Question about Kenmore Elite HE5t Washer
Constant flashing lights on control panel. No obvious error code showing. What can be done to reset/fix this?
  • Rolan Hatley
    Rolan Hatley Oct 17, 2013
    Thank you for the suggestion, but I am afraid that did not work. The lights continue to flash once we attempted to run the washer approximatley 6 hours after unplugging. Incidentally, the washer still works. We just are not sure what setting the washer is on -- because of all of the blinking lights.
    Master:
  • 492 Answers
Try unplugging the machine for a few hours to rest the code on the board.
Posted on Oct 15, 2013
Samsung fridge flashing error code 80/88 not cooling why?
it seems it is defective control board problem
Jan 13, 2015 | Samsung Refrigerators
We have a whirlpool quiet partner iii. It was working fine and was opened mid cycle. Then it wouldnt drain. Then all the lights started blinking. At some point it drained the water out. We flipped the...
see this causes and fix it. God bles you
Check Fault Codes If the display lights are flashing and there is an error code in the display window, check the Error Codes guide on our website to determine which component has failed or is failing
Touchpad If the display lights are flickering for no reason, the touchpad might need to be replaced. Sometimes when the touchpad is defective the display lights are flashing randomly.
Touchpad and Control Panel If the lights are flashing on the display the entire touchpad and control panel assembly might be defective. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Heating Element Assembly If lights are flashing on the control panel, the heating element assembly might have burned out. The heating element assembly heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element assembly can be checked for continuity with an Ohm meter.
Heating Element If lights are flashing on the control panel, the heating element might have burned out. The heating element heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element can be checked for continuity with an Ohm meter.
Drain Pump If lights are flashing on the control panel, the drain pump might not be working properly. For two-wire drain pump motors check them for continuity using an Ohm meter. If it's defective YOU'LL need to replace it. Drain pumps are not repairable.
Oct 02, 2012 | Dishwashers
Selection Buttons on GE Cafe Dishwasher
see this causes and fix it. God bless you
Frigidare AEQ600es2 does not heat. Reports error code E68, but all buttons seem to work.
You will nee The error code E68 is a stuck button error code. I recommend checking each button to make sure it loose in the plastic console. The button should rock side to side a little bit. If all the buttons are loose you can try to reset the unit control by unplugging the dryer for two minutes. If the error code comes back you will need to replace the unit control.
Apr 17, 2012 | Frigidaire AEQ6000ES Electric Dryer
The panel is stuck on pots/pans for cleaning and wont let me run the dishwasher. the pots/pans light keeps flashing
To reset the dishwasher push in this order the,
HIGH TEMP WASH- HEATED DRY- HIGH TEMP WASH- HEATED DRY - CANCEL/OFF
the control will be reset...but more importantly how many times in a row does the light flash..it will indicate what error code its displaying??
example if it flashes 4 times then a pause then flashes 4 times again its displaying the error code#4
7 flashes then pause then 7 flashes its displaying the error code#7 ect ect
GENE
Sep 06, 2011 | Whirlpool 24 in. DU1055XTPS Stainless...
Error Code 51.2 C on an HP 4600
A 51.2 error message means that there is an error 51(Printer Error).2 (Laser Error) C (Cyan). This basically means that there is something wrong with the laser and the cyan color laser.
Reference via HP Website, Click Here
To Fix the problem:
  1. Press the green c00224695.jpg (Select) button to continue.
  2. Turn the printer off, and turn it on again.
  3. Perform a cold reset.
    1. Turn on the printer.
    2. Watch the control panel.
    3. When the memory starts counting, press and hold the c00224695.jpg (Select) button.
    4. Continue holding the c00224695.jpg (Select) button until the Ready, Data, and Attention lights flash once, and then stay on steady.
    5. Release the c00224695.jpg (Select) button when the Ready, Data, and Attention light are on steady.
    6. The control panel will display SELECT LANGUAGE .
    7. Press c00224697.jpg (Down Arrow) button once. The control panel will display COLD RESET .
    8. Press c00224695.jpg (Select). The printer will perform a cold reset and then continue its power-on sequence.
  4. If this message persists, contact an HP-authorized service or support provider.
Mar 21, 2009 | HP LaserJet 4600 Printer
Washer went haywire
Obviously, the control panel is indicating some type of error condition.
First thing to do is unplug the unit from the 120VAC power for about 10 minutes and plug it back in. See if this fixes the problem.
2nd thing I'd check is the ribbon or molex connectors on the back of the control panel. Re-seat them.
Mar 06, 2009 | Washing Machines
Error code on electrolux
Haven't tried your solution but I'm keeping it in mind. I talked to a repairman and he suggested I remove the panel at the bottom of the dishwasher (left side). There I will see a red button which is the control board processor reset button.
This worked but if the problem reoccurs I will try your solution as it is easier than removing a panel.
Dec 28, 2008 | Dishwashers
The lcd scrren on my range displays F7 in red and flashes d6 in g
The code is because of bad keypad/the control panel.Have it changed.It probably non-functional and constant beeping sound is followed as you mentioned.Theres a link to explain more about this for reference.The only solution is to replace the control panel.
http://www.askgene.com/2007/06/23/oven-error-codes/ge-oven-error-code-f7-and-how-to-fix-it/
Dec 13, 2008 | GE Spectra JBP78 Electric Kitchen Range
I have a Carrier infinity model 38tdb037-3. The outside unit will not come on. the control board on the outside unit shows an amber led on status 2.it is a steady constant flash.the error is an apparent...
Have you eliminated the possibility of a high or low pressure error. Sounds to me like it's off on safety. Should have troubleshooting the flash right on the panel. Test your pressure switches for continuity.
Jul 13, 2017 | Carrier Heating & Cooling
Kenmore Elite HE5t Washer Logo
43 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
