Question about GE Profile JGSP44 Dual Fuel (Electric and Gas) Kitchen Range
GE Profile Spectra XL 44 gas oven
I can't find the oven in your list. It's GE Profile Spectra XL 44, combination gas and electric. Electric starter; gas range and oven. everything works except the oven. It did this a couple of weeks ago, and then suddenly started working later that night. Last night it wouldn't come on, and is still not working this afternoon. Broiler works; burners work; clock, etc. all work. When I set the oven temperature, it acts like it's coming on, but never does. Temperature read-out remains at 100. If we turn on the broiler, the temperature readout climbs, so obviously the thermometer is working. But no oven. The oven is about 7 years old.
  • 3 more comments
  • TigerStrong Sep 28, 2007
    Yeah, I thought about that. There is no gas smell.
    Yeah, I thought about that. There is no gas smell. I think there is a safety feature, though, that won't allow the gas through if the igniter isn't working, so I wasn't sure how significant the no-smell is.
    Thanks.
  • SassieKass Dec 28, 2007
    I am having the same problem. I removed the bottom of the oven (plate that had 2 screws in it) and have the elements exposed. Not sure of where to go from there.
    If it's an ignitor issue I should be able to replace myself, right? Any suggestions on how to assess without having to call in help would be appreciated.
  • Luzine May 25, 2008
    Exact same problem ! Stove is GE Profile gas and is four years old.
  • Anonymous Mar 23, 2014
    Oven will not turn off
    Problem Solver:
  • 7 Answers
If you can smell the gas when you turn on the oven, it may be on a separate igniter that has gone bad. I would check this first. If you are not getting gas to the oven, there is possibly an issue with the supply line.
Posted on Sep 28, 2007
SOURCE:
My GE XL 44 oven will not come on
Does the igniter glow white hot when you try to start the oven?
Apr 04, 2013 | GE Profile Spectra JGBP90 Gas Kitchen...
I have a GE Spectra Profile XL 44 and I get an code F0. What does that mean?
Here is a tip that I wrote that will help you with the Xl44 profile error codes.
Oven Fault Codes for GE XL44 Oven
heatman101
Oct 03, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Broiler works but oven does not ge xl 44 model JJBP24BEA2WH serial LV201917P Is this worth fixing?
Hello-  Yes if it's the igniter for the oven burner. The lower burner may light, but if igniter is bad, gas flow will not increase, causing under-temp condition. The part is available for 40-75$, and is fairly easy to install. Part is accessed by removing drip pan at bottom of oven. Gas ranges last longer than electric if the self-clean 'function' is avoided. Go ahead and fix it!  Let me know if this info helps-- have more if needed.   Thanks-  Ed
Mar 17, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
F3 code on ge xl 44 gas range
F3 Open oven temperature sensor circuit Measure oven temperature sensor circuit at oven temperature sensor (should be approx 1100 ohms at room temp); check for cut or pinched wire or loss of contact
Jun 25, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Spectra XL 44 wont keep temperature
Replace the oven temperature sensor part # wb20k0004
Mar 18, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile JGSP44 Dual Fuel (Electric and Gas) Kitchen Range Logo
524 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Steve Allison
Steve Allison
Archie Ferrarini
Archie Ferrarini
Are you a Kitchen Range Expert? Answer questions, earn points and help others
