I need a user manual for zanussi turbodry wje 1407g
kjmac
  • 97 Answers
SOURCE: Zanussi Turbodry jetsystem 1200
hiya
e90 means there is a communication error between the circuit boards inside. remove the plug then take the lid off the machine, remove the block which has the 5 (iirc) blue wires in it and give it a quick squeeze then replace, this should hopefully solve your problem.
hope this helps
please dont forget to rate the helpfulness of this reply, thanks kj
Posted on Aug 03, 2008
gittos73
  • 244 Answers
SOURCE: zanussi Turbodry 1200 spin problem
if this washer is used alot then it will more then likely be the carbon brushes which u will need to take the lid off undue 4screws out where it joins front to the back screws at the back to the bottom and 1screw either side of the bottom where the panels join together behind a little cap which will have an hole in the middle of it to get it out u will then be able to get to the motor to replace the carbon brushes
Posted on Nov 25, 2008
  • 17 Answers
SOURCE: What is E 40 on Zanussi Turbodry 1200?
E40 indicates the doors not closed properly. Sometimes it can be the lock itself or the main control board
Posted on Dec 17, 2008
  • 57 Answers
SOURCE: zanussi jetsystem turbodry 1200 door wont open
its the doorcatch,turn power off, remove lid and put hand in machine where doorlock is situated feel about and try open catch, repair or replace?
Posted on Jun 24, 2009
barkencoa
  • 3463 Answers
SOURCE: zanussi jetsystem turbodry 1600 wjs1665 w
More than likely the heater element has failed.
This is located at the rear of the washer drum.
It means removing the rear half of the cabinet to access it.
Posted on Mar 29, 2010
I need manuals for zanussi turbodry zww 1202
Go to
http://www.manualslib.com
Then type in the manual you need..
Hope this helps
Ellen
Feb 04, 2015 | Zanussi Washing Machines
Where can I find a manual?
You may view/download the manual here.
Mar 14, 2012 | Zanussi Washing Machines
Zanussi jetsystem turbodry 1600 wjs1665 w is not heating the water
Mar 29, 2010 | Zanussi ZWF1430W Front Load Washer
Zanussi jetsystem turbodry 1200 door wont open
Jun 24, 2009 | Zanussi ZWF1420W Front Load Washer
Washing Machine trips circuit breaker when Drying
This will be the dryer heating element needs replacing.
Hope this helps.
Jan 21, 2009 | Zanussi WDA1055W Front Load Washer / Dryer
Nov 24, 2008 | Zanussi FJS1225W Front Load Washer
Zanussi Turbodry 1200 spin problem
Nov 22, 2008 | Zanussi ZJD1219 Front Load Washer / Dryer
Zanussi WJS 1397W
possibly a foreign object in pump.
tilt backwards at a good angle and remove pump. i find the easiest way to do this is to undo the 3 screws round the periphery of the pump
Jul 11, 2008 | Zanussi WJS1265W Front Load Washer/Dryer
Zanussi JetSystem TurboDry JD12191 - HELP!!
Just 11 month! Do not try to fix it, jet. You have 10 days warranty left. I hope you have your buy ticket/invoice/recipe call service center as soon as possible! In case your warranty expired, there are many probable causes of the failure. You need to give a more detailed description of the problem. It is probable that you can find the user manual in the manufacturers webpage. Or google "your model"+manual Good Luck!
Aug 27, 2007 | Washing Machines
Zanussi jetsystem Turbodry 1200
It appears that you may have a faulty door interlock or a faulty PCB. pcb is not really a DIY job as some boards require proramming on certain versions. Regards Advisor
Oct 30, 2006 | Zanussi FJS1225W Front Load Washer
Washing Machines Logo
41 people viewed this question
Top Washing Machines Experts
