Question about Safe International Digital Electronic Safe Lockbox Gun Jewelry Lock Box Tool
I have a pilot hotel safe model sae-1410 batteries are dead. it looks like an adapter plug for external power is that correct?
  • 1 more comment
  • Anonymous Mar 26, 2014
    how to order another emergency key
    how to order a second emergency key
  • Tobbe Feb 01, 2017
    IF you're missing the external adapter, like in my case, 4 AA batteries can be connected (6v) and wires carefully inserted in the adapter plug ;-) Worked like a charm. Default code 1234
Yes, that's right. You can use an external battery box with a mini-jack connector to give power to the keypad. If you have it, just plug it in, type in your code as usual and turn the key. Should be fine. Otherwise, use your emergency key (the round one), which overrides the keypad. You need to flip off the cover around the main keyhole and underneath is the emergency key hole. Turn that first, then the main key...hey presto!
Posted on May 28, 2009
I can't turn on my la[ptop
Laptop is dead. How to troubleshoot the problem.
In this post I’ll explain how to troubleshoot a dead laptop and find the problem. The following troubleshooting tips are not model and brand specific, they should work for most laptops.
Let’s take a look at two different scenarios.
Example 1. The laptop is absolutely dead.
When you plug in the power adapter and press on the power button, there is no signs of life at all. The laptop will not make usual noises, LEDs will not light up, the fan will not spin, the screen is blank and black, etc… In short, the laptop is dead.
What you can do in this case?
1. Make sure the wall outlet is working and the laptop DC adapter is getting power from the outlet. Try another wall outlet.
2. Test the laptop DC power adapter, make sure the voltage output is correct. You can test the DC power adapter with a voltmeter.
3. Let’s say the DC adapter is fine and the adapter outputs correct voltage. In this case unplug the power adapter from the laptop, remove the battery, wait for 1-2 minutes, plug in the adapter and try turning on the laptop again.
OK, you tested the adapter and it’s bad. If you decide to replace the original DC adapter with a generic one, you’ll have to follow this rule:
The voltage output on your new adapter has to be exactly the same as on the original adapter. The amperage on the new adapter could be the same or higher.
If nothing helps and the laptop is still dead, apparently the motherboard is fried or there is a problem with the DC power jack. It’s possible the DC power jack is broken and the motherboard is not getting any power from the adapter. In this case you’ll have to disassemble the laptop and replace the power jack.
Example 2. When you plug the DC power adapter and press on the power button, the laptop starts making normal noises, the LEDs work properly but noting appears on the screen. The laptop will not start.
First of all, take a closer look at the LCD screen. Look at the screen under bright light. It’s possible that the image is still on the screen but it’s very faint.
If there is no image on the laptop LCD screen, test the laptop with an external monitor. Connect an external monitor to the VGA port on your laptop and turn the laptop on. You can toggle video output between the internal LCD screen and external monitor by pressing Fn and F4 keys simultaneously on HP laptops, Fn and F5 keys on Toshiba laptops, Fn and F7 keys on IBM laptops. Other laptops may use different key combinations.
Let’s say the external monitor works fine but the internal LCD screen has no image at all. If that’s the case, your problem could be related to the LCD screen or the video cable. Also, make sure the video cable makes good connection with the motherboard and the LCD screen. Try reconnecting, reseating the cable.
In my case, both internal and external monitors were absolutely dead. Neither of them had image. That means the problem is not related to the LCD screen or the video cable. From my experience I know that this problem could be related to the laptop memory.
Try reseating the memory module, maybe it’s not making good connection with the memory slot. Try cleaning contacts on the memory module with pen eraser. Try moving the memory module into another slot. Try replacing the memory module with another known good module, it’s possible that your original module is dead.
If you have two memory modules installed you can try removing them one by one, it’s possible that one of the modules is bad. Try installing different memory modules into different memory slots.
In my case reseating, swapping the memory module didn’t help. I was pretty confident that my problem is not memory related and I moved on.
Try removing battery, hard drive and DVD drive and turning on the laptop without these components.
Also, try turning on the laptop with an external monitor when the video cable is unplugged from the motherboard. If the laptop start with video on the external monitor, apparently there is something wrong with the laptop display panel.
Finally, disassemble the laptop and removed the motherboard.
1. Motherboard. Like on most laptops, in my case the video card is integrated into the motherboard
2. CPU with heatsink and cooling fan.
3. Known good memory module.
4. The power button board witch you need to turn on the system.
5. Working DC power adapter.
Still cannot get any video on the external monitor. The system turns on, the cooling fan starts spinning but there is no video.
At this point I’m 95% sure that the motherboard is dead. CPU failures are not very common, so it must be bad motherboard.
Nov 08, 2009 | Acer Aspire One PC Notebook
Push power button and it wont turn on on my
These tips may or may not help depending on the type, if any damage done to your system....
Nov 07, 2009 | HP Compaq Presario V2000 Notebook
Whilst in use went completly dead canot resart
Nov 02, 2009 | HP Pavilion dv6000z Notebook
No' it's not powering up at all now, can you help' after changinng ac-adapter & battery
Oct 19, 2009 | Computers & Internet
I have power out of adapter but laptop is completely dead; no lights come on at all.
Oct 16, 2009 | Toshiba Satellite A45-S150 Notebook
Acer will not boot up even with it being plugged in, no lights, noise, nothing
Oct 13, 2009 | Acer Aspire 5100 Notebook
Laptop will not power up, hard drive light flashes twice then nothing. model is an acer 9300 about 2 years old, the only thing I noticed before this is that it would never reboot from warn, you always had...
Oct 11, 2009 | Acer Aspire 9300 Notebook
TravelMate 240 will not start - it begins to power-up, faintly beeps three or four times, then turns itself off - all with a blank screen!
Try these troubleshooting tips and see if it helps....
Oct 11, 2009 | Acer TravelMate 240 Notebook
Dell latitude d500 had a power socket problem, but now resolved pc will not boot-up, drive spins-up, then nothing, completely dead display i think most likely scenario is mobo is fried, but open to...
Oct 10, 2009 | Dell Latitude D500 Notebook
The screen is not going on all that shows up is a black screen with a white slash mark flasing
Oct 10, 2009 | Dell Inspiron 2200 Notebook
Safe International Digital Electronic Safe Lockbox Gun Jewelry Lock Box Tool Logo
760 people viewed this question
Top Safe International Locks & Locksmithing Experts
Jim London
Jim London
john h
Are you a Safe International Lock and Locksmithing Expert? Answer questions, earn points and help others
