Question about Kitchen Ranges
During cleaning my burning got wet and only one of 4 are working. None are clicking. The screws to take off burners are stripped. Is there a special tool that can get them off and once they are removed will I be able to replace a part so that I can get the stove working? Or will I have to replace the whole unit. The stovetop is approximately 7 years old. I need help with determining if its cheaper to replace or fix
    Top Expert:
  • Kitchen Ranges Master
  • 9,472 Answers
What is the model number?
Posted on Oct 22, 2013
jsrock516
  • 5911 Answers
SOURCE: Stove burner igniter does not work.
Your problem is not the igniter itself, but the burner switch that controls the igniter. All the igniters get their power from one spark module that is mounted somewhere in back of the oven. That's why you are able to get all the igniters to spark with only one burner control turned on. This is normal. That is also why you are able to light the burner in question buy turning on another burner. The spark is being provided by a switch that is working. To answer your question: the igniter is removable, but I don't think it's necessary. Cleaning them generally doesn't make them work better. I would check the wiring from the spark module to the burner switch and/or replace the switch. I hope this helps.
Posted on Jul 18, 2007
IFIXALL
  • 868 Answers
SOURCE: Oven will not lite
Older is BETTER !! Replace the igniter,even if it is glowing
REPLACE it !
note:there is a 2% chance the safety valve is the problem.And I'll bet you ,you are in the 98% side on this one.EVEN THOUGH YOU SEE IT GLOW -----IF ITS JUST GLOWING---------GLOWING--------GLOWING---------it's gone ! !
Please Rate This & Thank You ! !
Posted on Jun 12, 2008
  • 172 Answers
SOURCE: GE Spectra stove, oven won't light
Hi ewood,
You can look up your ge owners manual at ge.com . If the oven has stopped working chances are you have a bad ignitor. the part number is WB2X9154 . The part is $69.99 and I have this item in stock. Shipping will be $6.50 in the continental US>
I hope this will FixYa. If you have more questions please let me know. I can tell you how to remove the old ignitor if needed.
Anderson Appliance
Mike Anderson (Owner)
(865)945-3808
Posted on Sep 30, 2008
SOURCE: gas stove /electric starter won't click to start cleaned stove
Try cleaning the starter with rubbing alcohol and toothbrush. There might be soap or boiled over residue on the starter. If that doesn't work, try using fine 150 grit sandpaper and gentle clean the starter with it. This problems drove me nuts too. Good luck!
Posted on Mar 21, 2009
SOURCE: burner igniter won't click or work
This is an easy problem to fix. If your repair man is correct and it is the spark module and not a wire harness problem you can pick up a spark module as sears for about $37 and it only takes a couple of minutes to install. Just pull off the back panel and replace the module. This is a repair that anyone can do. I would recommend unplugging the unit before replacing.
Posted on Jun 20, 2009
Evalschmeer@gmail.com
Hi, If you have fuses on the stove have them checked and/or replaced with new ones.
You may have shorted out something when you made it wet.
Also check main power breaker if tripped. 115/230 volt breaker.
Hope that helps.
Mar 17, 2014 | Kitchen Ranges
Amana electric dryer timer doesn't advance during
If this is one of the electronic models: Clean the sensor strips located inside the drying area. As wet clothes rub against these the control monitors the resistance changes and knows the clothes are still wet therefore it continues to operate. When buildup from dryer sheets and fab softener get on them strips a barrier is formed that repels dampness. Therefore the control does not know the clothes are wet and goes to the end thinking all is Kosher. Clean them sensor strips with Windex and party on!
Jun 18, 2012 | Dryers
Burner ignighter will not stop clicking. The burner is not lit, but the clicking will not stop
One of the 4 burner control switches on the front of each burner control valves has failed. Inside the thin ceramic switch there are 2 thin strips of copper that are pushed together by a rotating cam driven by the movement of the burner control knob. One of the thin strips is stuck together.
UNPLUG the unit and only plug it in briefly for testing.
The top has to be opened by removing all 4 burner caps and removing the 4 screws under the burner caps. Remove the caps completely but reconnect one burner cap and make sure it is grounded so you can test the igniter's. The gas burner tubing needs removed then the gas burner support has to be removed to gain access to these switches. To remove the wires from the switch you have to use a jewelers screwdriver to release the 2 wires from the switch one at a time. The switches are in series parallel so if one switch is stuck all 4 igniter's pop. To read out the switches you have to remove at least one wire from each switch and insert a short test wire to read for continuity, The switch that has continuity with the burner control switch OFF is the failed switch.
NOTE: the yellow and orange wires need to be insulated during testing. I use a folded paper bag or torn off strips of a cardboard box Just test briefly....
The part number for the switch is 7403P190-60 (Image search)
http://www.repairclinic.com/PartDetail/Switch/7403P190-60/2326
There are numerous sources for the switch.
Thanks for choosing FixYa,
Kelly
Jul 24, 2011 | Magic Chef Ovens
My Viking vgsu cooktop has the igniter go on continuously when I try to turn on 4 of the 6 burners
My Viking stove igniter won't stop clicking. Both igniters on one side are clicking over and over
May 21, 2010 | Cooktops
GE gas range, model #jgbp33wen5ww, ignitors clicking and gas flow on all 4 burners, but none of the burners will light.
the burners on ge range are different in size / you may have the caps on the wrong burners . 2nd / ck for the hole in the burner are clean ( do not enlarge them when cleaning .. ) if this does not work . see if the ignitor's are in good cond . if chipped replace .. mm
Nov 22, 2009 | GE Profile JGB900 Gas Kitchen Range
Spark igniters on the burners fire continuously
When cleaning, if the control switches get damp, they will react as you describe.
Unplug the appliance, use a hair dryer and attempt to dry the switches.
Leave it unplugged overnight and try them again tomorrow.
They will eventually dry and be OK.
Feb 24, 2009 | KitchenAid 31 in. KGCC505 Gas Cooktop
Low flame on gas top burner
Hello Husky!! We can help you get the correct parts to repair this wonderful range. You sin=mply need another burner head to be replaced. We have parts and will make sure we get this out to you asap so you get back up and running soon. How many burner heads would you like to order? Please call or email us asap and we'll get these parts right out to you. We look forward to working with you. 972-859-0929
Feb 01, 2009 | Stoves 60" VULCAN RANGES GAS(CLICK HERE):...
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
