Question about Samsung Refrigerators
My LED light is not coming on when I open the bottom freezer drawer on my Samsung french door refrigerator. I removed the pc board and checked it with an external 12 volt dc battery and it is OK. Where is the switch or sensor that controls this?
    Champion:
  • 210 Answers
Check door switch. whats the model number?
Posted on Oct 15, 2013
  • 116 Answers
SOURCE: Amana French Door Refrigerator "on" but no cooling; freezer still works
There are 2 possible problems. One is the defrost cycle is not working properly this is usually indicated by a large amount of frost on the back freezer panel. If so, the circuit will have to be repaired and the evaperator thawed to remove the ice build up. The other is the fresh food damper is not working properly this is behind the "lump" in the back of the fridge compartment above the top shelf, remove the louver panel to see if it is open or closed. closed will be warm open should be cold. The water dispenser reservoir is probably frozen due to poor air circulation.
Posted on Mar 11, 2007
SOURCE: Bottom freezer door/drawer won't close all the way on one side.
Remove all the food from the freezer and then the drawer from the cabinet. Now using a silicone based lubricant, lube the tracks up real well. Be sure to clean the tracks first if gunked up. Make sure nothing small fell out of the basket over time and is laying on the floor in the rear of the freezer section. Once done, you should be fine.
Eric Campion
Posted on Feb 21, 2009
woodchuck789
  • 4070 Answers
SOURCE: Our 3 yr old LG Model LFC25760SW French door
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Posted on Aug 26, 2009
  • 7 Answers
SOURCE: Samsung refrigerator - frost on outside of freezer drawers
try checking the freezer door seal.
if slight gap anywhere around the door seal drawer fronts will frost up.
warm seal up with hair dryer and ease seal out with your hands..
problem often happens with door reversal.
Posted on Oct 09, 2009
Daniel S
  • 4323 Answers
SOURCE: RF263 series Samsung Refrigerator just began
Hi
The sound comes when there is ice build up around the fan and the fan will hit it causing this sound. You can try to leave it unplugged for around 4-24hrs and also make sure that the area near the back is clear so that airflow can get through. If the issue returns then replace the thermostat. Hope this helps...please post back for further assistance.
Daniel
Posted on Jul 01, 2011
The moisture has to be getting inside to pool. Check your door seals or leaving the doors open to long.
Aug 14, 2016 | Samsung RF265AA Bottom Freezer French Door...
How do I defrost my Samsung bottom freezer? Can I turn off the bell if I need to leave the drawer open while it defrosts?
Most modern refrigerators can be turned off from the control panel. you should be able to shut off the alarm and the freezer and still leave the refrigerator on.
Dec 04, 2014 | Samsung RF265AA Bottom Freezer French Door...
Freezer light bottom not working,bulb good
Warranty time, call maytag, most fridge come with 1 year warranty.
Oct 27, 2013 | Maytag Ice2O MFX2571XE 25 cu. ft. French...
Samsung rf266aepn bottom french door ice maker arm
Simple but a pain. Unplug the refrigerator. Get out your hair dryers and start de-icing the freezer door. Slowly but surly you will get freezer open. Be gentle. Dry EVERYTHING!!! Tracks, rails.....then replace part, plug back in, restock.
If you need further help, reach me via phone at https://www.6ya.com/expert/steve_24d988f3507f7480
Oct 12, 2013 | Samsung RF266AEPN
Removing samsung freezer drawers
There are 3 bolts that hold the bottom of the freezer door in place, if you remove them the door will fall to the floor then youmcan pull it off then you can access the drawer
Sep 07, 2012 | Samsung RFG237AARS Bottom Freezer French...
Samsung rf265 series french door with freezer drawer on the bottom: Water collects under the veg drawers in the refrigerator part. What might be wrong?
I have the same problem!!! We need a class action lawsuit against Samsung for this problem on their French Door fridge. Instead of fixing it they want the consumer to pay for repair. NO MORE SAMSUNG PRODUCTS FOR ME!!!!!
Sep 04, 2011 | Samsung RF265AA Bottom Freezer French Door...
Freezer light no longer comes on. LG LFX28977 3 door refrigerator with Bottom drawer freezer.
The switch and or the led light assy has ice inside of it. This is a known issue with this LG unit.
Call LG and request them to fix this under a warrranty.
Good luck.
Jul 23, 2010 | LG LFX28977 (276 cu ft) Bottom Freezer...
Mod# RFG297AA:Need to remove the freezer section or handle/latch
there are two screws on each side of the bottom freezer unit you need to remove. they can be removed after de-installing the front bin with the two plastic sleeves on the right and left. Then you can remove the bottom drawer door and the bins inside. next, open both top doors and angle the fridge with one door inside the door frame, then "walk" the fridge over the doorstoop, turning towards the inside door as you push. Follow thru with the rest of the unit, then re-attach the bottom drawer.
Apr 08, 2010 | Samsung RF265AA Bottom Freezer French Door...
We have the bottom drawer freezer, top french doors, 3 months old, freezer will not shut all the way and now after door open beep has gone off for an hour the whole unit has gone dark
Make sure nothing has fallen behind the freezer drawer or is hitting the top of the freezer to prevent it from closing. Also check that the tilt open front is in the closed position. If nothing is blocking the drawer the gear wheels that support it may not be in the right position. See Owners Manual for instructions about removing/reinstalling the drawer. When you get the drawer to close you may have to unplug the power cord for 30+ seconds to get the unit to reset and restart.
Aug 11, 2009 | KitchenAid KBFA25ER Bottom Freezer French...
Refrigerators Logo
62 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
