmill, A2550
I have a Lifestyler 8.0 Treadmill. It keeps
Use a good silicone Spray under the belt for every 10 hours of use
Jan 02, 2010 | RTO Lifestyler 8.0 MPH Treadmill Walking...
Reebok 8050 ES Treadmill Logo
Top Reebok Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Howard
Howard
Are you a Reebok Exercise and Fitnes Expert? Answer questions, earn points and help others
