Question about John Deere Garden
Temperature gauge sensor
I have a JD X595 from 2005. The temperature gauge on the driver display/ dashboard does not move when engine gets hot. New display/ dash fitted. I suspect it may be a faulty sensor ?
    Novelist:
  • 157 Answers
Is this a mechanical or electric temp. gauge? If it is a mechanical gauge, you may have a bad gauge. If it is electrical, try to find what the sending unit resistance value is at a given temperature and see if it matches with your sender. If the resistance value is off, you have a bad sender. If the resistance value are close to exact, you have a bad gauge. Be sure to check all electrical connections going through that circuit and make sure that there is no corrosion or fretting at connection ends. Hope this helps.
Posted on Oct 16, 2013
2 Suggested Answers
wireguy212
  • 1627 Answers
SOURCE: 1962 JD 4010. TRANS SHAFTS TURNING, WON'T MOVE.
Try removing the the transmission shaft and you will likely find that the splines are missing from either the input or output shafts.
Posted on Dec 22, 2009
Does the 98 Ford F-150 5.4 triton have two coolant sending units? I found the one on the intake and replaced it and still no gauge.
Has CHT - cylinder head temp. sensor . This sensor is a input to the PCM - engine computer . The PCM sends engine temp info on serial data network to the instrument cluster . I/C has a microprocessor inside . Have it check for DTC'S - diagnostic trouble codes . Not OBD2 codes , B - body codes . The gauge could be the problem , which means replacing the instrument cluster .
Engine coolant temperature information is received by the instrument cluster from the PCM over the SCP network. Temperatures over 121°C (275°F) will display hot (H). If the engine coolant temperature data is missing or invalid for five seconds, the instrument cluster will move the engine coolant temperature gauge below the cold (C) position.
The best way to diagnose this is with a scan tool , factory or a professional type . Know how the system works and not replacing parts is the proper way to diagnose .
U1073 D073 SCP (J1850) Invalid or Missing Data for Engine Coolant PCM CARRY OUT the PCM self-test.
  • A single gauge does not return to zero with the ignition switch off
  • Instrument cluster.
  • INSTALL a new instrument cluster; REFER to Instrument Cluster . TEST the system for normal operation.
  • Incorrect temperature gauge indication
  • Circuitry.
  • PCM.
  • Engine coolant temperature sensor.
  • GO to Pinpoint Test F .
I should also point out that if the temp sensor were bad the vehicle may not run right .
Using the factory scan tool
Trigger instrument cluster active command ENGCOOLNT. Monitor the engine coolant temperature gauge while adjusting the ENGCOOLNT active command to read 50% and 100%.
  • Does the temperature gauge start at cold, move to half at 50%, and full hot at 100%?
Yes REFER to the Powertrain Control/Emissions Diagnosis (PC/ED) manual.
No INSTALL a new instrument cluster; REFER to Instrument Cluster . REPAIR the circuit. CLEAR the DTCs. REPEAT the self-test.
Your best bet , take it to a qualified repair shop !
May 29, 2017 | Ford Cars & Trucks
I have a daihatsu applause 16valve and the temperature reading is not displaying on the gauge in the dashboard. What you I do to fix it?
Check the wire from the temp sensor for a loose or disconnected wire harness connector. To see if the gauge is operating, pull the wire off the sensor and put a small jumper to engine ground. The gauge will move. If it does move then the temp sensor is not working. If it doesn't then the gauge is faulty.
Oct 08, 2016 | Daihatsu Cars & Trucks
Coolant sensor
Jeff, you haven't said what the problem is or what vehicle you have.
However, be aware that some vehicles have two coolant sensors.
One sensor sends a signal to the ECU to help control the running of the engine. The other sensor sends a signal to the temperature gauge on your dashboard - it shows you what temperature the engine is at - i.e cold, normal or hot.
If your vehicle has two coolant sensors, failure of the first type would more than likely illuminate an engine check light.
Failure of the second type would cause the dash temperature gauge to permanently read cold or hot, irrespective of the true engine temperature.
To locate this second type of sensor, look in the area of the thermostat housing. It screws into the engine block and will have 1 or 2 wires connected to it.
The link below shows generic images of this second type of sensor:
coolant temperature sensor Google Search
Apr 18, 2016 | Cars & Trucks
What is wrong the temp does not get hot going down rasd
I would buy a new thermostat and flush the radiator coolant. Dexcool (The orange coolant) is known to clog up the internals including the temperature sensor in cars of your age.
While you are at it, I would strongly consider changing radiator hoses and clamps unless that was done recently.
If you are referring to the dashboard temperature gauge not moving...It means that your temperature sending unit may be faulty (or it's not plugged in). Dexcool is known to clog up the internals including the temperature sensor in cars of your age. Inspect the connector to the temp gauge for damage and replace the temp gauge.
A replacement temp sensor is about $15 at any auto parts store.
Good luck
Feb 24, 2015 | 2004 Buick Rendezvous
2007 Chevy Silverado 2500 HD. I was driving and my digital dashboard reported engine hot and AC turned off. My temperature gauge read cool. What do I need to replace?
