Question about 1999 VW Beetle Strut & Spring Front Driver or Passenger Side
Power seat driver side not working in my vw passat 2000
It is probably the motor or something with the track..... Take it go VW
Posted on Oct 15, 2013
How do I remove the front seats for 2001 VW Passat?
Raise car and block securely. Underneath on floor pans directly below seats you will see oval or round rubber grommets.(plugs) Use flat screw driver to pry out. You will see a nut under each. Remove nuts and remove seat. Installation of aftermarket seats may require you to drill new holes and or addition of shims to square up the base of the new seat. Flat washers work well.
Sep 08, 2012 | 2001 Volkswagen Passat
I have a 2002 VW Passat. The driver's seat is
cud be the switch or somethin lodged between the motor-try vacuuming-dont keep tryin cause motor will draw more amps
Aug 20, 2011 | 2002 Volkswagen Passat
VW Passat 1.6l 2000 (UK) Electrical failure
fuses are usually in the glove box or under the drivers dash or under the drivers side hood either physically inspect every fuse by pulling them one by one or the aid of a test light and a good ground to the test light
Sep 09, 2009 | 2000 Volkswagen Passat 4Motion
VW Passat 1.6l 2000 (UK) Sudden failure of
check under seat, there are 3 sets of wires, they could be coroded, these wires run all the windows door, any thing that is for useing the power, i know just had it fixed 245, 00 later,,
Sep 09, 2009 | 1999 Volkswagen Passat
I have a 2004 VW Passat. Rear Passenger window issue
sounds like your window regulator is going out
Sep 03, 2009 | 2004 Volkswagen Passat
Location of security arlam of vw passat
The alarm is located behind the back seat on the Drivers side. Up and towards the outside of the car.
Pull the back seat down. Look up where I stated.
You may need to remove or pull back the trim.
You should be able to see it mounted there.
Hope this helps.
Sketchlab.com
Mug Shot Collection
Apr 12, 2009 | 1999 Volkswagen Passat
Remote won't lock driver's side door lock
replace the lock actuater in the drivers door and you can try your local library for a diagram and pictures if you need them
Mar 20, 2009 | 2000 Volkswagen Passat 4Motion
2003 passat 1.8T gls power dirver seat
Seeing you have a GLS edition... most of them have at least a power DRIVERS seat. I own a 2003 GLX v6 and it comes with both front seats powered and heated. i hope this helps!
Jan 28, 2009 | 2003 Volkswagen Passat
1999 VW Beetle Strut & Spring Front Driver or Passenger Side Logo
185 people viewed this question
Top 1A Auto Parts Vehicle Parts & Accessories Experts
Tom
Mike Stager
Mike Stager
Are you a 1A Auto Parts Vehicle Part and Accessory Expert? Answer questions, earn points and help others
