Question about LG LMV1650ST Microwave Oven
The microwave unit in my Thermodore CMT231 has abruptly stopped working. I suspect a fuse may have blown. Is this self-serviceable? I am pretty much a novice.
  • 150 Answers
When you say it stopped working , you mean no lights or display etc. Then that can be a fuse but fuses blow for a reason. Find the reason if the fuse blew.
Posted on Oct 15, 2013
GE Spacemaker (LVM1750) Microwave Oven
If the source voltage, the fuse inside the unit are good someone has to follow the voltage in to see where it stops.
Dec 23, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave just stopped working while in the middle of cooking. clock and inside light went black - nothing works!
You could have over heated the microwave or blown a fuse due to a problem in the door circuit. Either way this can be repaired with minimal parts. I would suspect you blow the fuse to the cabinet due to temperature where to high in the unit. I would need a model number to assist you further..
Good Luck
Aug 03, 2011 | Kenmore Microwave Ovens
The internal 8a ceramic fuse has blown on my Sharp platinum collection 900w microwave oven, model R-957. fuse is marked F8AH 240V and is located on a small circuit board inside the rear of the oven. is...
Don't know if this a regular problem with this unit, but for this fuse to blow, there must be a problem further downstream. Maybe with the power supply or the Magnatron.
Sep 07, 2010 | Sharp R-1874 Convection/Microwave Oven
HOW TO REPLACE BLOWN FUSE
Look for a reset button on the back--push to reset. If trips again, unit has probable short.
Jul 11, 2009 | Jenn-Air JMV8208A Microwave Oven
Unit dead Unit is dead - suspect blown fuse
Usually, when your microwave oven doesn't work it all, the internal fuse (thermal fuse) is blown. This fuse protects both you and the oven. When it blows, you need to have a qualified appliance repair technician replace it.
The reason for this is that if you do not have any experience and training with microwaves, you can get a SEVERE shock, even if the oven is unplugged. THAT being said, if you still want to know where the fuse is get back to me. good luck.
ALSO, as you may know, a small microwave these days is under fifty bucks at walmart.
May 20, 2009 | Sharp R-1880LS 850 Watts Microwave Oven
Stopped working
just had this myself......the problem IS A BLOWN 15 AMP fuse INSIDE the microwave... you must FIRST make sure plug is UNPLUGGED....remove the 3 screws on back maybe 4 ??,,,then lift off the top and side panel...the fuse is located in the red wire behind the start button....GOOD LUCK !!
May 09, 2009 | Emerson MW8777W Microwave Oven
Reset for GE Microwave?
There's no other reset function. If a reset (unplugging) does not correct it, it will need to be repaired.
If it's less than one year old, it should be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free. GE Customer Service is here.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
I would suspect a blown fuse or the magnetron;s thermal cutout / thermal fuse.
Dec 27, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker microwave XL1400
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
Essentially you remove the vent grille held on by screws and/or clips then you'll see a screw at the top of the control panel.
Then the control panel should either lift up and out or forward and down.
The fuse is normally near the door switches, on the floor behind the controls, or on a metal plate near the transformer or fan.
There should also be a very helpful "mini-manual" hidden inside the unit behind the control panel. It's very helpful when troubleshooting.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
The actual model number is like JVM1460. XL1400 is just a "line" and won't help in finding parts.
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 02, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
This is usually caused by either a bad door switch or a loose door switch mount.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Feb 20, 2008 | GE JVM1440 Microwave Oven
LG LMV1650ST Microwave Oven Logo
42 people viewed this question
Top LG Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
