Question about John Deere Garden
Fuel gauge not working
I have a JD X595.New driver display installed but the fuel guage does not work.It moves when the tank is filled but does not go down as the tank empties.....
  • 513 Answers
Sounds like the fuel sender is stuck or fuel sender selector has bad continuity or the contact on it is worn.
Posted on Jun 10, 2014
2 Suggested Answers
  • 2468 Answers
SOURCE: I have a JD X595 Diesel. This is what happens, say
have you tried bypassing the temperature sensor in the glow plug circuit? sometimes its in the blocks water temp sensor or in the intake manifold area that senses the need to use the glow plugs or not,due to the air and water temperatures in the engine,you will need to obtain a J.D. service manual for their locations on the engine
Posted on Jun 10, 2011
98 gmc jimmy fuel guage not working
No issues with the fuel guage that I know of , but you can follow the basic troubleshooting guidelines. Starting with the wiring disconnect at the fuel tank for a bad connector or bad connection. Only other connection would be up to the instrument cluster in the vehicle. Only replaceable items would be the guage or the sending unit in the fuel tank. You can disconnect the return line circuit or connector at the at the gas tank and jump a wire to the ground the that feeds the gauge and see if the guage moves, but don't and i repeat don't hold to long because the guage will go over hard over and could damage the guage. If the guage moved and I would suspect a bad float on the sending unit or a bad sending unit, either case the fuel pump assy would have to come out for repairs.
Jul 02, 2014 | 1997 GMC Jimmy
My 2006 ford explorer displays low fuel level n the fuel gauge does nt move or work even when there is full tank of fuel
make sure the sender is grounded or your guage wont work at all..there should be a ground wire .. if not add one someplace..
Dec 26, 2013 | Ford Cars & Trucks
Temperature gauge sensor
Is this a mechanical or electric temp. gauge? If it is a mechanical gauge, you may have a bad gauge. If it is electrical, try to find what the sending unit resistance value is at a given temperature and see if it matches with your sender. If the resistance value is off, you have a bad sender. If the resistance value are close to exact, you have a bad gauge. Be sure to check all electrical connections going through that circuit and make sure that there is no corrosion or fretting at connection ends. Hope this helps.
Oct 14, 2013 | John Deere Garden
Fuel guage does not work
The most common cause of an inop fuel gauge is the fuel level sender inside the gas tank is defective, this causes the gauge to read empty or just move a little when filled in some cases depending on where the break in the resistor that the float moves is located.
Oct 25, 2012 | 2007 Chrysler Pacifica FWD New Cars
2006 ENVOY fuel guage reads empty after fill up. What is the cause and how to rectify?
Usually I find there are two common causes for this problem. If the gauge goes to empty after a fill up but then starts to work and be fairly accurate as the fuel level in the tank drops then it's often the fuel level sending unit which is attached to the fuel pump module inside the tank. I have seen some guages go bad also [actually the servo motor that runs the gauge] but usually the gauge will stick in one spot and rarely move or go to either end of the scale and stick there. A good shop should be able to determine the cause of your problem pretty quickly. Hope this helps and good luck!
Dec 20, 2010 | 2006 GMC Envoy
Fuel gauge on 1993 Dodge Dakota V8
Definitely the gauge can be changed, provided the float in the fuel tank is OK, i.e. no leaks. This float connects to a potentiometer which records the current flowing thru it and displays it in the gauge. So before replacing the gauge measure the current and match that against the quantity of fuel in the tank...............sodeep
Jun 25, 2009 | 1992 Dodge Dakota
2002 honda crv fuel gauge moves really slow.
I had the same problem. My battery was going bad. When I replaced it with a new one, the fuel gauge worked fine.
Mar 15, 2009 | 2002 Honda CR-V
Gas Gauge not reading correctly
The most likely culprit is the sending unit in the tank. They are relatively easy to change, as long as you don't have much fuel in the tank. It's a mechanical unit that has a float that raises and lowers with the fuel level, however with age, the floats can develop leaks and no longer float, of the electronic portion of the unit can go bad and not register the proper level. They are replaced and an entire unit, so it doesn't matter which happened, you will need to change the fuel tank sending unit.
Jan 11, 2009 | 2004 Ford Explorer
Pajero NK87 petrol guage not working, shows empty even when tank is full
Sounds like the Fuel sender unit in the fuel tank needs replacing however you may want to check that the electrical plugs are contacting properly,Check that the gauge is working by putting a piece of wire from the sender unit wire to the chassis,at the fuel tank sender unit plug,Turn ignition on while watching gauge if it moves toward fill turn ignition off and remove wire to chassis.If gauge moves it means from the fuel tank to fuel gauge is intact and not your problem.
Oct 24, 2008 | Mitsubishi Montero Cars & Trucks
If you remove the sending unit in the gas tank, move it manually by hand as u saw done earlier, the gauge on the dash should also move. As long as the sending unit in the tank isn't 'stuck' at the half full level, the gauge should register empty to full as it moves. To be honest, I'm not sure if I would bother taking the sending unit out. 1st, u must be very careful not to blow yourself up when working on the gas tank (no sparks, etc), all u really need to do is fill up your car, see how many miles a tank of gas will go (carry a can of gas with u to see how many miles before u run out). If it's 350 miles, just set the trip gauge to zero every time u fill up, and get gas every 300 miles so u don't run out. If the sending unit moves freely, everything (wiring ) is connected properly, then it probably is the fuel gauge. good luck!
Oct 18, 2008 | 1992 Honda Accord
Garden Logo
285 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
