Question about Whirlpool 24 in. ADG6340 Built-in Dishwasher
Wirepool dishwasher ADPY 2320 start blinking 8 Times after I filled the slat (less than 1 kilo as per teh instruction). Filter is clean, the mashin does empty teh water if any put inside. But teh program( any ) doesnt start) Any Idea what to do next?
SOURCE: whirlpool gold start button flashing dishwasher won't start
press sani and heat back and fourth then after all lights light close door and hit start then wait about 3 minutes. worked for me
Posted on Apr 12, 2009
SOURCE: dishwasher will not run. clean light flashes seven times
I tried the button sequence described by guest #1 but nothing happened.... is there anything more to it?
Posted on Jun 13, 2009
QueenJLyn
  • 3 Answers
SOURCE: Maytag dishwasher not draining fully
Try cleaning out the air gap.  The air gap is not part of the machine, and is located on your sink. If this becomes clogged, it may cause the machine to not drain properly.  Also, I know you said you checked the drain hose and cleaned as far as the filter and chopper blade, but have you checked the lower filter?  There is a filter located underneath the machine that should periodically be cleaned.  To check this, you need to access the machine from underneath by removing the bottom vanity cover. Hope that one of these helps!
Posted on Aug 01, 2009
rylee_smith
  • 8619 Answers
SOURCE: My dishwasher clean light is blinking 7 times & not clean
Hi
Thanks for using FixYa. If the clean light flashes 7 times, pauses, then repeats...
When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring).
It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Posted on Nov 22, 2009
SOURCE: My whirlpool dishwasher is flashing 8 times - I
Hello, I have a Whirlpool DWF A10. The machine starts then stops after a short while and the indecator light flashes 7 times. What does this mean? Any body come across this?
Posted on Mar 23, 2010
I have a 3VE53 heater and was wondering about how much eletricity does it use if I keep it at 65-70 degrees for 9 hrs. a day?
Okay, for example a 100 watt bulb left on for 10hrs uses 100x10 =1000. so 1000= 1kwh. so look at the watt rating on the fan motor and times that by 9hrsand then do the math, then look at your bill and see what you pay per kwh (kilowatt per hour) and times that with your answer, for example lets say the heater blower is 10watts, take 10 X 9 = 90, then 90 divided into 1000=.09 so it .09 of a kilo watt almost a tenth of a kilo watt. so if you pay 3.25 a kwh then you would say .06X3.25=.195 less than one cent, hope this helps
Feb 16, 2012 | Dayton 3VE53 Oil Filled Liquid Fuel...
My new omega washing mashine shows an E2 error code 5 miniutes into the wash how do I fix this?
Manufactured by omega washing mashine have an electronic controlpanel that must be unlocked in order to set or make changes to your washingcycle.
E2 indicates a water leak. When a leak occurs, it trips thefloat device by dumping water into the dishwasher's base. The incoming watervalve will be switched off, and the drain pump will turn on until the sump isempty
However, if an error light is blinking on your dishwasher'scontrol panel, the panel must be reset before you can gain access. Blinkinglights on your washer control panel may signal a mechanical problem that needsto be repaired. If the lights continue to blink after you've reset the controlpanel, contact Sears to service omega washing mashine or considertroubleshooting the appliance yourself carefully.Instructions
1 Press and hold the "Heated Dry" button onyour omega washing mashine for four seconds to unlock the dishwasher controlpanel.
2 Press the "Heated Dry," "Normal Wash,""Heated Dry" and "Normal Wash" buttons one after theother, in fairly quick succession.
3 Wait for the washer to run a short diagnostic test.
4 Press the "Cancel/Drain" button at the endof the diagnostic test cycle. This should reset the control panel on your omegawashing mashine. Thankfor using fixya.
Jul 30, 2011 | Washing Machines
My Dishwasher starts as usual,,,fills with water then starts the wash cycle and quits after 5 seconds or so. it then does this 2 more times and shuts off completely. when i turn it on again it drains and...
Check the user guide manual. If resetting procedure is shown, follow it.
Otherwise the problem is with micro controller board. You have to contact the service provider as this is a computer program related fault.
If mechanical timer is used you can try cleaning them. But I doubt as the mechanical timers are no longer in use for the past few years.
Hope your incoming mains voltage is as per the recommendations!
110 V or 220 V as per your country standards.
Some times voltage fluctuations causes this problem. Should not be less than 10 % in any standard.
Sep 21, 2010 | Amana 24 in. ADB2200AW Built-In Dishwasher
Will not fill up with water before starting, it takes about 3-4 times brfore unit will run with full amount of water. loads take forever.
dish washers have a fill valve. the water supply line most likly has a net like filter that is stoped up with trash. Or fill valve is bad.
same thing happens to washing mashines. when they start filling up very slow you will TURN OFF water supply and diconect hose, look inside and there is the problem.
May 09, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Stopped runing
If you Whirlpool Gold 24 in. Built-In Dishwasher Dishwasher blinks 7 times and then repeats, indicates a problem in the dishwasher which should be investigated and not just the control 'reset'! That is why the control will not let the dishwasher start once such a condition is detected.
If the dishwasher's electronic control doesn't detect a water temperature increase during the main wash cycle, that symptom can occur. No water temperature increase could be caused by a problem in the heater element, its in-line thermostat, the related wiring or a problem in the electronic control.
It is also possible just the washer not spraying properly (possibly from blockage in the filter or problem in the pump), the dishwasher not filling sufficiently or draining prematurely or even a problem in the door latching mechanism's switch(es) could cause it.
Feb 22, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
Won't fill clean light blinks seven times
The blinking clean light is an interruption in the dishwasher program that either indicates a malfunction, or it can be a simple glitch. The following link explains how you may be able to clear the blinking clean light problem:
http://www.fixya.com/support/r417123-blinking_clean_light_kenmore_whirlpool
Now, keep in mind all dishwashers are not alike and have different panel options. If you do not have the same set up that I have mentioned, the tech sheet for your dishwasher will explain the touch pad functions. The tech sheet is located behind the lower toe panel under the door and lists the proper sequence of buttons to push for diagnostics and troubleshooting. Just remove the screws that hold the panel in place and remove.
NOTE: Sometimes the tech sheet is located behind the inner door panel. You will need to remove the screws securing the inner panel to access it if this is the case. Make sure you turn off the main power breaker before doing so.
I have often found this to be a momentary glitch in operation. However, if the problem keeps reoccuring the number of flashes is an indication of WHICH circuit is causing your problem. You will need to refer to your tech sheet to determine this.
If you have any questions, please let me know. I hope this helps you solve your problem.
Nov 30, 2009 | Dishwashers
I have a whirlpool dishwasher (gu2500xtpq6) wont fill up
water level should be approx 1/4--1/2 inch below the heating coil.. this is normal fill level
Apr 28, 2009 | Whirlpool 24 in. GU2500 XTP Built-in...
Whirlpool gold start button flashing dishwasher won't start
Oct 12, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Bosch
f is fill fault to much or not enough water or water in the sump white plastic base the f code will not go away until you solve the problem when the f code shows up the drain motor will run all of the time
Apr 01, 2006 | Bosch 24 in. SHU6802UC / SHU6806UC...
Whirlpool 24 in. ADG6340 Built-in Dishwasher Logo
913 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
