Question about Garden
I have a set of Azden wireless microphone, WMS-PRO. The sound is very low. I got a tip to open them up and adjust a tiny screw labeled VR101 (trans) and VR2 (rec) that adjust pick up. But somehow I messed up and adjusted also a third screw by mistake. Of course, it's not transmitting/receiving anymore! Any way to reset?
  • johan ginyard
    johan ginyard Oct 14, 2013
    Thanks for the solution! I tried to adjust it while transmitting, but I couldn't get it right. I'll try again.
    Scholar:
  • 64 Answers
The third screw was likely a frequency fine-tune adjustment. I would try having it turned on and transmitting, while carefully re-adjusting that third screw until it re-centered on the correct frequency.
On most wireless systems, sound level issues would only require making adjustmen to the reciever only, and if it's for stationary use, such as a PA system or mixing console, then better to leave it alone and boost the gain on the amp or console.
Considering the price of that particular model, if you don't need the reciever to be portable (such as for on-location vidiography), then I'd more strongly recomend spending only a little more for a more reputable, professional brand if you ever decide to upgrade or replace, like the "Sure SM-58" series that I now use.
Posted on Oct 14, 2013
  • 9 Answers
SOURCE: poulan pro 260
Clearance from coil to flywheel should be around .010
Posted on Oct 26, 2008
  • 14 Answers
SOURCE: 2375 ''wild thing'' poulan saw hard starting after carb rebuild
Through trial and error on fairly new Poulin Pro, found that the usual 3-half turns for both high and low was too much (flooded) (Used to be good starting point on weed eaters years ago. So, turned both all the way in, and only backed out 1-full turn. (2-halves) Saw fired up perfectly, and ran wide open just fine. Try that.
Posted on Nov 19, 2008
  • 4 Answers
SOURCE: adjust high low screws on carb.
I found one at my local parts store (they also work on them) for $5. It looks like a screwdriver with a special tip on it.........
Posted on Apr 17, 2009
  • 583 Answers
SOURCE: I have a Mcculloch chain saw. Mac 3216.
hi terry, here we go ---screw the H srew right in till it stops then back it out 1 1/8th of a turn do the same to theL screw but only back it out 1 turn.screw the idle screw in i turn. it is abit difficult adjusting things by holding them with one hand while you screwthings with the other,so if need be clamp the chain bar in a vice making sure the chain is not touching any thing.start the motor ,hold it at a high idle a minute or so to warm up, the n take it up to top revsand hold it there whilst screwing the H screw slowly in and out until it runs the sweetest then back it out 1/8 th of a ,turn, donot take it in past 7/8 ths of a turn . now release the throttle and let it idle do the same thing with the L screw in and out to where it idles best then set your idle speed with the idle screw so that the chain just holds from turning (that is not so important so long as it idles nicely with out cutting out) and there you have it . just watch your hands onthat chain .
Posted on Aug 27, 2009
  • 4088 Answers
SOURCE: "L" adjustment screw on the carburator
L is for idle speed mixture and H is for full throttle mixture. Adjust H, when engine is warmed up, with full throttle--adjust for high speed, but 4-stroking which should smooth out just as soon as you start cutting. Allow to idle and adjust L for smooth idle, but rich enough to allow the engine to 'follow the throttle'. Set idle speed screw to just allow the chain to stop moving.
Posted on Sep 13, 2009
Have a MacBook Pro and A Shure SM27 but the sound it's too low on Garage Band
hello paola go directly in your mac and open properties of the mic and adjust as you like obs this is making tests with the mic connected
yours antonio
Dec 26, 2013 | Shure SM27 Professional Microphone
I cant get both my mikes working together without getting feedback
1 they are too close together
2 the gain for each is too high
3 inputs are physically to close together, try ch1 and ch 4
Oct 30, 2013 | Azden WMS-PRO Professional Microphone
My garage door opens about 6" then stops
It sounds like you need to adjust the force settings on your opener. You should see either a white plastic knob on the opener, or a screw adjustment labelled "Open Force" or "Open Sensitivity". If you adjust that, it should fix the problem. If not, you'll need to contact a repair service.
Sep 16, 2013 | Sears Craftsman LiftMaster Chamberlain...
I have the AKG wms 40 dual mini mic set with two wireless mics. When mic on ch 2 is in the off position, I get lots of static. Works perfectly fine when on. What do you think is the issue?
Channel 2 mic's receiver needs the Squelch adjusted. The squelch control mutes the receiver so that when the transmitter stops transmitting, erroneous noises are not picked up and amplified.
Jan 23, 2013 | AKG WMS 40 Professional Microphone
Won't Record From Shotgun Mic.
Adjust Recording Levels.
Win 7Start > Control Panel > Hardware and Sound > Sound > Microphone >Properties > Level.
Oct 04, 2012 | Alesis PalmTrack Handheld Portable SD...
Have an Aiptek HD 12 1080p with Azden wireless mic system. no sound with wireless mic, but sound works on camcorder without the wireless.
you need to use a mono-to-stereo cable, the azden is a mono output mic by the aiptek is a stereo input and you are shorting out the phantom power with a mono plug in a stereo jack.
- DL
Sep 06, 2011 | Aiptek Cameras
How to make Shure wireless mic work with Azden 305
Sorry, that is not possible. Different manufacturers use different companding, noise reduction, and squelch schemes. Thus, even if they are on the same frequency, you might not get any audio or the audio might sound quite funny.
May 06, 2010 | Shure ULX1 Body-Pack Transmitter...
Wiring broke for all five wires in the usb connection of a Rosetta Stone Head Set 20090205. I may be able to re-attach. Where do the wires go on the usb plug?
Open the plug case by prying it apart.
The tiny circuit board is labelled on one side - three connectors for the headset and two for the microphone.
G - headset ground - red/gold wire
R - headset right - blue wire
L - heasdet left - red wire
M+ - microphone + - green wire
M- - microphone - gold wire.
Use hot soldering iron to 'melt' off the tip of the wire coating and apply tiny amount of solder. Place wire in position and solder together.
Finally use electircal tape to hold the plug covers together and continue to tape along the cable so it will not pull out again.
Jan 17, 2010 | Rosetta Stone Spanish Level 1-2-3 Full...
Extremely weak RF from AKG WMS 60 Hand Held Mic
I don't know what you've tried already to improve the signal level, so i'll list a few things that migt help.
It might help to put new batteries in (with the right voltage) You probably did that already.
There is a GAIN pot on the mic, in the battery compartment under the ring that is screwed onto the mic. When you adjust the GAIN, there will probably be better SN-ratio, but it does'nt change the RF signal
You could also adjust the antennas of the receiver, or try to set a different frequency (depends on which country you live in, in some countries it is illegal to change frequencies) or turn off the SQUELCH on the receiver
If this does'nt help, you could look for a user manual and try to find a solution in it.
There are some other solutions to improve RF signal, but those are quite expensive.
Oct 20, 2008 | Audio Players & Recorders
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
