Question about Sharp EL-2196BL Calculator
Install ribbon canon cp1213d - Sharp EL-2196BL Calculator
How do you change ink on a canon p20-dh calculator
For accounting offices and stores, calculators that produce a printed paper are indispensable. Canon's desktop or commercial printing calculators use ribbon tape, and you'll need to change the ribbon when it is used up. All Canon desktop and commercial printing calculators use the same method for changing the ribbon.
  • Turn off the calculator.
  • Pull up on the tab on the far side of the printer cover to remove the cover.
  • Pinch together the ribbon lock (the arrow shows you the direction to pinch). Lift the ribbon spools off the shafts and discard them.
  • Separate the new ribbon spools. Guide the ribbon tape around the four guiding pegs and set the spools on the shafts. The spools should be peg side down.
  • Rotate the spools so the peg at the bottom of the spool goes into the hole of the spool holder. Release the ribbon locks.
  • Rotate the spools to make the ribbon taut, keeping the ribbon positioned around the guide pegs.
  • Replace the printer cover and turn the calculator on.
How to Change the Ribbon in Canon Calculator eHow
Feb 06, 2016 | Canon Office Equipment & Supplies
Why does my Canon MP49D calculator print light?
Could it be you are using old ribbons? Are you using the correct ribbons?
did you put in the ribbon correct and is the ribbon transported, while it is printing, or is it stuck in the calculator. Just some questions to check out.
May 06, 2014 | Canon Office Equipment & Supplies
How to change ribbon on canon mp11dx calculator
See Page 3, top right column for ribbon change instructions and images.
https://www.manualslib.com/manual/355934/Canon-Mp11dx.html
Apr 15, 2014 | Canon MP-11DX Calculator
Only prints in red
may have print ribbon installed upside down. what happens if you try printing a negative number? if that number prints in black, try turning ink ribbon over
Jan 02, 2014 | Canon MP49D Calculator
My Canon QS310 electronic typewriter ribbon is always out-of-stock in our country. What other typewriter ribbons (brand/models) that are compatible with Canon QS310?
If you had posted what Country you are located in, I could have ran a search to locate someone local to you that has this product in stock. I am located in California. I could give you information on compatible ribbons which are available in my area, but they may not be available in yours and that would not solve your problem.
I would suggest that you stick with the ribbon that is made for your typewriter if at all possible? If you are unable to locate stock in your Country, try ordering the ribbons online instead.
The ribbons are available at Office Depot. They sell the product online and have your ribbon in stock. Here is a link to your ribbon on their website:
http://www.officedepot.com/a/products/914465/Canon-Model-AP11-Correctable-Film-Typewriter/
Here is a link to a website that sells both the generic and brand name ribbon for your typewriter:
http://www.fjaproducts.com/SearchMe/Department8640.asp
I hope this helps? Good luck!
Jul 07, 2011 | Canon Office Equipment & Supplies
Need to replace ribbon on canon mp25dv calculator
remove the printer cover, insert one spool on the left side pin, guide the ribbon though printer and inset other spool on right pin. make sure the ribbon looks like a C with the ribbon coming around the outside of each spool.
Apr 27, 2010 | Canon MP-25DV Calculator
Where can I get a ribbon for canon typestar 2?
ALL RIBBONS FOR THIS MACHINE ARE NO LONGER AVAILABLE
Nov 02, 2009 | Office Equipment & Supplies
How to insert the ink ribbon in a Canon calculator CP1213D
A lot of trial & error but finally figured it out. The ribbon winds around the outside guides towards the number cartridge or wheel.
Apr 14, 2009 | Canon CP1213DII Scientific Calculator
How to insall ribbon
Search Canon's website (www.canonusa.com) for the manual.
I did a quick look but didn't find it there. You might have to call
Canon:
Canon USA offers a full range of customer technical support* options:
  • Toll-free live technical support** Monday - Friday 8:00 a.m. - 8:00 p.m. EST at 1-800-828-4040
  • The location of the ASF nearest you for carry-in service at 1-800-828-4040
  • Toll-free TDD Support Line for the Hearing Impaired Monday - Saturday (excluding holidays) at 1-866-251-3752
  • Technical Support for Customers in Canada at 1-800-OK-CANON
or email link
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=349&modelid=9796#SupportDetailAct
Mike
Nov 08, 2007 | Canon MP-25DV Calculator
Sharp EL-2196BL Calculator Logo
85 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