This sounds like a bad coolant temp sensor that give computer false reading, check the coolant temp sensor connector and if it is good with no bad wires to connector then replace coolant temp sensor , when the computer gets a signal from temp sensor that engine is hot it turns fans on high speed to cool radiator and displays a/c turned off , if this truck does not have electric cooling fans then they wont run just explaining what happens depending on engine and cooling set up. replace coolant temp sensor and check connector.
Dec 25, 2012 | 2007 Chevrolet Silverado 2500HD
Heat gauge goes way up,then by reeving motor it will go down.blows cold air
Check out related help links with solutions to troubleshoot the problem:---
Click the link below:---
2004 Toyota Tundra: Oil Gauge and Temp Gauge Not Working?
http://howtobyme.blogspot.in/2012/05/2004-toyota-tundra-oil-gauge-and-temp.html
Toyota 4Runner: Temperature Gauge Sensor http://technoanswers.blogspot.in/2012/04/toyota-4runner-temperature-gauge-sensor.html
Temperature gauge sits over half way mark? http://schematicsdiagram.blogspot.in/2012/04/temperature-gauge-sits-over-half-way.html
Heater blows intermittently and temp gauge goes erratic?
http://technoanswers.blogspot.com/2012/01/heater-blows-intermittently-and-temp.html
------------- No heat on Oldsmobile Silhouette? http://technoanswers.blogspot.in/2012/02/no-heat-on-oldsmobile-silhouette.html
Temperature gauge does not move and no heat when heater is ON? http://technoanswers.blogspot.com/2012/01/temperature-gauge-does-not-move-and-no.html
Temperature gauge keeps fluctuating up and down close to red? http://technoanswers.blogspot.com/2012/01/temperature-gauge-keeps-fluctuating-up.html
----------- Temperature gauge on the dash quit working on Pontiac Grand Prix? http://technoanswers.blogspot.com/2012/01/temperature-gauge-on-dash-quit-working.html
Dodge neon gauges not working? http://technoanswers.blogspot.in/2012/02/dodge-neon-gauges-not-working.html
Heater blows cold? http://schematicsdiagram.blogspot.in/2012/02/heater-blows-cold.html
Heat blows cold on drivers side and hot on passenger side? http://schematicsdiagram.blogspot.com/2011/12/heat-blows-cold-on-drivers-side-and-hot.html
1992 Lexus LS400: Engine overheats, Antifreeze out of reservoir and heater Blows Cold Air? http://whatisbyme.blogspot.in/2012/05/1992-lexus-ls400-engine-overheats.html
These details will help.
Thanks.
Nov 22, 2012 | 1997 Ford Taurus
Temp gauge doesn't move
It seems like your Temperature Gauge Sending Unit is bad, have it checked out before your engine overheats.
May 27, 2010 | 2001 Volkswagen Jetta TDI
Why won't the oil and temperature gauge work on
you should switch the temperature sensor and oil pressure sensor you had on your first engine,because your new engine must come with the light indicator dashboard so the sensor of your new engine are not compatible with your gauges....lipak!...
May 05, 2010 | 1988 Ford Ranger
The tempertature gauge does not work on my jeep what may be the problem?
Could be the coolant temp sensor:
4.0L engine shown
5.2L engine shown
To test it:
Perform this test on a cold or cool engine.
  1. Disconnect the negative (-) battery cable.
  2. Unplug the electrical wiring from the sending unit.
  3. Using an ohmmeter, measure the resistance between the terminal and the sending unit's metal body
    1. Infinite resistance or zero resistance: the sending unit is bad, replace the sender with a new one.
    2. Other than infinite or zero resistance: continue test.
  4. Remove the temperature sender from the engine.
  5. Position the sending unit so the metal shaft (opposite end from the electrical connectors) is in a pot of water. Make sure that the electrical connector is not submerged and only the tip of the sending unit's body is in the water.
  6. Heat the pot of water at a medium rate. While the water is warming, continue to measure the resistance of the terminal and the metal body of the sending unit:
    1. As the water warms up, the resistance goes down in a steady manner: the sending unit is good.
    2. As the water warms up, the resistance does not change or changes in erratic jumps: the sender is bad, replace it with a new one.
  7. Install the good or new sending unit into the engine, then connect the negative battery cable.
  1. With the engine cold, remove the ECT sensor.
  2. Immerse the tip of the sensor in container of water.
  3. Connect a digital ohmmeter to the two terminals of the sensor.
  4. Using a calibrated thermometer, compare the resistance of the sensor to the temperature of the water. Refer to the sensor resistance illustration.
  5. Repeat the test at two other temperature points, heating or cooling the water as necessary.
  6. If the sensor does not meet specification, it must be replaced.
Submerge the end of the temperature sensor in cold or hot water and check resistance
Temperature-to-resistance relationship of the ECT and MAT sensors
Apr 28, 2010 | 1995 Jeep Grand Cherokee
Garden Logo
257 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
