Question about Fahrenheat FFH1615 Heater
I have an edenpure gen 3 model. When you plug it in it does NOTHING! No beeps like it used to do and no lights come on the front panel. Any suggestions what the problem could be, Someone told me it could be the control circuit board. I don't want to buy a replacement board until I determine if in fact that is the problem. is there a way to test it? Any help would be GREATLY appreciated! Thanks
My Eden pure model Gen 3 doesn't turn on ? The red light on front is lite and filter is clean Why not
Edenpure has a troubleshooting guide at this website: MY HEATER WILL NOT TURN ON.
  • Make sure the power source is good. Plug in a lamp to see if it works correctly.
  • Make sure the front power switch/button is set to the "ON" position.
  • Unplug the power for 30 minutes. Plug the power back in and try operating the heater again. This will reset the internal sensors.
  • Some heater models are designed to be operated in temperatures less than 75 degrees Fahrenheit. The heater will not operate when the temperature is too high. Test the heater in a room that is below 75 degrees Fahrenheit.
  • Bring the heater inside to warm up for at least one hour before operating if it has been stored in a freezing or near freezing environment.
  • Make sure the filter is clean.
  • Remember, it will take a few minutes for the heater to warm up. The fan will start to blow after the heater has warmed up.
Heaters FAQ
Dec 07, 2016 | Air Purifiers
Hello just been given a ps3 you plug it in turn it on and nothing comes up on telle you take the lead out the tele and it says power supply lost plug it back in but still nothing. also it wont turn off on...
u could try resetting ur ps3 by holding down the power button on the front panel for 5seconds/u should hear one beep then a second beep/ps3 should revert back to normal av output.
Oct 14, 2013 | Sony Playstation 3 (PS3) Console
I have an eden pure gen 3 model that was purchased in Nov. of "09". I thought it had a 5 year warranty but to my surprise it is only 3 so now it's out of warranty and no one will help me. I was given a...
Did you check the fuse ? If that is ok then normally what goes first is a standby transformer on the front board itself. There is thermal fuse located inside the transformer that goes open circuit. A fairly easy and quick fix.
Oct 14, 2013 | Microwave Ovens
Eden pure beeps 3 times, and then it will not work
Sometimes things can get out of sync. Try unplugging the machine for a few hours to rest the code on the board.
Oct 09, 2013 | EDENPURE USA1000 Infrared Heater
Edenpure xl1000 parts
Replacement bulbs can be gotten from edenpure parts or check EBay for a supplier. Some will ship them no charge. To change them. Remove rear cover, then the cover on the rear of the heater box by 2 screws on the bottom and 1 at the top inside of a "U" Channel. Then lift the rear box cover up off the hanger hooks then back and out. The bulbs will be right in front of you in the 3 holes.
Jan 25, 2013 | EDENPURE USA 1000 Black Portable Heater -...
Need repair manual for eden pure heaters
The Edenpure Gen4 and US-1000 have a set of 3 - 500 watt bulbs that generate the heat. You'll likely need to buy a new set of bulbs every heating season ($60) or pay an Edenpure service center $100-140 to replace them for you. (Almost imossible to get SCI to cover the the bulbs under their so-called warranty)
Unfortunately, despite the hype printed on the box and Suarez Corporation Industries advertising, those bulbs last less than 500 hours of operation in those heaters. Suarez Manufacturing Industries/Pinnacle Systems have no engineering staff nor did they perform any durability testing on the heaters or any heater components.
Thus you, as the consumer, are stuck with continually the bulbs (in the US-1000 and Gen4 at least).
Apr 01, 2012 | Heating & Cooling
Edenpure won't work, even after replacing all the bulbs
where is this located in your car or truck ?
Dec 14, 2017 | Cars & Trucks
Fahrenheat FFH1615 Heater Logo
128 people viewed this question
Top Fahrenheat Heating & Cooling Experts
butch welch
Paul Carew
Are you a Fahrenheat Heating and Cooling Expert? Answer questions, earn points and help others
