Question about Furuno GPA019S GPSDGPS HField Antenna without cable (ShieldedIMO Compliant
Antenna GPS Tram 1655 is compatible with GPS FURUNO?
    New Friend:
  • 65 Answers
If the Furuno unit you're referring to uses a GPS antenna with a coax (i.e. GP31/32) then the Tram antenna will work but the connector is wrong. The Tram antennas usually come with BNC connector and Furuno uses a TNC. Will need an adapter.
Posted on Jun 20, 2014
Why can I not receive with nthis antenna
what kind of radio do you have where are you mounting it and is it compatable with your set.A ham antenna may not work with your radio and a ham may not work with a cb antenna.Lot of factors
Apr 28, 2014 | Tram 1198 Glass Mount Cb With Weather-Band...
Ais and 1920c Furuno chart plotter
n the system setup, under “UNITS” I set BEARING to “MAG” (magnetic). This will cause the unit to display course / bearing information in relation to the Magnetic North and match magnetic compass readings. It is not the same as True North! One has to be careful with this setting. There are a number of areas where the earth's magnetic field is locally disturbed, sometimes very significantly. Your GPS may not account for it. - again, under “UNITS” I set “METRIC”.
Sep 02, 2008 | Furuno NavNet vx2 1920C GPS Receiver
Does my furuno GP32 have an internal antenna or do I need the to install the extra one?
Hi!
Your Furuno Does NOT have an internal antenna. You have no choice but to install the external one.
Hope this helps.
Jan 27, 2011 | Furuno GP32 GPS Receiver
Furuno GaAs FET Front End 4 Tone Daylight Display - when closing the DC breaker for the rada unit, the 10 amp fuse blows. Don't have a schematic. Don't know the model number. There are no data nor...
unplug the radar from it and turn on the display. If that does not blow the fuse, then your problem is either in the cable to the antenna or the antenna itself. Start there.
Nov 10, 2010 | Furuno 1715 LCD Radar System GPS Receiver
I have a Furuno Radome RSB0094-075 with a Navnet RDP 139 10.4" What I dont have is the antenna cable to connect the two units. What cable should i be ordering for this?? Thanks, Mike
That is a Furuno 1823C Radar -000-138-972 (10 meter Radar cable) $150.00 msrp from Furuno. Give their Camas Office a call or your nearest dealership. The Furuno number in Camas, Wa 888-834-9330
Nov 06, 2010 | Furuno NavNet vx2 1920C GPS Receiver
IS THERE A EXTERNAL ANTENNA AVALIBLE . IF SO WHAT MODLES CAN I USE THANKS MODLE 1623 FURUNO .
I would assume you're talking about the radar? it's a RSB0093-074 it's just for the 1623. There are no other options. If you're referring to gps antennas then any antenna that outputs nmea can be used.
Jan 25, 2010 | Furuno 1623 Radar 16nm Range
Error SB SIG MISS on FURUNO CRT radar?
Either your reed switch is bad or your antenna is not rotating. You may hear the motor spinning but that does not mean the array is. If the array is not spinning make sure the belt did not come off the motor. Start there.
Jul 05, 2009 | Furuno 1715 LCD Radar System GPS Receiver
Adapt 997c si gps to navnet furuno sounder
no can do you must have a Furuno GPS or a GPS with NMEA 0183 output. you could get that from the Hummingbird display but not straight from the antenna
Feb 27, 2009 | Furuno NavNet vx2 1920C GPS Receiver
Installation furuno GP7000F/NT
This unit has built in sonar, so no DFF1 is required. The 1KW transom mount is in stock here, with the proper Furuno 10 pin connector. That is all you need, the display, the power cord, the GPS antenna, the transducer and THE BOOK! We are a Furuno dealer in the Great Lakes
Mar 03, 2008 | Furuno GP7000F/NT GPS Receiver
Can't Receiver ( No Signal )
I WOULD SUGGEST THE ARIEL BREAKING DOWN, OR AN INGRESS OF WATER IN THE COAX CABLE. IF YOU NO SOMEONE WITH THE SAME UNIT TRY YOUR UNIT ON THERE ARIEL.
Feb 27, 2008 | Furuno GP32 GPS Receiver
Furuno GPA019S GPSDGPS HField Antenna without cable (ShieldedIMO Compliant Logo
118 people viewed this question
Top Furuno Boating Experts
Daniel Dollive
Daniel Dollive
David Burbee
David Burbee
Colin Stickland
Colin Stickland
Are you a Furuno Boating Expert? Answer questions, earn points and help others
