Question about Sharp AQUOS 52" Flat-Panel LCD HDTV
Adjust picture size - Sharp AQUOS 52" Flat-Panel LCD HDTV
The picture from my fire stick is too large for the screen. The picture from my regular tv, cable and dvd are perfect. I need to know how to adjust the size of the picture.
adjust the size of your tvs picture with your tv remote. Hit mode and select desired size.
Bitcoin donation address: (anything helps!)
1BxGnavhUFra5zsuq2bdQJSz1HcFyGn8Za
Feb 28, 2017 | Televison & Video
How do i adjust the picture to fit thescreen on my toshiba flat screen tv
Hi, T
There will be a key on the remote control to adjust the picture size. You can adjust the picture size of your choice using this key.
Oct 11, 2014 | Toshiba Televison & Video
Picture size is to big how do i adjust it
check power supply volt is normal
if abnormal picture size is big
check vertical filter,preset, ic &yoke
Mar 25, 2014 | Sylvania Televison & Video
Picture too large for tv. Can't figure out how to adjust it.
There is a key on the TV remote control for adjusting the size of the picture. On pressing this key you will get the potions of the picture size like 4:3, 16:9, Zoom, Wide etc. You can choose the size you like.
Jan 08, 2014 | Sharp Aquos Televison & Video
43 inch plasma samsung tv with abnormal picture size .i want to adjust but i dont have serivce menu codes please help.
Using The Remote Control Your remote control will have a button on it to quickly adjust the picture size.
  1. Press the P.SIZE button.
  1. The current picture size will be displayed on the screen.
  1. Press the P.SIZE button repeatedly until the desired picture size is selected.
  2. Important: Some picture sizes are only available with certain resolutions or certain inputs.
Using The On-Screen Menu
  1. Press the MENU button. [The Main Menu appears]
  1. The Picture portion of the Main Menu will be selected by default, if it is not selected use the directional arrows to select the Picture portion.
  1. Use the directional arrows to select Screen Adjustments, and then press ENTER.
  1. Picture Size will be selected by default if not use the directional arrows to select Picture Size, and then press ENTER.
  2. Note: The current picture size selection will be displayed to the right.
  1. Use the directional arrows to select the desired picture size, and then press ENTER.
Nov 12, 2013 | Cell Phones
How do i adjust the picture to fit the screen?
The wide button on your remote adjusts the picture size. Each time you press it you adjust the picture. If repeatedly pressing the wide button is not changing the picture size check you cable/satellite remote control. Look for the hdzoom# button. There may also be an aspect or format button. When you adjust this the picture size changes and between the Sony remote and the cable/satellite remote you should be able to come to a happy medium. If the picture size still isn't changing you might not be set to the correct resolution i.e. 1080i on your cable/satellite box. It might be set too low or you might be in the wrong input (av 1 av 2 hdmi 1 hdmi 2) etc.
Jul 07, 2010 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
I can't switch the picture size. When i hit the pic size button, it tells me it's not available. I tried changing the pic size with the tv/video input on our dvd, but it won't change it when its on out hd...
defective hd cable box is possible but each unit has its own picture size adjustment. use your cable box remote and change size there. use tv remote to adjust tv size to auto. dvd the same thing
Nov 10, 2009 | Toshiba 57H82 57" Rear Projection...
Size of the picture decreased
If this only happens with your cable or satellite box this may be an adjustment in your box. So you may need to contact them and find out how to adjust the picture size. This tv may have a wide mode setting on the tv remote. Pushing this button may select full,wide,wide zoom or normal size. On many occasions the tv stations control the picture size. Good Luck
Jan 23, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Connection to MAC Mini
No changes can be made to the picture size on the panel. Most PCs have a facility to reduce the size by software means to correct this sort of problem (for example in 'Display properties'). As for the Mac; since it's not my area of expertise I can't say for sure but I'd be suprised if it didn't have this feature.
Nov 08, 2007 | Pioneer PDP-5060HD 50 in. Plasma...
JVC AV2649S Picture Too Large
you can see the diagnostic menu in jvc as you press both at the same the display and the picture mode buttons
Oct 17, 2007 | JVC AV27F476 27" TV
Sharp AQUOS 52" Flat-Panel LCD HDTV Logo
15 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
