Oneac 600e Red and green lights on front of unit are solid and yellow light on front is flashing. Unit is also making a steady, periodic beeping sound.
The Machine
  • 788 Answers
SOURCE: My computer won't boot and the CyberPower 825 AVR makes a continuous sound.
It sounds as though the UPS is not receiving power. Check that it's cable is properly plugged into the wall. Also verify that it's internal ground fault interrupter has not tripped, it's usually a little red button on the back of the unit, it should be pressed in and should stay that way, if it pops out then there is a problem with the ground of your electrical outlet. Also check that the breaker for that electrical has not tripped at your fuse box.
Since the UPS is not receiving power the batteries have discharged and that is why your computer cannot start, there is not enough juice from the UPS to boot it. That is also why it is making a noise as most UPS's sound an alarm to indicate that they are not connected to power.
There is a chance that the batteries in your UPS have gone bad or that something has become faulty in your UPS. Try plugging your computer and monitor directly to the wall bypassing the UPS to see if they work fine.
Posted on Jun 18, 2008
SOURCE: My Toshiba 62HM15A DLP television
I just had the same problem last week I had reinstalled another lamp unit on my 62hm14 DLP, and it was doing the same thing both lights were blinking but the tv would not power up and come on.
It was simple once we figured out what was wrong the lamp unit door apparently has a safely mode switch and if the screw is not screwed into the tv to keep it from being opened it will not come on. It was just a safety feature.
We dropped our screw and god knows where it went but we found another, put it in and ta da tv came straight on.
Posted on Dec 02, 2008
SOURCE: samsung aircon cuts off. lights green/yellow flashing
lg air cond.multi split led lamp blink power 1 times,good sleep 2 times
Posted on Feb 13, 2009
micromedi280
SOURCE: Solid red light on R1500 rackmount UPS
If it is the single light to the left of the batery symbol it means "Potential Battery Failure". I have a pdf of the manual that I found at a different forum site. I am not sure how to post an attachment here. E-mail me and I will send it to you.
Dave
Posted on Mar 20, 2009
  • 4 Answers
SOURCE: My playstation 3 stays in the "standby mode" and does not turn on
its a power failure inside the ps3!!! You have to call sony to replace the system it will cost u 150.00 dollars unless ur still under warrenty goodluck because i had to get 3 systems from sony before i got one that worked just right
Posted on Mar 25, 2009
I ahve a beeping sound that is coming from my garage door opener.
If you have an opener with battery backup this may help. BBU stands for 'battery back up.'
This is battery related. On top of your unit is a battery pack with three colored led lights. You can tell what is going on by looking at these. This information is in your manual or here it is.
GREEN LED: All systems are normal. A solid LED light indicates the batteries are fully charged. A flashing LED indicates the batteries are being charged. NOTE: Batteries do not have to be fully charged to operate the motor unit. YELLOW LED: The motor unit has lost power and is operating off of the BBU. A solid LED with beep, sounding approximately every 2 seconds, indicates the motor unit is activating the door and is operating off of the BBU. A flashing LED with beep, sounding every 30 seconds, indicates batteries are low. Once the power is restored the BBU will recharge. This is indicated by a flashing GREEN LED. RED LED: An error has been detected and the BBU will automatically shut off. The BBU will attempt to restart by reconnecting to the batteries. If the error is still present it will shut itself off again. This process will repeat every 5 minutes or until the error has been resolved. This is used to prevent further draining of the batteries. If a red LED remains on when the power is restored, and is accompanied by a beep sounding every 30 seconds, please call for service.
Jul 09, 2011 | Sears Craftsman LiftMaster Chamberlain...
The main unit beeps every 30 seconds
GREEN LED: All systems are normal. A solid LED light indicates the batteries are fully charged. A flashing LED indicates the batteries are being charged. NOTE: Batteries do not have to be fully charged to operate the motor unit. YELLOW LED: The motor unit has lost power and is operating off of the BBU. A solid LED with beep, sounding approximately every 2 seconds, indicates the motor unit is activating the door and is operating off of the BBU. A flashing LED with beep, sounding every 30 seconds, indicates batteries are low. Once the power is restored the BBU will recharge. This is indicated by a flashing green LED. RED LED: An error has been detected and the BBU will automatically shut off. The BBU will attempt to restart by reconnecting to the batteries. If the error is still present it will shut itself off again. This process will repeat every 5 minutes or until the error has been resolved. This is used to prevent further draining of the batteries. If a red LED remains on when the power is restored, and is accompanied by a beep sounding every 30 seconds, please call for service.
Jan 25, 2011 | Sears Craftsman LiftMaster Chamberlain...
Lift masters battery keeps bleeping every 5 seconds,does this means my battery needs replacing.
Jan 15, 2011 | Sears Craftsman LiftMaster Chamberlain...
The battery backup beeps and the service light is on. The battery tests good with a volt meter
Dec 30, 2010 | Sears Craftsman LiftMaster Chamberlain...
Opener beeps
Nov 06, 2010 | Sears Craftsman LiftMaster Chamberlain...
The top light of the two is flashing green/red back and forth very fast and the light on the bottom is a solid red. how do I fix this so that way it will work normally
The steady lower light indicates the unit needs a new toner cartridge, MLT-D108S. Did you previously see this light blinking or blinking rapidly? (Those indicate the toner being low.) Replace the cartridge and check for any other error lights. Turn off the machine and let it cool. Then open the front cover and pull the old toner cartridge. Open the package with the new cartridge, remove the packing tape and paper that protects the cartridge and gently shake it (avoid touching the blue or green parts of the OPC drum). Press the cartridge into the slot until it is fully seated. Close the front cover.
The green/red blinking power light is not one I'm seen before. The printer indicates a non-toner failure (open cover, no paper, LSU failure, etc.) with a steady red light.
Aug 02, 2010 | Samsung ML-2240 Laser Printer
When you turn the unit on it goes to a green light then beeps twice and goes to a flashing red light?
This is an overheating problem.
Let it sit for about a day and then try it out.
Make sure it has ATLEAST 4 inches of open space all around it and is not near any heat-making devices, it makes enough heat on its own.
Also make sure it's not on carpet.
If it ever starts to immediately shut-off, blink green yellow and then repeating red with 3 beeps, you have the Yellow Light of Death.
This is a console killer.
Repost as a different question if it turns into the YLOD.
Feb 20, 2010 | Sony Playstation 3 (PS3) Console
My playstation has the light trun green yellow flashing red light
With your PS3 turned off, press and hold the Power button on the front of the PS3 for about 10 seconds (the system will beep as normal as it starts up but after 7-10 seconds it will beep again). The video settings should now be reverted. Doing this will also reset any theme settings. try this? seems to fix alot of issues.
Jan 22, 2010 | Sony PlayStation® 3 (80GB) Console
PS3 won't stay powered up.
powersupply is bad. ebay has them for around 45.
Jul 06, 2009 | Sony Playstation 3 (PS3) Console
Mar 24, 2009 | Sony Playstation 3 (PS3) Console
Computers & Internet Logo
748 people viewed this question
David Payne
David Payne
