Question about Jacuzzi Home
HELPED INSTALL A JACUZZI FOR MY FRIEND TWO MONTHS AGO. ALREADY THE AIR BLOWER MAKES THE PROPER NOISES BUT NO AIR COMES THROUGH THE VALVES. HELP PLEASE
  • Jacuzzi Master
  • 15,937 Answers
Check the air intake and see if it is ok. Check the output side of the airpump too and also make sure that the nozzles in the tub are not screwed down to shut them off.
Posted on Oct 14, 2013
Air conditioner making loud noise
The only time i have encountered this problem it turned out to be a cracked fan wheel in the blower. fooled me until the fanwheel disengrated and locked up the blower motor.. could be trash in the blower too like leaves, plastic bag etc.
May 07, 2014 | 2007 Kia Sorento LX 4x4
2003 Ford Explorer HVAC blows weak, blend door motor and blower motor resistor already replaced
is the cabin air filter plugged up and it's not getting any air to blow?
Jul 10, 2012 | 2003 Ford Explorer
Need to figure out how to clean out the black stuff that comes out when we turn on the air jets
You need to get some jacuzzi cleaner solution or hot tub jet cleaner solution fill the tub with the solution and follow directions to clean them out needs to be done every couple months IF THIS HELPED PLEASE VOTE FOR ME
Aug 26, 2011 | Whirlpool Aquatic Infinity 1 66X66X25...
I have a 1992 honda accord LX and my blower motor doesnt work and hasn't since i got the car about 2 months ago. It came with the new blower motor but I dont know how to put it in or take the old one out....
From autozone.com:
1990-93 Accord
See Figures 2, 3 and 4
Disconnect the negative battery cable.
If so equipped, disable the Supplemental Restraint System (SRS).
Remove the glove box.Remove the glove box frame (lower support)
Fig. Fig. 2: Remove the glove box and frame
If not equipped with air conditioning:
Remove the three screws and remove the heater duct.
Remove the blower mounting nuts.
Unplug the wiring from the blower motor, resistor and recirculation control motor, then remove the blower assembly.
If equipped with air conditioning:
Lift the carpet in the passenger compartment.
Remove the side cover (kick panel).
Remove the control unit bracket nuts; unplug the five connectors and remove the control unit bracket.
Remove the retaining band, then remove the blower lower covers. Do not break the tabs on the lower covers.
Remove the retaining nuts and remove the blower assembly.
Fig. Fig. 3: Air conditioned models require the removal of the control unit. Handle it carefully
Fig. Fig. 4: Remove the lower covers from the blower unit
To install:
Install the blower unit and tighten the retaining nuts.
On air conditioned vehicles:
Install the lower covers and the retaining band.
Install the control unit bracket and carefully engage the wiring connectors to their proper location.
Install the kick panel and reposition the carpet. Connect the wiring to the blower assembly.
For non-air conditioned vehicles, install the air duct and tighten the screws.
Install the glove box frame and install the glove box. Note that some of trim on the frame is held with 2-sided tape; replace the tape when reassembling as necessary.If applicable, enable the SRS.Connect the negative battery cable.
Aug 22, 2017 | 1992 Honda Accord
5 year old Laars 25,000 LX won't ignite.
The low pressure indicator is for the gas pressure not the water pressure. The heater won't ignite because it's not getting gas to the igniter. Check gas supply, if okay, check gas connections, valves, etc.
The 1 HP motor should be fine on the jacuzzi.
May 26, 2009 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Suddenly whirlpool action in jacuzzi tub very low
Try turning the jets clockwise while they are running and see if this makes a difference.
Jan 18, 2009 | Jacuzzi EH0 / EH1 / EG9 Fuzion 6666 Corner...
Stops Playing: screen freezes
My friend suggested I clean the dvd optical reader lens inside the player with a fine brush (like a camera brush with a blower bulb). This seemed to help immensely. I'm not certain if this is just a temporary fix, but it seems to be ok so far.
Jun 06, 2008 | LG DP781 Portable DVD Player
Making Loud noises
Got the same problem with my second TX-S3082WH Slimfit...the first had the same problem...it was deemed unrepairable and I was advised to return it to Circuit City...now a year and five months later Samsung support has been less than helpful as I am 5 months out of warranty...don't know what I'm going to do...any advice would be appreciated
Dec 02, 2007 | Samsung TXR3079 TV
Home Logo
Top Jacuzzi Home Experts
Mike
john h
Donni Steen
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
