Chill mat doesn't run automatically when plugged in to USB port
  • Kim Harden
    Kim Harden Oct 14, 2013
    Sorry - I didn't clarify - This is a Targus PS248U1 that is supposed to run off a USB port. I got it secondhand so don't have any original paperwork.
  • Computers & ... Master
  • 16,181 Answers
I done believe in using those but, you need to check it on another usb port to be sure that it is not the fan in the pad that is bad.
Posted on Oct 14, 2013
Testimonial: "Thanks Brad! I will check!"
What are the other ports used for, and can I use them to run the fans?
Do you mean the USB-ports on your laptop? If so, than yes, you will need one free USB-port to connect the Chill Mat to.
Feb 18, 2016 | Targus netbook chill mat dual fan awe39us1
Tip
Cooling Mats a must have for laptops of any kind
One of the biggest enemies of pcs/macs and laptops are heat.
A great way to prevent this is a simple little item called a chill mat
when you go to buy a laptop or already have one dont forget to pick one up they plug into your usb port and keep your laptop from overheating many like the Swiss Army brand even have pull out arms to hug your laptop and fit on your lap and easily into your laptop bag with it they run under 50.00 bucks and are a great item for keeping your laptop healthy
on Mar 20, 2010 | Computers & Internet
The little insert in the usb port on my targus dual fan chill mat has become loose. How do I re-insert it and keep it from becoming loose again?
Tawny, If port still functioning, use 2 part epoxy to secure port, be care, no glue inside port.
press the helpful button
How do I get the additional usb ports to work on targus awe0101us1 chill pad
Does your laptop recognize the extra USB ports? If no, try updating your drivers.
Jan 15, 2015 | Targus PA248U AWE01US Chill Mat and four...
Targus chill mat won't work
it is definatly either a wiring issue or a cpu issue
Mar 18, 2014 | Targus Chill Mat PA248U Laptop Cooler
Targus AWE81US grinding noise in fan
any luck y fans make a grinding noise. vegasguy913@gmail.com
Feb 25, 2014 | Targus AWE81US Chill Hub and Chill Mat...
Lost the targus notebook chill mat power cord (usb from computer to the mat). Where can I find a replacement?
hi this can be purchased from somewhere like radio shack specs are Output: 5V 2000mA, centre is + positive so really just your standard adaptor will do, this also comes from the targus site hope that helps
Oct 02, 2010 | Targus Chill Mat PA248U Laptop Cooler
Targus Chill Mat. I keep getting error with windows 7 that the device is not working properly. It operates but an error keeps popping up every 10 seconds. So I can not use it. What is the fix?
Belkin makes a surge plug that has usb powered ports.
this is a Gr8 option it takes the poering off the pc.
this should fix ya up.
Good Luck
Happy Computing
Jan 10, 2010 | Targus AWE19US Chill Mat XC for Laptops
Power cable problems, also
open it up and splice the current power cable and connect it permanently to the USB connector. The problem is the power plug gets loosened after some time and can't make a proper connection.
May 24, 2009 | Targus Chill Mat PA248U Laptop Cooler
Targus chill mat not working properly
This problem is being caused by a wire becoming disconnected from the switch in the usb power cord. The easiest way to solve this problem is to open the switch using a flat blade like a knife, and either reconnect the loose wire yourself or to completely remove the switch and connect the wires together completing the circuit and allowing the fan to operate. I hope this helps.
Oct 30, 2007 | Targus Chill Mat PA248U Laptop Cooler
Computers & Internet Logo
David Payne
David Payne
